Pocket GPS World :: View topic - Muting Voices but NOT Alerts!
Davebravey
PostPosted: Tue Nov 20, 2007 5:59 am    Post subject: Muting Voices but NOT Alerts! Reply with quote
I work in the building trade, so I tend too be at the same location for awhile and I am looking for a way too mute the voices on route but keep the active alerts going (speed cams etc). Anyone have any info on this?
PostPosted: Tue Nov 20, 2007 7:59 am    Post subject: Reply with quote
You don't say if you will have the route selected.
If the route is being used/displayed there used to be a 'silent voice' but I'm not sure if it is still available.
If you don't need the Route Guidance displayed you can select Clear Route and just set up Warn when Near by unticking the Warn only if on Route Option on the last screen.
TT Via 135 App 12.075: Europe Map v1165
PostPosted: Tue Nov 20, 2007 11:28 am    Post subject: Reply with quote
On the x20 models (and maybe other models on v7 software) there is a menu option to "disable voice" which leaves the alerts still sounding (unless you've used text to speech for your alerts too!)
This DIDN'T work on v7.0xx (the icon was there but it didn't do anything with TTS voices), but seems to have been fixed in v7.210.
PostPosted: Tue Nov 20, 2007 1:11 pm    Post subject: Reply with quote
I can't find that option on 7.161
How did you get to it? I'm using the ogg files.
PostPosted: Tue Nov 20, 2007 2:53 pm    Post subject: Reply with quote
Its in 'Change prefs' / 'Voice prefs' / 'Disable voice' on mine, Richard. Smile
PostPosted: Tue Nov 20, 2007 3:26 pm    Post subject: Reply with quote
I don't get Voice Prefs, only Change Voice. Confused
PostPosted: Tue Nov 20, 2007 3:54 pm    Post subject: Reply with quote
Another difference for the list then!
Musketter
PostPosted: Wed Nov 21, 2007 7:02 pm    Post subject: Reply with quote
There still is a silent/blank voice going around.
Try Here - http://www.gpsice.co.uk/silentvoice.html
By choosing this one you get all the displays coming up, but no actual voice.
Hope this helps !
PostPosted: Wed Nov 21, 2007 10:22 pm    Post subject: Reply with quote
Well found!
I spent ages looking for that yesterday. All the links I found were dead.
PaulBt
PostPosted: Thu Nov 22, 2007 12:48 am    Post subject: Reply with quote
Hi what am I doing wrong:?: Question
I cannot get it to install this voice file, using Home ver 2.1.2.121
Then looking at the voice folder on the TT720 the file extension is not .rar as the download.
Paul
TT720 V8.010, regular audio book user.
WestEuro v805 connected to E90 on O2
TT910 V6.525, TTN5, TTN3, TT on Psion 5mx
PostPosted: Thu Nov 22, 2007 1:07 am    Post subject: Reply with quote
Don't use Home to install it.
It comes from the good old 'pre-Home' days!
Looks like you might need the WinRAR archiver to uncompress it (a bit like Winzip)
WinRAR is shareware. There is a time-limited free version available HERE
Once unzipped, just copy the files into your voices folder using Windows Explorer.
PaulBt
PostPosted: Fri Nov 23, 2007 12:07 am    Post subject: Reply with quote
Thanks Andy, thanks all,
That's much better.
PostPosted: Fri Nov 23, 2007 12:33 am    Post subject: Reply with quote
Andy_P2002 wrote:
Well found!
It's on my L Drive under a folder called Silent Voice - Data99 I think. I used it on 720 #6 before I discovered the Mute Voice option. Embarassed
24.041 (01 Apr 26)
