Pocket GPS World :: View topic - How to install (camera database) POIs to TomTom Navigator 5+
Goto page Previous  1, 2, 3 ... , 16, 17, 18  Next
Ezy162
PostPosted: Wed Aug 01, 2007 2:23 pm    Post subject: Reply with quote
okok chill the bean
TheChef
PostPosted: Thu Sep 06, 2007 11:01 am    Post subject: Reply with quote
I have just had my PDA repaired, and had to re-install TTN5 back onto it, the camera database is in the folder Great Britain map on the SD card but they are not showing up on the Manage POI's so I can not tick them to make them active.
and my poiedit manager says the pocketgps is offine.
If the camera files are in the correct folder why won't they appear in manage POI's, ?
Was ok before it went off for repair. any advise would be greatly appreciated...
Privateer
PostPosted: Thu Sep 06, 2007 4:05 pm    Post subject: Reply with quote
Hi TheChef,
The POI Edit method had been stopped, to avoid confusion. Another way is now used to allow you to download the files.
You need to use this page instead.
Robert.
Garmin Camper 770 LMT-D
grumsta
PostPosted: Tue Sep 25, 2007 1:08 am    Post subject: Reply with quote
Hi just wondering if anyone has had any joy getting this to work with tomtom6 on a nokia 6120 classic?
tuck1s
PostPosted: Tue Oct 02, 2007 7:36 pm    Post subject: Automatic update with subscription Reply with quote
Hi PocketGPSworld,
Along with probably quite a few other users, my PoiEdit sync recently stopped working, and after reading the forum, I've taken out my £19 subscription, and done a manual sync.
All looks fine, but I really miss the automatic sync that I had with PoiEdit. I am happy to pay my subscription, but I would like an automatic update method.
Are there any plans in the pipeline? surely it's not impossible for some client SW (like PoiEdit or something else) to provide credentials when downloading, that you are prepared to accept and validate?
[TomTom Navigator 5.2 running on Dell Axim X50]
niek
PostPosted: Sun Oct 14, 2007 2:58 pm    Post subject: download speed cams netherlands Reply with quote
i don't get where I can download the speedcams for the netherlands.. can anybody give me a link..
PostPosted: Sun Oct 14, 2007 3:35 pm    Post subject: Re: download speed cams netherlands Reply with quote
You will need to Subscribe first and then Click the Speed Camera Link at the Top Left of every Page.
The Cameras for any European Country is combined into the EUR Download.
TT Via 135 App 12.075: Europe Map v1165
peugeot306dturbo
PostPosted: Tue Oct 16, 2007 3:28 pm    Post subject: If you're running out of POIs in TT5 Reply with quote
Guys, got bored by the time I reached page 10 of this post so if this tip has been posted already I apologise:
I've run out of POIs (only 40 for TT5) on my Ipaq 2210. The solution to this for me was:
Use Speed zoned Gatso files (and set appropriate voice warnings)
Use Consolidated by Type files for everything else (due to the number of custom POIs I have this was best for me)
However you may also be able to fit the Speed zoned Mobiles if you have more room than me (which would be useful)
Simply delete the old speed zoned files which will not display as they won't fit (leaving the ones that will fit) and copy the Consol. by type ones across to the same folder. Then set the warnings as described in the other threads...
Eg:
[SZ] = Using files from Speed zoned db
[CL] = Using single files from Consolidated db
Say I have 27 Custom POIs (a lot I know)
I choose to use:
8 Gasos [SZ]
2 Mobiles [CL]
1 Redlight [CL]
1 Specs [CL]
1 Temporary [CL]
=13 POIs
27+13=40 (I have used my limit)
If I deleted some Custom POIs I didn't need, I might be able to fit some/all the Speed zoned Mobiles on there too (15 including 'P-Mobile' files)
I'm not an expert but I hope this helps.
PostPosted: Tue Oct 16, 2007 3:39 pm    Post subject: Reply with quote
You are one over your limit as it is 39 for TTN5 Wink - Mike
FrequentFlyer
PostPosted: Wed Oct 17, 2007 10:24 pm    Post subject: Reply with quote
Blimey...page 17.
Do I assume that I can download the camera files using TT Home...if so, struggling to find out how !
Hunterlaar
PostPosted: Mon Nov 26, 2007 6:05 am    Post subject: Reply with quote
If i enable the gatso poi alone on a nokia phone it disables all the other warning poi signs like redlights ect they don't show on the screen.. anyone know why this is?
mburton2
PostPosted: Mon Jan 14, 2008 8:51 pm    Post subject: Reply with quote
I've just updated the TTN5.21 on my Dell Axim x51V (Mobile Windoz 5) to TTN 6.010...
Having just downloaded the UK speed camera DB (I now have only two "map" folders, Western&Central Europe, and EasternEurope...I copied the ov2&bmp files into Western&Central), I have a choice:
1) Enable the Various UK camera POIs (This works OK)
2) Connect my GlobalSat BT-338 GPs to the PDA (This works fine)
If I try to do both 1) & 2), the PDA just hangs/does nothing.
Anyone know why?
PostPosted: Mon Jan 14, 2008 9:01 pm    Post subject: Reply with quote
Go to Change Preferences/ Enable_Disable POI and de-select the whole lot, use the warn when near POI funcion to get warnings - this might sort the issue out - Mike
mburton2
PostPosted: Mon Jan 14, 2008 9:47 pm    Post subject: Reply with quote
OK,Tried that....
Turned on the BT-GPS.....a few seconds later it connected to the PDA....then everything froze again. Sad
EDIT
I noticed when de-selecting the "Warn when near", that some of the .bmps were red squares, and NOT the camera/speed icon I was expecting...a sign of a currupt download??
PostPosted: Tue Jan 15, 2008 7:38 am    Post subject: Reply with quote
mburton2 wrote:
EDIT
The red square is an indication that a matching bmp file can't be found.
Either the name is wrong, it has to be an exact match to the ov2, or it doesn't exist in the Map Folder.
Page 17 of 18
24.041 (01 Apr 26)
