MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15452 Location: Bradford, West Yorkshire
Posted: Thu May 17, 2007 9:25 pm Post subject: iGO Speed Camera Database Released |
As from todays release (5.053) there is a version of the database available for iGO software - it is the "text file" version as mentioned in another thread.
Simply select 'iGO' on the downloads page.
MaFt |
linknet Frequent Visitor
Posted: Fri Jun 08, 2007 9:25 am Post subject: Re: iGO Speed Camera Database Released |
MaFt wrote: | As from todays release (5.053) there is a version of the database available for iGO software - it is the "text file" version as mentioned in another thread.
MaFt |
There appear to be a couple of anomalies in the PGPSW iGO Speed Camera text file.
Firstly, it isn't in true text format, each line ends in a LF (Line Feed - Hex 0A) only rather than the normal CRLF (Carriage Return + Line Feed - Hex 0D + Hex 0A).
I know that iGO still accepts this but it's non-standard and when opened in NotePad, for instance, it's not formatted correctly.
Secondly, many of the Type 3 RedLight cameras have speed information in the SPEED field rather than 0 (zero).
Again it's possible that iGO will ignore this information if the TYPE field is set to 3 , but for correctness, it still should be set to 0 (zero).
Regards
linknet
Posted: Fri Jun 08, 2007 10:54 am Post subject: |
file displays correctly in notepad for me... |
Posted: Fri Jun 08, 2007 11:12 am Post subject: |
MaFt wrote: | file displays correctly in notepad for me... |
Strange ?
This is how it displays on three different machines, two WinXP-SP2 and one Vista:
This is with LF's replaced with CRLF's:
Am I doing something wrong ?
Regards
linknet
Posted: Fri Jun 08, 2007 11:36 am Post subject: |
ah, think i see the problem here.
i was checking the main file on my system as opposed to the downloaded one.
after downloading the file i get the same issue as you.
i can only assume that the process used for zipping the files on the server messes with the .txt file - certinly i've noticed it with the layout of release.txt
probably nothing we can do, but if the file works wih the igo then it shouldn't be an issue
MaFt |
Posted: Fri Jun 08, 2007 11:49 am Post subject: |
MaFt wrote: | ah, think i see the problem here.
MaFt |
Yes, it's doing it with all the text files (release and licence text) in all of the PGPSW downloads.
I think your server needs a tweak
Are you using a Unix/Linux based server, in which case the original text files won't contain any CRLF's, only LF's. It's unlikely that the zip is removing them, they're probably just not there to begin with.
Regards
linknet |
Posted: Fri Jun 15, 2007 4:40 pm Post subject: Re: iGO Speed Camera Database Released |
linknet wrote: | MaFt wrote: | As from todays release (5.053) there is a version of the database available for iGO software - it is the "text file" version as mentioned in another thread.
MaFt |
Many of the Type 3 RedLight cameras have speed information in the SPEED field rather than 0 (zero).
It's possible that iGO will ignore this information if the TYPE field is set to 3 , but for correctness, it still should be set to 0 (zero).
linknet |
Hi MaFt
Any chance of a reply to this second part of the question ?
Regards
linknet |
Posted: Sat Jun 16, 2007 12:48 am Post subject: |
i don't have igo but alix who has tested the file for me did not have any issues with the speed setting on the redlight cams.
MaFt |
mk_graham Regular Visitor
Joined: Jul 13, 2006 Posts: 200 Location: Milton Keynes UK
Posted: Wed Aug 08, 2007 2:05 pm Post subject: |
Short and sweet question - if I purchase and install the PGPSW IGO speed cams to my V7 PMD 1400 will it bong nicely at me if I exceed? _________________ Garmin i3 gone (sold on eBay)
V7 PMD 1400 with Western Europe Maps gone (sold in local paper)
TomTom Go 720 WE Maps (for sale)
iPhone with Sygic Mobile Maps (Europe) - having problems |
Posted: Wed Aug 08, 2007 2:59 pm Post subject: |
mk_graham wrote: | Short and sweet question - if I purchase and install the PGPSW IGO speed cams to my V7 PMD 1400 will it bong nicely at me if I exceed? |
there is a specific download for the Myguide PND's that will work fine - the myguide units run a similar version of the igo software
MaFt |
Posted: Wed Aug 08, 2007 5:09 pm Post subject: |
Thanks for the info MaFt _________________ Garmin i3 gone (sold on eBay)
Posted: Thu Aug 09, 2007 11:42 am Post subject: |
Hmmm, my V7 unit doesn't have a USB port to connect to the PC to load these files to the unit.
I copied these to the SD card and reading around I found instructions to 'hack' various files so that you can get WinCE explorer to run. I did this okay a copied the files from the SD to the Flash Disk\MyGuide\POI\SPEEDCAM folder and restarted the unit. All okay.
Short of driving towards a camera over the limit to check that they are working, should I be able to see the cameras in Map or Cockpit mode as I can't see them at the moment? _________________ Garmin i3 gone (sold on eBay)
Posted: Sat Aug 18, 2007 10:07 pm Post subject: |
Okay just back from a week away with my V7 with PGPSW speed cams loaded as advised, but they don't work!! Advice: don't waste your 2 quid if you have one of these V7 units as (sorry MaFt) they are NOT the same as the MyGuide 3000; assuming that some peeps have confirmed that the speed cams work on MyGuide 3000's?? Anyone?? _________________ Garmin i3 gone (sold on eBay)
Posted: Sat Aug 18, 2007 11:15 pm Post subject: |
mk_graham - many apologies. please can you email mike (AT) pocketgpsworld.com and he will arrange a refund of your payment. please point him to this thread as confirmation.
thanks
MaFt |
Sallet Occasional Visitor
Posted: Sat Jun 14, 2008 4:47 pm Post subject: |
linknet wrote: | MaFt wrote: | ah, think i see the problem here.
MaFt |
Regards
linknet |
If you use WORDPAD rather than Notepad (type WORDPAD from the RUN command in XP) this allows editing and save as .txt keeping any CR or LF hidden in the file. |
