Pocket GPS World :: View topic - Need new in car power cable
roonaldo
PostPosted: Sat May 12, 2007 12:28 pm    Post subject: Need new in car power cable Reply with quote
Last night the end of my power cable fell off and the fuse came out and since putting it back together it no longer works. I was wondering what charger I would need as a replacement. I have read the V3 ones work but cant seem to find any that don't have a curly wire.
Would it be possible to buy this
http://cgi.ebay.co.uk/USB-CAR-CHARGER-ADAPTER-iPOD-VIDEO-MINI-MP3-PSP-UK_W0QQitemZ280114023943QQihZ018QQcategoryZ86533QQrdZ1QQcmdZViewItem
then simply use the usb cable that came with the i3 initially to charge it?
thanks
BoneMan1946
PostPosted: Mon May 14, 2007 3:10 pm    Post subject: Reply with quote
Roonaldo,
Same thing happened to me Sad . However please check you still have power to your lighter socket before getting a replacement. When mine went, it "blew" the car's fuse and gave the impression it wasn't working. I tested it in another car and it worked fine. Suggest you check the I3 power cable in another car (if possible) and/or check the fuse for your lighter socket. You may find you don't have to buy any replacement Wink
Ray.
roonaldo
PostPosted: Fri May 18, 2007 3:14 pm    Post subject: Reply with quote
You have just saved me the effort of buying a new cable to find out it doesn't help!
The fuse in the car was spot on, brilliant. everything is working again now.
However I'm sure that before it stopped working the i3 could be switched on when plugged in even if the ignition wasn't switched on. But now you at least have to turn the key once so the battery comes on. Is this just me remembering wrong?
swing
PostPosted: Fri May 18, 2007 6:05 pm    Post subject: Reply with quote
Whether the cigarette lighter socket is active all the time, or switched with the ignition is a decision the manufacturer takes, and wires the car differently, so simply replacing a fuse should not be able to influence that. If you tell us which model car, and approximate age, someone may be able to confirm what behaviour they would expect...
Please don't be offended if I do not reply to a PM - please ask questions via the forums.
roonaldo
PostPosted: Sat May 19, 2007 10:41 am    Post subject: Reply with quote
Ok thanks, it's an x reg peugeot 206. Smile
BoneMan1946
PostPosted: Mon May 21, 2007 4:46 pm    Post subject: Reply with quote
Swing,
Don't want to cross swords with a "fanatic" Wink but some car makers give you a choice. My current car (a Ford) and the one before (a Citroen) both had two positions for the appropriate fuse; one for "ignition controlled" and one for "always on".
Roonaldo,
If you can, please check your owner's handbook. That should have all the info. However, as Peugeot and Citroen are basically the same company, your Peugeot may well have the same "feature" as my old Citroen Wink .
Ray.
swing
PostPosted: Mon May 21, 2007 4:56 pm    Post subject: Reply with quote
Now, that's interesting, and shows us fanatics can still learn a thing or two Wink
Or maybe it just shows we need to read the manual more, says a Citroen owner!
24.041 (01 Apr 26)
