| Author |
jspencer Occasional Visitor
Joined: Dec 06, 2007 Posts: 30 Location: Brighton, MA, USA
Posted: Wed Jan 09, 2008 8:54 pm Post subject: |
| Andy_P2002 wrote: | Trust us...
We are NOT talking about software versions or GPS hardware. We are talking about how TomTom themselves refer to the devices privately (and how they are identified in Home).
The correct name for the latest model ONE is the "3rd Edition". It is categorically not a "v3" - that's just what people who don't know tend to call it. |
OK, point taken. But judging by the number of misuses of the term just in this thread, it would seem you have an uphill battle ahead of you. I, at least, will change my terminology.
Jon |
| Back to top |
Calomax Lifetime Member
Joined: Sep 30, 2005 Posts: 988 Location: St Martin's, Guernsey
Posted: Thu Jan 10, 2008 9:17 am Post subject: |
Thanks all for the advice. I think I'm a little less confused now. To get a One with an SD slot I have to get any that is not called a 3rd edition. The difficulty there is that most of the online retailers are not calling it 3rd edition either and, living where I do, I can't just go into a store and look at one.
I might just stick to Navigator 6 until I can afford a Go. Assuming that TT doesn't do away with the SD slot in those.  _________________ TT Go Essential |
| Back to top |
Andy_P Pocket GPS Moderator
Posted: Thu Jan 10, 2008 10:46 am Post subject: |
| jspencer wrote: | ...judging by the number of misuses of the term just in this thread, it would seem you have an uphill battle ahead of you. I, at least, will change my terminology.
Jon |
Totally agree with you there!
I had an email flyer from Maplin or CPC yesterday offering several different "V3" packages.
Of course it doesn't really matter UNTIL, people ask for help in a forum such as this, where much time gets wasted working out exactly what model someone has, before you can start trying to help.
In the good old days, all TomToms worked pretty much the same except for obvious differences like whether you had text-to speech or not; but now it's a different kettle of fish! Knowing what actual model is being discussed gets pretty important and many people DO refer to the "V" numbers as reported by Home. |
| Back to top |
franb Banned
Posted: Thu Jan 10, 2008 3:01 pm Post subject: |
| Just go for a One XL as they all come with an SD slot. |
| Back to top |
moofoo Occasional Visitor
Posted: Thu Jan 10, 2008 6:23 pm Post subject: Favourites question |
Just a quick question...
I used to have a Pocket PC (iPAQ) with TomTom Navigator 5 software but this has since broken so I can't use it any more. It used to really annoy me that it was only capable of saving 20 favourite locations on it. I am now thinking of getting a TomTom One V3 as a replacement and wondered if someone could tell me how many favourites you can store on it?
Many thanks in advance,
Nick |
| Back to top |
Posted: Thu Jan 10, 2008 7:44 pm Post subject: |
48 is the limit for favourite locations, although I would use a custom home made POI file to store locations, this way you can have thousands of location.
When I say "Home Made" I don't mean using TomTom Home software, I thought this should be pointed out - just create a POI category on the device and add the locations to it - Mike |
| Back to top |
Posted: Fri Jan 11, 2008 12:58 pm Post subject: |
| Thanks for getting back to me so soon Mike. That sounds really good and I think I will treat myself to a new TomTom unit!!! |
| Back to top |
Posted: Fri Jan 11, 2008 3:23 pm Post subject: |
| Maybe try for a One XL rather than a "3rd Edition"? |
| Back to top |
snarf Occasional Visitor
Posted: Thu Feb 07, 2008 5:59 pm Post subject: |
| Has anyone made any progress on recovering the help options via the custom menu? |
| Back to top |
Posted: Fri Feb 08, 2008 1:26 am Post subject: |
| I remember reading that someone with more brains than most had hacked into the system deep enough to see all the menu codes and there was NO mention of the Help Me and Map Correction items, so they are coded in a totally different way, not through the .mnu |
| Back to top |
Posted: Fri Feb 08, 2008 2:39 am Post subject: |
| Andy_P2002 wrote: | | I remember reading that someone with more brains than most had hacked into the system deep enough to see all the menu codes and there was NO mention of the Help Me and Map Correction items, so they are coded in a totally different way, not through the .mnu |
That was actually in the first message of this thread. I suspect that snarf was wondering if, in the intervening 5 months, someone had found the magic cookie that got one past that roadblock. It sounds like the answer is no.
Jon |
| Back to top |
Posted: Mon Feb 18, 2008 8:26 pm Post subject: |
I have to revise my previous message. While nobody has found a way to have both the custom menu and the original Help Me and Map Correction menu items simultaneously, someone has created a program to switch between the two on the fly using just the TomTom menu, without connecting to a computer.
The program is called MenuTT and is located here:
http://www.tomtomheaven.com/index.php?option=com_content&task=view&id=325&Itemid=29
This page is in French, but not to worry, when you download the program you find that there is a Read Me file in English, which explains how to install and use the program.
There are a couple of items that deserve explanation:
1. There is a folder called icones_optionnelles. In English, this is optional icons and it's just what it says. You can use these icons instead of the default ones. Make sure you put the optional ones in the right place -- the two icons go in different folders. There is also an optional sound file (the program plays a short sound file at the switch).
2. When the switch occurs there is a delay of about 10 seconds and the TomTom goes back to the Legal Notice screen. You lose any planned routes you had running in the process.
3. In the documentation he says he will let you find the icon to get back to the custom menu. Here's a hint -- open the PDF in the optional icons folder.
Jon |
| Back to top |
vinniet Occasional Visitor
Posted: Sat Feb 23, 2008 2:35 am Post subject: |
Hello ... I tried the TTMenu and could not get it to work. I want to have it switch from my custom menu to the original TT one. I would think this could be simple to setup.
If anyone got this working, please let me know how. |
| Back to top |
Posted: Sat Feb 23, 2008 2:52 am Post subject: |
| vinniet wrote: | Hello ... I tried the TTMenu and could not get it to work. I want to have it switch from my custom menu to the original TT one. I would think this could be simple to setup.
Worked for me. What did it do, if anything?
Remember, since you have to modify the menu to get the custom menu, you also have to modify the menu again to see the TTMenu icon.
Jon |
| Back to top |
guru-cat Occasional Visitor
Posted: Thu Feb 28, 2008 1:20 am Post subject: What a pitty |
Please inform me if someone finds the way to keep the existing menu of TomTom ONE Third Edition Europe Version 7.166, just adding Itinerary planning & Manage POIs
And keeping TomTomSafety Cameras, Map corrections & Help me.
I don't understand why you are unable to do it if you did a menu of 8 pages!!
I don't know why TomTom has hidden all these important options!!!!!
Thank you guys!  |
| Back to top |
| Back to top |
