Pocket GPS World :: View topic - Spoken POI alerts for TomTom GO, Mobile, PocketPC and Palm
Goto page Previous  1, 2, 3 ... 68, 69, 70, 71, 72, 73  Next
Mick_1959
PostPosted: Wed Oct 03, 2007 10:04 pm    Post subject: Reply with quote
Mike
Thanks for the advice. Not sure of sample rates, but I converted wav files to ogg and they seem to work well.
Now the only thing I miss from old satnav is the large visual warnings as well as spoken ones for Speed cameras, any one know if it is possible to make the warning icons bigger?
PostPosted: Thu Oct 04, 2007 12:00 am    Post subject: Reply with quote
Nope, sorry. That is hard-coded into the software, and AFAIK no-one has ever hacked it.
Mick_1959
PostPosted: Thu Oct 04, 2007 8:10 am    Post subject: Reply with quote
Thanks for the info, Andy.
Also, can any one help with following:
I am pleased with my TomTom 720 so far, but I would like to have two warnings when approaching certain types of safety camera.
Is there any software like Checkpoint that can be used on the 720 to achieve this.
Sorry if this has been answered before, but have tried searching (maybe I am lacking in grey cells as I approach 48 years), but could find no answer
PostPosted: Thu Oct 04, 2007 9:41 am    Post subject: Reply with quote
You could try the approach shown in This Post.
TT Via 135 App 12.075: Europe Map v1165
Mick_1959
PostPosted: Thu Oct 04, 2007 10:40 am    Post subject: Reply with quote
Oldboy, thanks for the help.
Mick
Go 1005 in need of resuscitation
GO 950 Dead,
GO 920 Dead
Mick_1959
PostPosted: Sun Oct 07, 2007 5:02 pm    Post subject: Reply with quote
Oldboy, anf ror others wanting two warnings for safety cameras, I have discovered a simpler way to have two warnings than that suggested above.
Download and use Camera manager V2.5 by Ash10.
You get some nice icons, and if you enable each of the new icons in POI's, as well as the safety cameras, you set each of them at a different distance and give then a different warning if you require.
This also saves on doubling up on the number of POI's, saving precious space.
Ash10, a donation will be on its way.
If the above works for you, please donate to Ash10 to.
Mick
GO 950 Dead,
GO 920 Dead
JockTamsonsBairn
PostPosted: Mon Oct 08, 2007 3:56 pm    Post subject: Reply with quote
Presuming that you are talking about your TT720, are you getting 2 warnings from the PGPSW database or are you using it in combination with the TT database, and getting 1 from each?
Jock
PostPosted: Mon Oct 08, 2007 4:09 pm    Post subject: Reply with quote
I was wondering that...
If you look at the help file for Ash's utility, it seems to say the double warnings setup is only for Garmins.
JockTamsonsBairn
PostPosted: Mon Oct 08, 2007 6:49 pm    Post subject: Reply with quote
Presuming that the version of v2.5 that I've got is the same version of v2.5 that Mick's got, then I couldn't see a way that it could be done (for TT) in the software. I also don't know of any way it can be done on my TT, but given what you've just found out about the TT cameras ... Exclamation
Jock
Mick_1959
PostPosted: Tue Oct 09, 2007 11:07 pm    Post subject: Reply with quote
No, I have taken off TomToms Speedcameras, and yes I have a TT 720
I only have the PGPSW Speedzoned database and Ash's Utilty.
I found I was only getting one warning with the PGPSW database for each camera location and was about to follow the advise doubling up on camera POI's, but decided to download Ash's utilty first.
When I used Ash's program, which added his icons to the POI's.
I was checking my POI's to see what was added and I noticed his Icons were not enabled.
So I enabled them and out of curosity gave then a different sound file and at a different distance hey presto, two warnings
Hope this helps
Mick
GO 950 Dead,
GO 920 Dead
JockTamsonsBairn
PostPosted: Tue Oct 09, 2007 11:28 pm    Post subject: Reply with quote
Hope this helps
I think you'll find that you have 2 copies of the PGPSW files loaded, with different names.
Humour me and have a look at the following
BGF wrote:
Andy_P2002 wrote:
I'd suggest your next step is to download this little utility, DriveZ
This will enable you to make a list of all the files inside your map folder, which you can then paste here, so we can have a look. Saves a lot of time and guesswork.
