		| Author | Message |
		| p3nz Occasional Visitor
				|  Posted: Wed Apr 07, 2004 2:04 am    Post subject: memory map functions question |   |
				| First of all hello
 I have been looking at memory map A-Z street maps for a way of mapping out wifi hot spots in my local area and i know that this is not what the software is intended for but from reading about this program i feel that it would be ideal :D
 I would be looking to run the map on my ipaq with a node scanner running in the background and as the scanner found a hot spot i want to be able to mark the postition on the map for later edits on my pc.
 so now for the questions
 can i do  this with memory map A-Z?
 is there another pda app out there that i could do this with?
 Would the A-Z vers work well with a portable bluetooth gps device and is there any way of exporting the mm maps out to another format (jpeg,gif etc) as i may want a way of publishing the data recorded to non mm users.
 Thanks for any advice given
 P3
		| Back to top |  |
		| Oldie Pocket GPS Moderator
				|  Posted: Wed Apr 07, 2004 8:52 am    Post subject: |   |
				| You can mark a location on an A-Z map in the same way as on a topographical map and then the marked locations can be exported and made available to other users. I usually use the Maptech export format with Memory-Map and convert to other formats using my POIConverter program (look in Downloads | POI Icons and Converters | PC).
 How does your hotspot scanner show a node position to you? I have never seen one so I am interested to find out.
		| Back to top |  |
				|  Posted: Wed Apr 07, 2004 10:29 am    Post subject: |   |
				|  	  | Oldie wrote: |  	  | How does your hotspot scanner show a node position to you? I have never seen one so I am interested to find out.
 the scanner i am using at the moment has a rather good gui which gives off information relating to signal strength,wep on/off, internet access availabilty and ip info and more! all you need to do is listen for an audio alert as you are out and about.
 Problem being i am finding more than i thought i would and i am quicky loosing track of where they are and which one's are open or closed.
 Have a look at the software here
 Thank you for your help on this one and it looks more likely that i'll be buying mm especially since i am going into town today!
		| Back to top |  |
				|  Posted: Wed Apr 07, 2004 11:21 am    Post subject: |   |
				| I see that Chris Devereaux has compiled a list of Wireless Hotspots, 1889 of them around the country. These are available for download on this website. Look under GPS Central | Points Of Interest.
 You can use my POIConverter program to create a Maptech MXF file from the TomTom Navigator OV2 file.
 Thanks for the link to the software. I will have a look at it
		| Back to top |  |
				| ![]() Posted: Today    Post subject: Pocket GPS Advertising |  |
  Have you considered making a donation towards website running costs ?. Or you could disable your ad-blocker for this site. We think you’ll find our adverts are not overbearing!
		| Back to top |  |
