| Author |
Mick_1959 Lifetime Member
Joined: Sep 24, 2007 Posts: 247 Location: Cambridgeshire
Posted: Thu Oct 11, 2007 5:40 pm Post subject: |
So Ash's utility did the trick, well, at least I did not have to rename any files. _________________ Mick
Go 1005 in need of resuscitation
GO 950 Dead,
GO 920 Dead |
| Back to top |
Andy_P Pocket GPS Moderator
Posted: Thu Oct 11, 2007 5:50 pm Post subject: |
You wouldn't have had to anyway...
My point above yours though, is that since they started charging for it, PGPSW have not been allowing the database to be distributed by others except under licence. So the database that Ash's utility seems to have installed could be 18 months out of date. (This is what was happening with POI Edit's automatic update system too).
As you're already subscribed to the speed cams (in order to get the speed-zoned set), you should re-download the consolidated one direct from PGPSW every time too. |
| Back to top |
JockTamsonsBairn Lifetime Member
Posted: Thu Oct 11, 2007 10:38 pm Post subject: |
| Andy_P2002 wrote: | You wouldn't have had to anyway...
As you're already subscribed to the speed cams (in order to get the speed-zoned set), you should re-download the consolidated one direct from PGPSW every time too. | I suggest that you read up on Ash10's utility. It is downloading the most recent version. You have to log in to the site 1st.
@Mick_1959:
Just remember that when Ash10's util tells you that the next download is available, you'll need to update both! _________________ Jock
TomTom Go 940 LIVE (9.510, Europe v915.5074 on SD & 8.371, WCE v875.3613 on board) |
| Back to top |
Posted: Fri Oct 12, 2007 7:12 am Post subject: |
BGF - Thanks for the tip _________________ Mick
GO 950 Dead,
GO 920 Dead |
| Back to top |
Firebird Lifetime Member
Posted: Fri Oct 19, 2007 4:31 pm Post subject: |
Hello guy's
I currently have the newer data.chk file installed.
However, as I use gatso for all gatso's it frees up several alarms for poi's
I am wanting to edit some of the alarm sounds within the data.chk file.
can you advise me how you ammended the current alarms so I can amend/edit them to suit my requirements.
I am running TTmobile APP Version 5.000
Which means I am using (419)
Thanks everybody |
| Back to top |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10645 Location: Suffolk, UK
Posted: Fri Oct 19, 2007 5:45 pm Post subject: |
See if this thread can be of any use to you.
Try a Search for 'viftool'. Try Google as well. _________________ Richard
TT Via 135 App 12.075: Europe Map v1165 |
| Back to top |
Posted: Fri Oct 19, 2007 6:06 pm Post subject: |
| vif tool is for splitting dataXX.chk files which are the nav voives and sounds, the data.chk file used to be split / modified using a PC application called POIExtend, but this only supports Pocket PC and Go style devices, I have never seen anything to take appart the data.chk file and swap out the individual sounds (short of using a Hex Edit program and quite a lot of work) - Mike |
| Back to top |
theboneman2 Occasional Visitor
Posted: Sat Nov 17, 2007 8:59 pm Post subject: voice n not beep |
| can anyone assist me do this with the tomtom one! I have the newer version but cant seem to work out what and how to do it. Not that computer whizz either |
| Back to top |
Posted: Sun Nov 18, 2007 2:09 pm Post subject: |
Are you following the instructions HERE to the letter?
If so, where is it going wrong? |
| Back to top |
Posted: Sun Nov 18, 2007 4:39 pm Post subject: |
| IF it's a One Third Edition there is a slight change, there is no Manage POI in the menu, there is ''Warn when near POI'' it is on page two IIRC you should use this to set up the camera warnings - Mike |
| Back to top |
Posted: Sun Nov 18, 2007 10:16 pm Post subject: help |
| followed the instructions to the letter! how do I try it out to see if it works.....wifes got the car |
| Back to top |
Posted: Mon Nov 19, 2007 12:57 am Post subject: |
Find a camera or two on the map.
Set up an "A-B Prepare route" (what used to be called "Advance plannng") from a few hundred yards before the camera to a few hundred yards after it using the "from map" option to select start and end points. Once it has calculated the route, tap "details" and set it to run a "demo" of the route (keep below 300% speed in order to hear the alerts). |
| Back to top |
Posted: Mon Nov 19, 2007 6:41 pm Post subject: |
| Andy_P2002 wrote: | Find a camera or two on the map.
followed instructions took it in the lorry with me today no sounds no spoken words headache |
| Back to top |
sayed Occasional Visitor
Posted: Mon Mar 10, 2008 3:20 am Post subject: |
hey, new to this forum. i have the gatso camera POI files which work, and i tried to add the new voices. my tomtom version is 6.021(8120) and i am using it on my SE P990i. i couldnt find the data.chk file so the new voices work on here. is there anywhere i can get it from??
thanks
sayed |
| Back to top |
Posted: Mon Mar 10, 2008 10:40 am Post subject: |
Hi Sayed.
The first post in this (very) long topic says:
| Quote: | | Please note that the data.chk file replacement method is no longer supported for all versions of Navigator EXCEPT TomTom Mobile 5. |
The new method is to use the individual sound files found HERE
Have you tried that?
Give us a shout if you have any problems. |
| Back to top |
| Back to top |