Make sure you have UNticked the "Remove extensions" box before you click the big button to make the list in the right-hand window.
Post your results up here and hopefully all will be revealed...
I'd suggest that you make the mask "*.OV2".
If you run that, it will create a list of the OV2s that you can post back here.
Jock
Mick_1959
PostPosted: Wed Oct 10, 2007 10:08 pm    Post subject: Reply with quote
Following is a list with OV2 extension
ATM.ov2
CA7311.ov2
CA7313.ov2
CA7314.ov2
CA7321.ov2
CA7322.ov2
CA7337.ov2
CA7352.ov2
CA7373.ov2
CA7377.ov2
CA9373.ov2
CA9377.ov2
Car Parks & Garaging.ov2
Cinemas.ov2
Coffee_House.ov2
Food_&_Drink.ov2
Fuel.ov2
Heritage_Site.ov2
Hotels.ov2
Little_Chef.ov2
London_Congestion_Charge.ov2
London_Underground.ov2
National_Trust-UK.ov2
Parking.ov2
Pharmacy.ov2
PocketGPS_UK_Gatso.ov2
pocketgps_uk_gatso_20.ov2
pocketgps_uk_gatso_30.ov2
pocketgps_uk_gatso_40.ov2
pocketgps_uk_gatso_50.ov2
pocketgps_uk_gatso_60.ov2
pocketgps_uk_gatso_70.ov2
pocketgps_uk_gatso_tba.ov2
pocketgps_uk_gatso_var.ov2
PocketGPS_UK_Mobile.ov2
pocketgps_uk_mobile_20.ov2
pocketgps_uk_mobile_30.ov2
pocketgps_uk_mobile_40.ov2
pocketgps_uk_mobile_50.ov2
pocketgps_uk_mobile_60.ov2
pocketgps_uk_mobile_70.ov2
pocketgps_uk_mobile_tba.ov2
pocketgps_uk_pmobile_20.ov2
pocketgps_uk_pmobile_30.ov2
pocketgps_uk_pmobile_40.ov2
pocketgps_uk_pmobile_50.ov2
pocketgps_uk_pmobile_60.ov2
pocketgps_uk_pmobile_70.ov2
pocketgps_uk_pmobile_tba.ov2
pocketgps_uk_pmobile_var.ov2
PocketGPS_UK_Redlight.ov2
PocketGPS_UK_Specs.ov2
pocketgps_uk_specs_20.ov2
pocketgps_uk_specs_30.ov2
pocketgps_uk_specs_40.ov2
pocketgps_uk_specs_50.ov2
pocketgps_uk_specs_60.ov2
pocketgps_uk_specs_70.ov2
pocketgps_uk_specs_tba.ov2
PocketGPS_UK_Temp.ov2
Pub.ov2
Shopping_-_Supermarkets_etc.ov2
Theatre.ov2
The following are the files added by Ash's utilty that I have enabled and I also get a 1st warning from them.
The other pois e.g. pocketgps_uk_gatso_30.ov2, i set at distance to get a 2nd warning and different warning sound.
I do not know if this throws any light on how it occurs on my TT720, but I originally downloaded the speed zoned database first onto my TT 720.
I then discovered and downloaded Ash's utilty, and put it to work.
and yes, when the latest database was released Ash's utility updated the files .
Mick
GO 950 Dead,
GO 920 Dead
PostPosted: Thu Oct 11, 2007 12:56 am    Post subject: Reply with quote
Bingo!!
The above shows you have both the "consolidated by type" AND the "speedzoned" versions of the database installed. That's why you are getting two warnings.
They might have got added when you installed Ashes utility, but you don't need to have it and the utility isn't actually doing the double warnings, you could have just downloaded both types yourself (as per Oldboy's link in his post on the 4th).
JockTamsonsBairn
PostPosted: Thu Oct 11, 2007 10:36 am    Post subject: Reply with quote
Andy_P2002 wrote:
Bingo!!
Thumbs Up
Jock
PostPosted: Thu Oct 11, 2007 12:49 pm    Post subject: Reply with quote
One final thought... If the extra "consolidated by type" database files were automatically installed by Ash's utility, I wonder how up to date it is?
Page 69 of 73
24.041 (01 Apr 26)
