| Author |
zippybits Occasional Visitor
Posted: Tue May 01, 2007 9:03 am Post subject: NAVMAN Traffic Module T1 TMC Receiver BASIC GUIDE for Dummys |
OK you have got your navman and also a TMC T1 Module
Like me all excited that your going to get all your traffic updates to run to your car plug it in and ....... you guessed it DONT WORK, if your very lucky you might get it working about once a month,
Answer - The Aerial is quite franky as useful as a choclate teapot.
Solution - yep involves yet more money due to Navman's bad design which is a same as I like there Products I have a N60i anyway this is what you need, you may get the parts cheaper but at end of day this appears to work, just copy and paste links for the bits and order.
Part 1 of 2 required
Buy a Garmin MCX to BNC Adaptor Cable, #010-10121-00 - eXpansys UK
http://www.expansys.com/p.aspx?i=100140
This is about £16 quid of hard cash for a stupid cable but you need it to connect to your T1, buy the way incase you diddn't know MCX means Micro Co-axle
Part 2 of 2 Required
Miniscan Mobile Antenna
http://www.maplin.co.uk/Search.aspx?criteria=QT30H&source=15&SD=Y
Again £14.99 plus postage, But it appears to be the sensable DIY solution to the problem for Mr. DIY no hassle like myself, Maybe Navman will read this and take notice and sort out there own problems before there customers have to take matters into there own hands.
Come on Navman, you can to better than this, you make good GPS units sort your T1 modules out!!!
Hope this helps all the normal people like me,
Adrian
zippybits@aol.com
[url][/url][url][/url] |
| Back to top |
Posted: Tue May 01, 2007 9:25 am Post subject: |
Welcome to the forum, you are quite correct to use an external aerial, at least you have this as an option, not many RDS-TMC units have a socket.
For what its worth I am currently using a T1 and have green TMC box around Preston on the M6 (aerial as supplied) so it does work, but is much improved if connected to external feed.
A cheaper option is to connect it to the existing car aerial via a spitter lead, you can get the bits from CPC to make one - Mike |
| Back to top |
edwards_skin Occasional Visitor
Posted: Tue Aug 21, 2007 12:05 pm Post subject: Similar issues... I thnk??? |
I also have a N60i with the T1 module. (Supplied aerial attached and installed at the highest point in the car window) I accept that the best solution would be an external aerial, but have a basic question first. I am not getting a signal in the Nottingham area.
The User guide for the T1 shows a screen shot of the Traffic System status screen, where it is displayed that the tuner is tuned to Classic. is this something that is displayed when a signal is recieved? or is it something that you can set manually or scan for? |
| Back to top |
gtarling Occasional Visitor
Posted: Sun Aug 26, 2007 8:10 pm Post subject: |
| Has anyone tried an internal, amplified aerial, such as item 250157746981 on Ebay? I'm keen to get my T1 working properly, but don't want an external aerial and I'm not very keen on fitting a splitter to my existing radio. |
| Back to top |
Posted: Sun Aug 26, 2007 8:21 pm Post subject: |
| Assuming the unit you are looking at on e-bay does work efficiently at the lower frequency of its claim 48,5 to 223 MHz then it should offer an improvement but what do you intend to do with the associated wiring and aerials? - it doesn't look anywhere nearly as effective as either the mini scan or sky scan mag mount external aerials from Maplins? - both these products from Maplins are known to work very well with the T1 RDS-TMC unit - Mike |
| Back to top |
Posted: Mon Aug 27, 2007 12:10 pm Post subject: |
| Mike - Thanks for your opinion. I really don't want any form of external aerial on my car, which is why I was looking at the internal type. I've now found that Pioneer make a AN-TMC1 amplified antenna for use with all TMC systems - it's £25, so am going to phone a dealer tomorrow and try to find out a bit more about it - there's no details that I can find on the Pioneer website. As for fitting it, I'll either fit it on the left side of the windscreen or on one of the rear side windows (estate car), whichever works best. The wiring is easily concealed either under trim or carpets. |
| Back to top |
johncarnie Occasional Visitor
Posted: Wed Sep 12, 2007 2:07 pm Post subject: |
I managed to find this unit - Navilock Car-aerial splitter (DIN-ISO connector) for GPS-TMC-Sirf3 from cartft for my Navman F50 - took 5 mins to fit - and picked up TMC Classic FM immediately (with the OE Navman - only limited reception). It's a tad expensive - it is shipped from German
http://www.cartft.com/catalog/il/671
Edited by Tim to correct URL. |
| Back to top |
keithjeffrey Lifetime Member
Joined: Apr 07, 2006 Posts: 249 Location: Kent , England
Posted: Wed Sep 12, 2007 6:22 pm Post subject: |
| johncarnie wrote: | I managed to find this unit - Navilock Car-aerial splitter (DIN-ISO connector) for GPS-TMC-Sirf3 from cartft for my Navman F50 - took 5 mins to fit - and picked up TMC Classic FM immediately (with the OE Navman - only limited reception). It's a tad expensive - it is shipped from German
[/url]http://cartft.com/catalog/il/671[/url][/url] |
That is a neat looking bit of kit !
Would it work with a Navman F20 do you know ? _________________ Keith
TomTom GO 730T App 8.392 (1909/091109) , W and CE 2GB v835.2419 |
| Back to top |
Posted: Sat Oct 06, 2007 5:04 pm Post subject: |
| It works on my F20 |
| Back to top |
| Back to top |
