| Author |
JessopSmythe Occasional Visitor
Posted: Mon Sep 25, 2006 12:03 am Post subject: Where can I get more maps? |
I'm running MM v5 OS and I'm looking for maps of Corfu. The OS versions of MM don't allow you to scan and calibrate your own maps so it seems as if I have two options.
1) Buy MM Europe which will allow me to scan and calibrate
2) Try and locate calibrated maps of the Corfu area at a sensible price.
Any suggestions as to where I can get the maps at a sensible price? |
| Back to top |
MrT Frequent Visitor
Joined: Nov 14, 2003 Posts: 2146 Location: Surrounded by A1, M1 & M25
Posted: Mon Sep 25, 2006 4:19 pm Post subject: |
| You do not need to buy MM Europe or MM USA and these products (not tried Europe) will work with you serial but just won't let you use OS maps. They will install to a different directory so you can have both on your PC at the same time. I have used this to calibrate high res aerial photography. These maps will then work with the OS version. |
| Back to top |
G1LIW Lifetime Member
Joined: Jun 19, 2006 Posts: 212 Location: Sahrf Lunnon ;)
Posted: Tue Oct 30, 2007 1:47 am Post subject: |
OK, may be the time of night, but Mr T, you just confused the wotsit out of me!
Are you saying that MM v5 UK CAN use maps from other sources - even scanned maps? if so, can you type up a "how to" guide for us, please? |
| Back to top |
JasonMM Occasional Visitor
Posted: Tue Oct 30, 2007 11:27 am Post subject: |
| G1LIW wrote: | OK, may be the time of night, but Mr T, you just confused the wotsit out of me!
No, you can only scan and calibrate maps using the Memory-Map European Edition which you can download from www.memory-map.co.uk and activate it with your existing OS Licence details |
| Back to top |
mhb Regular Visitor
Posted: Wed Oct 31, 2007 5:51 pm Post subject: |
| Just to clarify further, I believe that the scanned in maps from MM European Edition, can then be used in MM OS? |
| Back to top |
robertn Frequent Visitor
Posted: Thu Nov 01, 2007 2:16 am Post subject: |
Before you go ahead, consider the problem with self calibrated maps - how much work involved in doing it, how accurate will it be, and if it is wrong, can you correct it in the feild.
I played around with doing it and gave up and solved the problem with money - maybe you are more accruate and patient than me. |
| Back to top |
| Back to top |
