Pocket GPS World :: View topic - ANN: Postcode support for TTN2 on PocketPC
Goto page Previous  1, 2, 3 ... 10, 11, 12, 13, 14  Next
sland
PostPosted: Tue Mar 23, 2004 11:12 pm    Post subject: Reply with quote
I am an idiot Sad you are a genious Smile
//note to self - when somebody goes to a lot of trouble to write a help file - READ IT!!
OK Here is how I got it working - most of this is covered in your explanation of how to install ukpostcode but I just didnt read the document properly. When the install didn't work I installed CheckPOInt to try that. Of course I then tried to run the install for ukpostcode again instead of remembering to just copy the 2 files (exe and dat) to a folder in my SD card.
Anyway, here is how to use ukpostcode on a WM2003 PPC with TTN3:
    Install TTN3.
    I then updated to 3.01 (avail from TT website) but you may not have to.
    Install CheckPOInt 3.2 avail from http://checkpoint.oabsoftware.nl/
    Copy the ukpostcode exe and dat to a folder on your card as per Niels instructions.
    Make a shortcut to the exe as per Niels instructions.
Voila! A working solution.
Sorry for duff gen earlier and hopefully this explanation will make me forgiven (me blushes).
Rgds Sland
Torchy
PostPosted: Thu Mar 25, 2004 2:29 pm    Post subject: Reply with quote
Glad that you have got the program up and running but I have a problem. I originally loaded a version several day ago. This was the version that had a number of Post Codes missing. Now yesterday a colleague told me that the program had been updated and in fact showed me that the missing codes were now available.
So I downloaded and installed exactly as before but to no avail. It just will not work and an error message tells me that the Exe file is missing.
Any ideas please?
sland
PostPosted: Thu Mar 25, 2004 5:08 pm    Post subject: Reply with quote
delete your existng shortcut and create a new shortcut to the new exe?
Rgds,
Mike
Torchy
PostPosted: Thu Mar 25, 2004 5:15 pm    Post subject: Reply with quote
I've tried that. The error messages are:
1] Installation error - ukpostcode.dat not found in exe folder (it IS there)
2] No matching postcode in database
Thanks for the reply
Torchy
PostPosted: Thu Mar 25, 2004 5:32 pm    Post subject: Reply with quote
At last!!!! It is working, however one last problem- how do I get the program icon onto the main menu please. I have used 'copy' but cannot find how to 'paste'
Sorry I'm so stupid!!!
Dave Embarassed
sland
PostPosted: Thu Mar 25, 2004 5:34 pm    Post subject: Reply with quote
Have you tried deleting the shortcut, create a new folder, move exe and dat to new folder, delete old folder then create new shortcut to new exe.
I know it sounds longwinded but it may fix things (of course it may not but theres only one way to find out) Smile
Rgds,
Mike
sland
PostPosted: Thu Mar 25, 2004 5:39 pm    Post subject: Reply with quote
Dave Embarassed
browse to windows/startmenu and press stylus and hold it down, popup menu should offer paste as an option.
Rgds,
Mike
Squibby
PostPosted: Fri Mar 26, 2004 8:22 pm    Post subject: GPS Assist Problem Reply with quote
Problem resolved by simply re-loading GPS Assist and taking a YES to all the updates. UK Postcode works fine.
Rgds
Squibby
dynamite
PostPosted: Fri Mar 26, 2004 11:27 pm    Post subject: Reply with quote
Hi Guys,
Sorry, been off the forum for a few days - busy at work.
Glad to see you are all managing to sort out the problems without me though Smile - I really must get round to sorting out the installation program.
sland,
I'm dead keen to know what level of support TTN3 has for post codes... Any? Any chance of a screen shot?
Niels
PostPosted: Sat Mar 27, 2004 3:06 pm    Post subject: Reply with quote
5 digits
PostPosted: Sat Mar 27, 2004 4:21 pm    Post subject: Reply with quote
In other words your application is still needed! I used it the other day, TTN had got me to the industrial estate OK but I couldn't locate the right unit (huge place with no signs!), I did have the Post Code so launched your app, tapped in the code and it took me right to the door Thumbs Up
hegedusa
PostPosted: Sun Mar 28, 2004 10:57 am    Post subject: Reply with quote
I did find a problem with installation - initially the setup files were located in a folder on my pc - C:\download\tomtom\uk postcodes\ukpostcode_all_ppc2002
When I tried to install, it didn't actually install anything.
I moved the install files to just C:\download\tomtom\posttest it worked fine.
Perhaps it's the space in part of the path, or just the length of the path.
It works fine now (ppc 2002 with the .net framework loaded)
Nick412 wrote:
hi,
ive just downloaded this and i have a problem which im hoping someone can help me out with.
i have downloaded the ppc 2002 version & unzipped to a folder on my desktop pc
i have clicked setup - and it connects to the pda
the next screen is where i get a problem...it shows me the apps currently installed with ticks etc...but
it says space required for this app 0.0kb
space available 32mb etc
after i select default folder, and click ok nothing happens, and it doesnt look as though it has installed.
any help would be gr8
im on my dinner so fast assist would be appreciated.
Regards
Nick
mhowse
PostPosted: Sun Mar 28, 2004 8:04 pm    Post subject: jornada 548 Reply with quote
Hi There,
Saw an earlier post from someone with a jornada 548 , still not quite sure if it will work on this running WinCE 3.0 on a SH3 processor , if it does work ok which download shall I select please, have just downloaded all the area codes from the posting at the top of this forum so if it does not work will try and install them instead, thanks it sounds real good so would rather try your option first.
Mark
dynamite
PostPosted: Sun Mar 28, 2004 9:22 pm    Post subject: Reply with quote
Hi Mark,
No sorry, at the moment I haven't compiled the program for the SH3. I have had one other request for it, so I'll see if I can get hold of the right SDK for that platform and recompile the program for it. PM me your email address and I'll keep you informed.
- Niels
mhowse
PostPosted: Mon Mar 29, 2004 9:12 am    Post subject: P.M sent Niels Reply with quote
Thanks Niels have sent p.m with e-mail details
If anybody knows if checkpoint and the area post code poi will run on my jornada 548 running wince 3.0 sh3 chip please let me know and any speed camera poi also have posted in poi syn forum also..
Mark
Page 11 of 14
24.041 (01 Apr 26)
