| Author |
SRMoll Occasional Visitor
Joined: Mar 11, 2006 Posts: 45 Location: London, U.K.
Posted: Thu Sep 20, 2007 1:12 pm Post subject: Handle Bar Mounted of i3 |
This is probably an old, old topic that has been covered a thousand times. I've had a search and discovered that some enterprising members had made various adapters and mounts for the i3 over the years, but these are all gone, used up or the links go nowhere now.
However, I would like to clip the i3 to my motorcycle every now and then, and was wondering if there were any options still available?
| Back to top |
welshgasman Regular Visitor
Posted: Sat Sep 22, 2007 8:13 pm Post subject: |
I got mine last year from a Mr Gonzales, not sure if he frequents this forum any more.
Basically you need a 17mm ball mount (I believe it is 17mm).
He made one for my bicycle, which I then transferred to my motorbike.
Search for him and try a PM to him. He also used to sell them on Ebay, but also seems to have stopped.
If you have a windscreen, I seem to recall someone used that with a lanyard, just in case it came off.
This also exists http://www.mountguys.com/ProductDetails.asp?ProductCode=RAM-B-149Z-GA22&click=21 |
| Back to top |
Posted: Tue Sep 25, 2007 5:52 pm Post subject: |
| Unfortunately Mr Gonzales has shut up shop, and no longer makes the adapters. So I'm going to have to continue looking. Gonzales does say on his website that alternatives might be to get another suction cup mount and cut it up. He also suggested RAM Mounts, but I don't think they do much for the i3 now either. |
| Back to top |
Darren Frequent Visitor
Posted: Tue Sep 25, 2007 6:36 pm Post subject: |
| SRMoll wrote: | | Unfortunately Mr Gonzales has shut up shop, and no longer makes the adapters. So I'm going to have to continue looking. Gonzales does say on his website that alternatives might be to get another suction cup mount and cut it up. He also suggested RAM Mounts, but I don't think they do much for the i3 now either. |
RAM do a specific i3 Mount linked above, Part Ni. RAM-B-149Z-GA22 with a U-Bolt attachment.
You can order these in the UK from GPSW. _________________ Darren Griffin |
| Back to top |
cantgetlost Frequent Visitor
Posted: Wed Sep 26, 2007 8:59 am Post subject: |
http://www.knobs.uk.com/ourrange-B0-ballknobs.php
I got an 18 mm ball from the above with M6 thread and Loctite'd it on to the thread.
Using "production" (sand paper) for rubbing down car paint work with care it took a short times to reduce the ball to a 17 mm tight fit with less smooth finish so the satnav does not swivel about or drop off. Long M6 thread just bolts in place of a fairing screen bolt.
I think the postage was more than the ball!
| Back to top |
gilesme Regular Visitor
| Back to top |
Posted: Wed Sep 26, 2007 6:52 pm Post subject: |
| cantgetlost wrote: | http://www.knobs.uk.com/ourrange-B0-ballknobs.php
I like this idea, thanks. |
| Back to top |
Posted: Wed Sep 26, 2007 6:54 pm Post subject: |
Is that a Nuvi 250?
If so does the Nuvi product line use the same mounting mechanisms and ball size as the good ol' i3? |
| Back to top |
Posted: Wed Sep 26, 2007 6:57 pm Post subject: |
Oh! Well! I just had a look at the Knobs-uk site, they have 16mm balls and the next size up is 20mm. There isn't an 18mm ball.  |
| Back to top |
Posted: Wed Sep 26, 2007 8:51 pm Post subject: |
According to our invoices you are right, height is 18mm.
With the ball screwed to the M6 thread and put it in a batterry drill and took it down on the production paper. Its still works fine two years on! |
| Back to top |
Posted: Thu Sep 27, 2007 8:48 am Post subject: |
Yeah, sorry, Nuvi 250 (not widescreen).
The in-box windscreen mounts plus the additional friction mount fit either my i3 or my Nuvi 250.
On this basis, I reckon it should work.
Can you post back here if it does - think I might get one next year for holiday in France. |
| Back to top |
| Back to top |
Mr_Gonzales Regular Visitor
Joined: Oct 05, 2005 Posts: 123 Location: Mmm...medway
Posted: Fri Dec 12, 2008 10:09 pm Post subject: |
| SRMoll wrote: | Oh! Well! I just had a look at the Knobs-uk site, they have 16mm balls and the next size up is 20mm. There isn't an 18mm ball.  |
Have faith, young Padouin
Website is back up at http://www.mounts.pwp.blueyonder.co.uk/
Only the black plastic balls this time, but with those you can make up whatever you need. |
| Back to top |
| Back to top |
