Pocket GPS World :: View topic - quickgps.exe error
quickgps.exe error
deevee
PostPosted: Tue Aug 14, 2007 4:48 pm    Post subject: quickgps.exe error Reply with quote
I have begun to receive a notification error 'cannot execute\windows\quickgps.exe'
I then get a reminder that 'the satellite data on your device has expired'
When I try and connect, which takes ages, I eventually get a message saying 'connection failed'
I havent changed any settings or done anything I can think of that would have any effect.
Anyone got any clues ?
PostPosted: Tue Aug 14, 2007 10:02 pm    Post subject: Reply with quote
you may have to do a hard/clean reset on your device to get that back into working order. How much software did you install?
SpikeyMikey
PostPosted: Wed Aug 15, 2007 9:32 am    Post subject: Reply with quote
I found this link if it helps
http://www.4winmobile.com/forums/htc-artemis/9274-quickgps-notification-error.html
This happens to my wifes Orbit occassionally, but connecting manually normally restores OK, then it might not happen for ages. If you can sort your connection problem out I think you'll find it will go away.
Mike
deevee
PostPosted: Thu Aug 16, 2007 2:35 pm    Post subject: Reply with quote
Thanks Guys, a combination of a soft reset and going to the start menu and opening the prog from there seems to have done the trick.
I dont know whether there is a conflict with the original co-pilot data and the pgps data, both of which are running at the same time
24.041 (01 Apr 26)
