| Author |
RicksAlfas Occasional Visitor
Posted: Thu Nov 29, 2007 12:59 pm Post subject: I want a neater TMC aerial |
I've got a Navman S90i and I don't like the long trailing wire type TMC aerial that comes with it. Are there any neater alternatives like a little rubbery stick or similar. I don't want to leave the S90i on display in the car and having a great long trailing lead is not very convenient. _________________ Navman S90i for the car and Etrex Summit for walking! |
| Back to top |
philpugh Lifetime Member
Posted: Tue Dec 04, 2007 2:42 pm Post subject: |
Problem is that you need an efficient aerial for reception of the RDS information (which is transmitted at lower powers than you may think!)
The 'piece of string' is actually quiet efficient - but not inside the partial Faraday Cage we call a car! For best results get a connection to an external aerial (existing car radio aerial with a splitter is often the simplest). Have a look at the posts here for some ways of doing this. _________________ Phil |
| Back to top |
Townfield Occasional Visitor
Joined: Dec 27, 2007 Posts: 8 Location: UK, Cheshire, Northwich
Posted: Sat Jan 05, 2008 10:14 pm Post subject: |
RicksAlfas,
You might find you do not need the nasty wire. If you get decent Classic FM reception, you might get by without it. |
| Back to top |
gmoorc Occasional Visitor
Posted: Sun Jan 06, 2008 1:28 pm Post subject: |
Came across this while researching the new Becker units.
Not sure how well it would work and looks like it has 4 positions on the connector jack.
Link
Translation
Pic
Think the 1.5m long description must be an error! |
| Back to top |
Posted: Mon Jan 07, 2008 3:14 pm Post subject: |
| Townfield wrote: | RicksAlfas,
Only if you have your unit connected to an external aerial. Cars are VERY good at blocking radio signals. Also the RDS signal is transmitted at lower power levels than the main broadcast signal giving rise to poor TMC detection even in the presence of what seems to be a good ClassicFM signal. _________________ Phil |
| Back to top |
alistairm1 Regular Visitor
Posted: Tue Jan 08, 2008 2:21 pm Post subject: |
I have just bought one of the stick antennas from a chap on eBay.
When it arrives and I have time to test it I'll post back. (could be a week or two, though) |
| Back to top |
Posted: Wed Jan 09, 2008 9:26 pm Post subject: |
@PhilPugh
I live just up the road from you (Barnton) and can assure you that TMC works on my S90i without the aerial, in many (agreed not all) areas.
As I said, it might work for the OP if he is lucky. |
| Back to top |
Posted: Tue Jan 15, 2008 5:44 pm Post subject: |
| Townfield wrote: | @PhilPugh
What transmitter are you seeing in Barnton? Just curious Before I connected the nuvi to the car aerial I had to get onto the A559 to get a signal. This is the highest point for a few miles (at 80m !!) - at home (55m) it was very hit-and-(mostly) miss affair. Now I get reception (GALAXY FM) from central Manchester at home within 1 minute of turning on. _________________ Phil |
| Back to top |
Posted: Tue Jan 22, 2008 10:00 pm Post subject: |
Well, it's been a while but at long last the aerial has arrived from Germany.
it is 10.5 cm long, so not overly obtrusive, but can't pick any sort of signal up unless you are very close to the transmitter.
I am now going to try the splitter option. |
| Back to top |
| Back to top |
