| Author |
DennisN Tired Old Man
Posted: Thu Aug 02, 2007 7:46 am Post subject: |
| BGF wrote: | | Outlander wrote: | | DennisN, sorry but can you explain RTFM for those of us who are not up on technical language. If you could put that into plain English that would be great. | 1)
2)
3) See here for the reason for my amusement
4)
5) / |
Ah - Touched, as mes French amis would say. I'd almost forgotten that. But I think Andy gave me a link to an Acronym dictionary, which I've set as a Bookmark, although I actually learned RTFM long before I became DennisN (after the one and only manual I ever DID read - Lotus 123 back in 1986, I wore it out in six months).
Must be off to go sit by the front door - 720 due inside 1.5 hours now. _________________ Dennis
Two of them are obesiting!! |
| Back to top |
homersolly Occasional Visitor
Joined: Mar 07, 2006 Posts: 32 Location: Leicestershire, UK
Posted: Thu Aug 02, 2007 7:53 am Post subject: |
Hi Darren,
Thank for the info on the N73.
Could I just ask what you actually think of the phone?
Thanks in advance.
Kevo
:D |
| Back to top |
Darren Frequent Visitor
Posted: Thu Aug 02, 2007 8:06 am Post subject: |
| SpeedCam wrote: | | So does this mean Darren can now publish the review? |
Indeed it does and I am busily working on that now (I only received the retail unit Monday).
| Quote: | | Also can someone upload the user guide so that I can read it before mine arrives. |
Get the manual here. _________________ Darren Griffin |
| Back to top |
PaulBt Lifetime Member
Joined: Sep 22, 2006 Posts: 188 Location: Kempsford, UK
I have also connected a SE T610 without any problems.
It is also very easy to switch between phones, but only one will connect at a time.
Paul _________________ TT720 V8.010, regular audio book user.
WestEuro v805 connected to E90 on O2
TT910 V6.525, TTN5, TTN3, TT on Psion 5mx |
| Back to top |
Posted: Thu Aug 02, 2007 8:10 am Post subject: |
| PaulBt wrote: | I have just tried to upload the present set of zoned speed cameras and am told: | Quote: | | The is no map where this set of POIs can be shown |
Well I installed Speed Zoned onto our 720 last night (using the HOME version of the download) and it worked fine? _________________ Darren Griffin |
| Back to top |
| pete1336 wrote: | Interestingly, I've set up my usual liz whittaker ogg files to use for the speed cam warnings. Having set up this up 3 or four times, the unit seems to lost the link to them after it's reset and they need setting up again. I'm wondering if this is a fault with the unit or if it's something I'm doing wrong. If anyone else experiences this with a 720 please post.
Thanks. |
Not had that issue even after resetting. _________________ Darren Griffin |
| Back to top |
Posted: Thu Aug 02, 2007 8:11 am Post subject: |
| homersolly wrote: | Hi Darren,
Thanks in advance.
Kevo
:D |
It's OK, the menus can be a little slow but the camera is good (in good lighting) and the web browser works well. _________________ Darren Griffin |
| Back to top |
davefarley Occasional Visitor
Posted: Thu Aug 02, 2007 9:03 am Post subject: |
Dixons is now showing the 720 as In Stock! I also got a mail this morning to say they are processing my order:
"This is to confirm that we are starting to process your order. When we are able to confirm your order we will send you a third email, which will also confirm dispatch of the goods"
Whooohoo! |
| Back to top |
Posted: Thu Aug 02, 2007 9:25 am Post subject: |
| runarg wrote: | | PaulBt wrote: | | On the 720 you can only use the bells, bleeps, and chicken noices, or record your own voice. |
No, you have the same possibilities as you have on GO910. That is if you use TTS! |
Thanks runarg, it had changed to a non-TTS voice. How did that happen?
| Back to top |
Posted: Thu Aug 02, 2007 9:31 am Post subject: |
| Darren wrote: | | PaulBt wrote: | I have just tried to upload the present set of zoned speed cameras and am told: | Quote: | | The is no map where this set of POIs can be shown |
Well I installed Speed Zoned onto our 720 last night (using the HOME version of the download) and it worked fine? |
Thanks Darren, I will try again, I was using the 1.5 version of HOME. I have subseqently updated HOME to 1.6 from the CD, and this recognises the unit as a 720, where as 1.5 only said it was a GO.
| Back to top |
Posted: Thu Aug 02, 2007 9:33 am Post subject: |
| PaulBt wrote: | | Thanks runarg, it had changed to a non-TTS voice. How did that happen? |
Have you by any chance inserted a memory card in the SD slot? _________________ Darren Griffin |
| Back to top |
Posted: Thu Aug 02, 2007 10:09 am Post subject: |
My order at Dixons is being processed.
Let's see how long it takes to arrive.
Kevo |
| Back to top |
SpeedCam Frequent Visitor
Joined: Mar 18, 2004 Posts: 755 Location: Biggleswade, BEDS
Posted: Thu Aug 02, 2007 10:16 am Post subject: |
:D Having read the manual last night there apears to be some very small but nice improvements, hopefully my 720 will be waiting for me this evening...
The only thing that I noticed that was a backward step is the warranty, if I'm not mistaken previous GO's had a 2 year warranty, reading the small print the x20 now only have a 12month warranty. |
| Back to top |
Posted: Thu Aug 02, 2007 11:08 am Post subject: |
| Darren wrote: | | PaulBt wrote: | | Thanks runarg, it had changed to a non-TTS voice. How did that happen? |
Have you by any chance inserted a memory card in the SD slot? |
Darren,
I have a we card that I am going to try tonight. So far I plan to use it for podcasts.
I am assuming that I just need to put them into an mp3 directory on the card. _________________ TT720 V8.010, regular audio book user.
| Back to top |
uffe73 Frequent Visitor
Posted: Thu Aug 02, 2007 11:41 am Post subject: |
| Could any of you lucky TomTom GO 720 owners let me know the version number of the Western Europe map supplied with the unit? Have you seen any improvements compared to the Navteq map v660.1256 and the Tele Atlas map v675.1409? I wonder if there will pop up a v680 map for Western Europe soon (just as for Eastern Europe) or if the next maps will be v7xx indicating the connection with the Navcore 7 SW. |
| Back to top |
| Back to top |
