Pocket GPS World :: View topic - Screen cover - How To remove
mackeddie
PostPosted: Fri Jan 11, 2008 8:17 pm    Post subject: Screen cover - How To remove Reply with quote
Does anyone know how to remove the front screen cover. Somehow there appears to be water trapped behind mine, which is very annoying, and without any detailed instruction manual I am stuck.
Crying or Very sad
chrissyboy2241
PostPosted: Sat Jan 12, 2008 12:32 am    Post subject: Reply with quote
Someone wrote a detailed description on this forum but i cant find it. put your nails under the plastic cover at the top where it says GPS and pull until it comes free. Then on the left hand side just above the card cover put your thumbnail under the cover and pull and it should just click away. When replacing the cover make sure the plastic lug at the bottom of the screen is situated correctley.
robs1972
PostPosted: Sat Jan 12, 2008 1:02 am    Post subject: Reply with quote
The way things are going it looks like you have to connect your Active 10 to your PC and export the cover using Satsync!!! Rolling Eyes Laughing
I like mapping, I like mapping, I like mapping and I like to map!
FrequentFlyer
PostPosted: Sat Jan 12, 2008 4:21 pm    Post subject: Reply with quote
I saved this...specifically.
"Moisture under the screen cover can be removed by easing off the screen cover itself. The cover is held in place by 3 clip points: the top (by the GPS text), left shoulder and right shoulder (by the Active 10 text). To remove the cover:
Slide your fingernails under the top edge of the screen cover (directly underneath the GPS text). Ease the screen away until it ‘clicks and lifts up. Depending on the stiffness of the cover, you can now do one of two things:
Insert a small headed screwdriver into the cut-out on the edge of the cover beneath the Active 10 text on the right hand side (i.e. just above the on button). Move the screwdriver head backwards, under the edge of the screen (i.e. towards the side buttons, not towards the antenna) and ease the cover away from the edge of the unit. This should release the 2nd clip. With two clips released, the screen cover will come away.
Please your nails at the bottom edge of the screen cover, between the top edge so the buttons and the cover. Then holding the back of the unit firmly with your other hand, push with your nails upwards towards the antenna. This should release the cover. When doing the method though, please do be careful: if you press down on the screen cover itself, when it slides off there is a small chance that it may leave marks on the screen underneath. These can be cleaned off – but it’s just better all round to avoid it on the first place.
Replacing the cover is easy, just sit the tang at the base of the cover into the slot above the joystick, then push the cover down at each clip point until all three click into place.
lucevans
PostPosted: Sat Jan 12, 2008 6:31 pm    Post subject: Reply with quote
Since it's not in the manual, could someone on the forum admin make this a sticky please?
Jay1967
PostPosted: Sat Jan 19, 2008 12:47 pm    Post subject: Reply with quote
i posted a video on how I do this on YouTube. I hope it helps?!
click this link: http://uk.youtube.com/watch?v=sIAjuCFvU6g
Visit my Walking Blog: http://jswalks.blogspot.com/
Visit my Tech Blog: http://jtech2010.blogspot.com/
TT GO920, Honda in-Car system, Garmin Oregon 550T + (OSGB 1:50k S.Eng), Garmin 60CSx, TT BT, QSTARZ QBT1000 Data Logger, MemoryMap v5 - Uk 1:50kOSG
FrequentFlyer
PostPosted: Sat Jan 19, 2008 4:23 pm    Post subject: Reply with quote
Very good....I think the top needs to be released first, as on mine you can't see the side ones, and then only just with the top released.
Trevor1234
PostPosted: Fri May 09, 2008 5:50 pm    Post subject: Reply with quote
Hi Jay1967
Thats a good idea (putting it on Youtube) and I'm sure it will be helpfull to customers in the future. Reading instructions is one thing, seeing it done is far superior.
Tomtom Go 720.
Navcore 9.510
GPS World Traffic cameras
Home 2.7
iPhone 3G
Westlothian
PostPosted: Wed Dec 31, 2008 10:59 am    Post subject: Reply with quote
To make this job easier, particularly in winter, the screen cover can be heated gently with a hairdryer first to make it more pliable. This also makes it less prone to damage. Instread of fingernails a plastic edge, like a bank card, can be used for more visibility and better control.
The first tab on the end is easy to pop out and up. The second tab, I select above the brightness button, then slide the card just under the cover parallel with the screen surface towards the on/off button corner until the tab pops out with minimum force.
The screens don't seem to be coated and therefore they can easily have light scratches removed by T-Cut, Brasso, or other polishes for CDs etc.
Bosun
PostPosted: Wed Dec 31, 2008 1:39 pm    Post subject: Reply with quote
With reference to inserting a bank card etc. into the top clip,be careful not to push the rubber seal down as I did when using the end of a plastic ruler.
If you do happen to do so,slacken the two small screws on the unit a turn or two and the seal should pop back into place.
Thanks for the tip regarding the hairdryer,good one.
Ian
dungbeetle
PostPosted: Sun May 17, 2009 8:35 pm    Post subject: Reply with quote
Perhaps Satmap could look into producing a thin self-adhesive neoprene gasket, to fit around the edge of the main screen.
It would sit sandwiched in between the main body of the unit and the protective screen cover, thereby creating a seal which would prevent the ingress of water in the first place.
The gasket could also be fitted quite easily to units that have already been sold by their owners.
Just a thought.
Brelin
PostPosted: Mon Jun 08, 2009 4:38 pm    Post subject: Reply with quote
Just a thought.
Totally agree. I was out in the rain with the A10 and water got in between the scratch cover and the screen. In the next design overhaul of the product I'd recommend to Satmap to either seal the scratch cover properly or get rid of it completely and use stick on film to prevent scratches instead.
Bosun
PostPosted: Mon Jun 08, 2009 7:40 pm    Post subject: Reply with quote
I have to say that I think the replaceable screen is quite a radical idea in GPS design but perhaps it has not been quite as succesful in practice as Satmap hoped it would be.
In this forum post:-
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=75823&start=15
some enterprising person ( a Dutch chap I think ) has removed the centre clear section and just left the rim ( apologies if you have already read it ).
I am rather impressed by this and perhaps it is the way for Satmap to go.You still have a raised rim for protection but only the one screen ( with a protective film presumably ) so any water can escape.
Personally when walking I put the whole thing in an Aqapac the only problem being that it is yet another layer to observe the screen through but it keeps it clean and water free.
I think I will e-mail Satmap regarding it ( with reference to the original designer of course ).
Ian
stephenmorphey
PostPosted: Wed Aug 19, 2009 5:08 am    Post subject: Reply with quote
Hi mackeddie...
Hope this is useful for you:
The screen cover is held by 3 clips. 1 at the top below GPS text, a left shoulder and a right shoulder. Slide your nails beneath the cover from top below GPS text and swipe your nails until it clicks open!
Always Be Happy...
PhilCorley
PostPosted: Wed Aug 18, 2010 10:38 am    Post subject: Reply with quote
Warning to others; first time I tried this I cracked the screen cover Sad
So take care and be gentle with it (which I thought I had been!)
Phil
23.123 (17 Dec 25)
