| Author |
anjomi Occasional Visitor
Posted: Sun Dec 30, 2007 10:46 pm Post subject: Does ONE XL have a NMEA interface? |
I have a ONE XL, and have been trying to connect to it and get data in NMEA format.
I've used Bluetooth Console (http://www.webazar.org/tomtom/bluetooth.php?lang=uk) to connect to it via Bluetooth, and this seems to work fine. However, I can't seem to get the ONE XL to transmit the NMEA data (by using the cat \dev\gpsdata\ command).
I've searched the web a bit, and have found some suggestions that the ONE XL doesn't have a NMEA interface, but some type of binary one. Does anybody know if this is true?
If this is true, it greatly limits what you can do with it, all the 3rd party software out there (such as GPS TrackMaker), uses NMEA to connect to GPS units.
Does anybody have an information about the new binary format and if any tracking/logging software out there can connect via it?
Thanks |
| Back to top |
lbendlin Pocket GPS Staff
Posted: Wed Jan 02, 2008 5:30 am Post subject: |
try this
/bin/sirfreset help _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
| Back to top |
stuart Frequent Visitor
Joined: 20/04/2003 11:51:10 Posts: 405 Location: Dorset, England, Great Britain
| Back to top |
| Back to top |
Posted: Wed Jan 02, 2008 10:39 pm Post subject: |
Stuart, that comment is for the x10, and it isn't true any more anyhow, TomTom changed the x10 back to NMEA after the Sirf desaster.
The One XL does indeed behave differently than all the others. Interesting _________________ Lutz
| Back to top |
| Back to top |
Posted: Thu Jan 03, 2008 10:41 pm Post subject: |
Thanks for the replies.
I've played around with sirfreset a bit, but it didn't seem to have an effect (However, I'm new to this game, and didn't really know what I was doing!). I think you are right that it has the Globallocate chipset, and therefore the sirf commands are no longer valid.
When I do run /dev/gpsdata and redirect the output to a text file, the file is full of garbage. I guess this indicates that it is outputting some type of binary file. I hoping there is a way to switch this to NMEA format, but I have no idea what the command would be.
Any idea if you can get a list on all the commands?
Anjomi |
| Back to top |
Posted: Thu Jan 03, 2008 10:54 pm Post subject: |
| anjomi wrote: |
can you please be a bit more precise? It's mostly busybox anyhow. _________________ Lutz
| Back to top |
Posted: Thu Jan 03, 2008 11:10 pm Post subject: |
Like I say, I'm new to this, so its a bit difficult to be precise.
I'm presuming that sirfreset was a command written by tomtom to control the SiRF chipset. I'm also presuming that they have written another function to control the new Hammerhead chipset.
What I want to know is how can I get a list of commands which are available. One of them may be the one to control the output from the new chipset.
Or maybe I'm just grasping at straws here...
Anjomi |
| Back to top |
Posted: Thu Jan 03, 2008 11:28 pm Post subject: |
well, go through the /bin folder and all the other folders and look for yourself. we're all chasing the black cat in the dark room. If you find something, let us know. _________________ Lutz
| Back to top |
Posted: Fri Jan 04, 2008 2:31 am Post subject: |
OK, I finally got it to work.
Once your are connected to the XL you need to run this command
cat /var/run/gpspipe
This then starts to stream out the NMEA data.
I got this info from here
http://web.tiscali.it/macri/Event_Logger/ReadMe1.htm
Anjomi |
| Back to top |
Posted: Fri Jan 04, 2008 2:38 pm Post subject: |
Glad to be of some use......  |
| Back to top |
katamara Occasional Visitor
Posted: Fri Jan 11, 2008 5:46 pm Post subject: |
would you have a direct link to download the software? I've looked all over the page and the software download link brings you to:
http://web.tiscali.it/macri/Event_Logger/Download.htm
which then has a link that brings you right back to the main page. |
| Back to top |
Posted: Fri Jan 11, 2008 6:29 pm Post subject: |
I guess he wants you to donate... _________________ Lutz
| Back to top |
| Back to top |
