| Author |
loser40 Occasional Visitor
Posted: Fri Jan 11, 2008 1:41 am Post subject: Confused newbie... Which version ? |
Hi...
I have a HTC TyTN2 Pocket PC on Vodafone, with Tomtom Navigator 6, & Western Europe maps.
I'm not sure which version of the Safety Camera S/W to D/L.
I was going to download it from here http://www.pocketgpsworld.com/modules.php?name=Cameras&op=SelectPackage (this is the right page - yes?) but I'm offered 3 different versions.
They are; Consolidated Type, Single File, & Speed Zoned !
Which do I download ? ... and will it be a Western European version ??
In short, would someone who understands this process kindly post links and advice :)
TIA.
Mark. |
| Back to top |
Daggers Lifetime Member
Joined: Jun 20, 2005 Posts: 1096 Location: Solihull, UK
Posted: Fri Jan 11, 2008 10:13 am Post subject: |
If you read the bottom of the initial speed camera page (below the table of supported devices), there's an explanation of each version of the database.
If you want details of UK cameras, download the UK database for your selected option. If you want other european cameras IN ADDITION to UK cameras, then download the European database as well. However, if you don't drive on the continent, then I would argue that it isn't necessary to have the European database.
Also, note that if you decide on the speed-zoned version of the database, you will end up with many POI files which, depending on the TomTom version that you have, use up a significant propotion of your available quota of POIs - particularly if you decide on both UK AND European databases. |
| Back to top |
Andy_P Pocket GPS Moderator
Posted: Fri Jan 11, 2008 1:55 pm Post subject: |
Normally, the choice of version is down to your personal preference. Every version of the database has EXACTLY the same cameras in it, they are just divided up into different numbers of sub-sections fo people who want more information about camera type and speed. Also, some machines can only load ONE user file, so they are stuck with the simplest "all-in-one file" version.
On Navigator 6 you are allowed 100 maximum user-POI files.
The fully split up "speed-zoned" version of the database will use up 31 of those (or 24 if you leave off the optional un-confirmed "pMobile" files). |
| Back to top |
Posted: Fri Jan 11, 2008 3:02 pm Post subject: So Andy.... |
... Which set up would I need to download to have the all singing, all dancig 'best' speed camera alert settings ?
Also, could I install the basic all-in-one version and the bells and whistles version and preference the complete version & have the all in one as a.back up ?
Links and advicefor this newbie much appreciated.
TIA.
Mark. |
| Back to top |
Posted: Fri Jan 11, 2008 4:08 pm Post subject: Re: So Andy.... |
| loser40 wrote: | | ... Which set up would I need to download to have the all singing, all dancig 'best' speed camera alert settings ? |
Speedzoned... plus spoken warnings from HERE
| Quote: | | Also, could I install the basic all-in-one version and the bells and whistles version and preference the complete version & have the all in one as a.back up ? |
If you do, you will get two alerts for every camera (unless you set it up NOT to show on the map and NOT to "warn when near").
Some people do this deliberately, in order to get a warning some way away and another when you get nearer. (But it uses up yet more POI categories).
I assume you've seen the help file HERE? |
| Back to top |
Posted: Fri Feb 15, 2008 7:45 pm Post subject: PoiEdit Problem... |
Hi...
Thanks for all the sound advice previously posted.
Ive just D/L the PoiEdit application and an trying to set it up to auto-update...
...however, when I try configure this application Im having no luck 'cos the 'AutoUpdate Sites & Status' page ( http://www.poiedit.com/sites.htm ) states pocketgpsworld.com site is offline.
Is this a regular thing or a temporary blip ?
I really was hoping I could use this facility as an easy update method !
TIA.
Mark. |
| Back to top |
Posted: Fri Feb 15, 2008 7:53 pm Post subject: |
| The POIEdit method of updating POI files on your device is not supported by this web site, what you need to do is download the relevent file set, extract the files from the zip archive and copy/ paste the files to the map folder on your device - Mike |
| Back to top |
Posted: Fri Feb 15, 2008 8:16 pm Post subject: Not supported ??? |
Im surprised that you say that it isnt supported 'cos the application has a download link on this site which says otherwise.
Why say it is supported when it isnt... and why cant the site adopt this update method - it would be so much easier.
M. |
| Back to top |
Darren Frequent Visitor
Posted: Fri Feb 15, 2008 8:36 pm Post subject: |
We haven't supported POIedit for over two years now, it is incapable of functioning with our subscription system which creates files 'on the fly' from a master database.
I wasn't aware any links remained but if you can tell where where you saw it I'll remove it. _________________ Darren Griffin |
| Back to top |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10645 Location: Suffolk, UK
Posted: Fri Feb 15, 2008 9:42 pm Post subject: |
| Darren wrote: | | I wasn't aware any links remained but if you can tell where where you saw it I'll remove it. | I think he is referring to this -
Bottom of page. _________________ Richard
TT Via 135 App 12.075: Europe Map v1165 |
| Back to top |
Posted: Fri Feb 15, 2008 10:48 pm Post subject: |
Crikey, its hard enough maintaining our site without worrying about others!
I'll send them an email and ask to be removed  _________________ Darren Griffin |
| Back to top |
| Back to top |
