| Author |
grossm Occasional Visitor
Posted: Tue Jan 08, 2008 5:17 pm Post subject: TTN6 Map Options |
| I've just purchased an HTC P3300 which includes TTN6 software, but just one free local map. I would like to get full USA maps. Am I limited to buying these from Tom Tom, or are there other map sources? What's my best (least expensive) option? Earlier version maps are OK. |
| Back to top |
Posted: Tue Jan 08, 2008 5:30 pm Post subject: |
| Shop around for the maps on disk, you might find a cheap deal somewhere, one US stockist can be found Here don't forget you will also need a micro SD crad to put the maps on, depending upon the ROM you have loaded to the P3300 (WM5 or WM6) and a small tweak you can run the larger 4GB cards on the phone - Mike |
| Back to top |
Posted: Wed Jan 09, 2008 2:37 pm Post subject: |
| Thanks. What's the tweak that allows me to use a 4GB card? I'm using WM6. |
| Back to top |
Posted: Wed Jan 09, 2008 9:46 pm Post subject: |
| You can find the CAB file for SDHC Here - I know at least two others that are using this on their MDA Compact - III devices (same as the Artemis but devoid of WiFi) - strange thing though my Artemis used the SDHC card without the CAB, so if you get one try it first it might just work - mine did - Mike |
| Back to top |
| Back to top |
