Pocket GPS World :: View topic - Aytobe- Speedcams and other POIs
Goto page Previous  1, 2, 3 ... 7, 8, 9 ... 18, 19, 20  Next
Post new topic   This topic is locked: you cannot edit posts or make replies.    Pocket GPS World Forum Index -> Other Hardware and Software
Mike1963
PostPosted: Mon Apr 30, 2007 7:57 pm    Post subject: Reply with quote
I get happier by the minute with my AytoBe. Best £93 my daughter has ever spent on a present for me Smile
fordfocus
PostPosted: Mon Apr 30, 2007 9:26 pm    Post subject: Reply with quote
widu wrote:
portman wrote:
Another option if you want Tomtom 6 and a PDA is this PH one for £128.
http://www.expansys.com/p.aspx?i=143354
That's a better deal than the A2B...I've ordered one Exclamation Thanks for the link :D
Thanks for the Ipaq link, absolute snip at that price, just ordered one, stock expected in 3 days :D :D
widu
PostPosted: Mon Apr 30, 2007 9:50 pm    Post subject: Reply with quote
The link is down to "Portman". Thanks again mate.
Device: Co-Pilot (Android)
Skoda Columbus
Sallet
PostPosted: Mon Apr 30, 2007 10:17 pm    Post subject: Reply with quote
A good discussion! We can always spend more money on a better or more versatile machine but I enjoy the DIY aspects of these machines. The Aytobe seems good value to me and I have managed to get TomTom 6 working on it. A question though, has anyone managed to upgrade to 6.01, 6.02 or even 6.03?
Retromax
PostPosted: Tue May 01, 2007 8:14 am    Post subject: Reply with quote
Mike1963 wrote:
Process Killer - very handy! Use the version with mcf. I managed to kill Malata.
To get the taskbar/start button - use SIPrc keyboard, press Ctrl and Esc, it should pop up then you can change the settings so that it isnt hidden.
Thanks for that, i can now see the task bar but when i kill malata it does go which is good but there is still something showing on the task bar.
How do you do a right-click?
phonic
PostPosted: Tue May 01, 2007 10:36 am    Post subject: Reply with quote
you can just edit the reg to remove malata.exe and change autorun.exe to explorer.exe and it will be as a normal pda after a softboot.
HKEY_LOCAL_MACHINE\init change delete Launch50 "Malata.exe"
and edit Launch45 "autorun.exe" to "explorer.exe" .
do a soft reboot.
One problem with removing Malata is that keys don't work...
phonic
PostPosted: Tue May 01, 2007 10:53 am    Post subject: Reply with quote
Regarding the Ipaq:
Does anyone know if the Ipaq GPS as LCD display as good or better then the AyToBe? I get 9-12 sats on my AyToBe.
also the CPU is a 400Mhz Samsung cpu and the Aytobe is a Intel 300Mhz PXA255. any problems with software, speed? Could I still use my old software for Intel ARM cpus?
I've double checked and hp ipaq normal selling price is £249, is it discontinued?
wow...If it's really going for over 50% lower, then I'll get one just for work.
phonic
PostPosted: Tue May 01, 2007 11:19 am    Post subject: Reply with quote
How about using the AyToBe as a GPS receiver on your LapTop?
The software you need is all Freeware and listed below:
1) GPS2Blue 1.7
http://users.skynet.be/hofinger/GPS2Blue.html
2) .NET Compact Framework 2.0 Service Pack 2
http://www.microsoft.com/downloads/details.aspx?FamilyID=AEA55F2F-07B5-4A8C-8A44-B4E1B196D5C0&displaylang=en
4) Microsoft ActiveSync 4.5 (only tested on this version)
5) HW VSP
http://www.hw-group.com/products/hw_vsp/index_en.html#download
Install Active Sync on Laptop (if not already using it)
Install .NET 2.0, but does not start via ActiveSync, you need to copy the .cab over and install that way.
Install Gps2Blue on AyToBe.
Settings: IP should be 192.168.55.101, remote: 192.168.55.100.
tick TCP/IP. GPS is on COM6 at 9600. Click "On" to start.
Install HW VPS on Laptop. Settings: Select(settings tab): HW VP work as the TCP Server only.
Unselected(settings tab): Don't create VSP Port if Ping to
remote device failed.
in VSP tab: IP: 192.168.55.101(your IP) Port: 31873
Port name: COM5 or any free port name. Server Port: 31873.
Theses settings work both on my Laptop and Desktop pc, running Windows XP SP2.
Make sure you always install software to MMC_Storage. Good idea to make a folder called Program Files.
Mike1963
PostPosted: Tue May 01, 2007 11:27 am    Post subject: Reply with quote
I`d been using my laptop with a Garmin GPSr for satnav but found it cumbersome in the car. The A2B does a much better job.
Is it possible for TCPMP to play WMV movies? What codec/whatever do I need?
phonic
PostPosted: Tue May 01, 2007 11:37 am    Post subject: Reply with quote
It does support windows media audio and video files, but I it requires the codecs from Windows Media for it to work. I have not found a download for it yet.
I'm using the same player, and just test a 700MB .mpg video, and worked well.
Retromax
PostPosted: Tue May 01, 2007 11:43 am    Post subject: Reply with quote
do a soft reboot.
and how do i do that then?
cant run regedit
oh and yes, i didn't realise the top key no-longer works.... but who cares
Mike1963
PostPosted: Tue May 01, 2007 11:45 am    Post subject: Reply with quote
700MB? I bet that took forever to transfer! I`m setting it up to be an autocue for my sax playing. I`ve made some movies that display the sheet music and play backing but I used the Windows Movie Maker that only outputs to WMV afaik. I suppose I could convert to mpg but it would be simpler if TCPMP played WMV. I`ll work it out.
do a soft reboot.
cant run regedit
Use that regedit proig I posted earlier.
ejr1039
PostPosted: Tue May 01, 2007 11:52 am    Post subject: Reply with quote
http://h10010.www1.hp.com/wwpc/uk/en/sm/WF06b/21675-21679-21679-21679-297609-12816716-78075723.html Laughing :D
Retromax
PostPosted: Tue May 01, 2007 12:01 pm    Post subject: Reply with quote
Where?
Sorry if i appear dumb but i looked through the posts and cant see it
Mike1963
PostPosted: Tue May 01, 2007 12:04 pm    Post subject: Reply with quote
Here ya go...
IBE Reg editor
Registry editor
None.
Post new topic   This topic is locked: you cannot edit posts or make replies.    Pocket GPS World Forum Index -> Other Hardware and Software All times are GMT + 1 Hour
Page 8 of 20
24.034 (25 Mar 26)
