| Author |
1neil1 Occasional Visitor
Posted: Tue Dec 11, 2007 2:37 pm Post subject: trumpion-route 66 |
first of all hi guys and thanks for having me here just joined the site in search of some info into the world of sat navs
this is the unit i have just bought
http://cgi.ebay.co.uk/GPS-Sat-Nav-Euro-Map-speed-camera-Xmas-gift-Tom-1day_W0QQitemZ190182588747QQihZ009QQcategoryZ156954QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
sys info
rom version 17c.yf.3.q.1023
processor atlas111
software version v2.0.0.10.20
id 2dao48830000078a
software on sd card consists of folder named route 66 with sub folders help, lang,maps,pois,res,speechand tmc
can any body help me with cam updates map updates and voice change updates, cant see any voices on the sd card at all in the speech folder are .ogg files for poi sounds. very new to this so all help in basic terms would be greatly appreciated
regards neil.
sorry if this is in wrong place its my first time on here |
| Back to top |
Posted: Tue Dec 11, 2007 2:48 pm Post subject: |
Welcome to the forum, for Speed Camera installation to your device please have a read though This Thread, it is for the Pocket PC and PNA based devices running Route 66 so will work for your unit.
For custom voices things are not quite as easy, the spoken words are all lumped together in one single file, it is possible to split this open, substitute each spoken command with a replacement then stitch the single file back together again. It is very much a DIY job as there are no custom voice packs available as yet for Route 66, have a read of This Thread which explains how to swap out the voice files - if you do intend messing around like this please ensure you fully backup the sat navs memory card to the PC BEFORE you start - Mike |
| Back to top |
Posted: Tue Dec 11, 2007 3:32 pm Post subject: |
thanks mike for your reply, ive checked out the links but theres one thing i cant understand it says to drop the cams in folder britian i only have one folder named europe i assume this will be the same thing as its a europe map and not the brit one, the thing thats confusing me is in side the folder there is only the map no speed cams but yet the sat nav has picked up all the cams ive passed so far ? i cant find any folder with any cams inside them except the poi wich just has gasto 30-40-50 ect
neil. |
| Back to top |
Posted: Tue Dec 11, 2007 4:46 pm Post subject: |
Yes the folder will be POIS/Europe as you have Euro mapping on the device, Route 66 is supplied with a speed camera database as standard, I have never used it so I will not comment on how good or bad it actually is.
If you follow the instructions placng the POI files into the correct place you will be able to not only get visual warnings but true spoken alerts using the ogg files.
Various different types of ogg file sets exist to match the Pocket GPS World Speed Camera database, these can be downloaded for free from This Page - Mike |
| Back to top |
Posted: Tue Dec 11, 2007 7:45 pm Post subject: |
thanks mike that was a great help voice are now all set up, when you update cams what ecxactly are we updating possiton of cams or type of cams or somthing else as this device as come with redlight, gasto mobile,
average speed ect so not sure if it actually needs the cams updating but thanks for all your help m8 its made it a bit easier finding my way around it
regards neil. |
| Back to top |
Posted: Tue Dec 11, 2007 7:56 pm Post subject: |
| You probaly have both the speed camera database from Route 66 and Pocket GPS world on the unit, try disabling the R66 one or remove the files you suspect are R66 cameras, just copy them to the PC before deletion (just in case) - Mike |
| Back to top |
Posted: Tue Dec 11, 2007 8:16 pm Post subject: |
sorry m8 think you missunderstood the question i havent d/loadd cams from here but my satnav came with the above already on i was wondering if i or anybody for that matter updates the cams what exactly gets updated or what gets added should i say
neil. |
| Back to top |
Posted: Tue Dec 11, 2007 8:25 pm Post subject: |
As I said earlier I have no experiance of the Route 66 camera database, the only version I tried 18 months ago contained 2 cameras for the whole of the UK, the spooky part was one of them was at the end of the road I live on!
Perhaps someone else who has knowledge of the R66 update can assist at this point, but I would expect the update is similar to ours in that it just replaces the location data files with an updated set - Mike |
| Back to top |
Posted: Tue Dec 11, 2007 8:53 pm Post subject: |
ok mike no problem thanks very much for all your help its appreciated m8
neil. |
| Back to top |
gazgelder Occasional Visitor
Posted: Sun Oct 26, 2008 6:48 pm Post subject: Re: trumpion-route 66 |
hi sorry icant help with your questions,but you hay be able to help me i have just moved house and lost my backup cd that i made for my trumpion sat nav ,now my software has developed a fault and i cant fix it.is there any chance you could download your sd to a cd for me .if you can i am willing to pay you for it plus postage.please help if you can has i am lost without it amd cant afford to buy again.thanks lisa
| 1neil1 wrote: | first of all hi guys and thanks for having me here just joined the site in search of some info into the world of sat navs
sys info
processor atlas111
id 2dao48830000078a
regards neil.
| Back to top |
Posted: Sun Oct 26, 2008 7:51 pm Post subject: |
| Try to resolve this issue by contacting Trumpion, requesting copys of software from other users devices is against the rules of the forum - Mike |
| Back to top |
| Back to top |
