Pocket GPS World :: View topic - How to track a weather balloon?
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Vehicle Locators & Person or Pet Tracking
deneo_e
PostPosted: Fri Mar 07, 2008 3:36 pm    Post subject: How to track a weather balloon? Reply with quote
Hi there,
A group of us are currently launching a weather balloon that will reach a very high altitude and require some way of tracking its location - inparticularly for retreiving it once its landed!
The system needs to be reasonably small, inexpensive, not too heavy and easy to set up - knowledge of micro-interfacing very limited.
Any help or ideas?
Thanks, :o)
PostPosted: Fri Mar 07, 2008 3:42 pm    Post subject: Reply with quote
Welcome to the forum, have a look at This - you will need to provide a power source (battery etc) but the device is very low power in current consumption - Mike
Skippy
PostPosted: Fri Mar 07, 2008 6:45 pm    Post subject: Reply with quote
Welcome
How high is "very high"? Shocked
Bear in mind that GPS units may have limits on the altitude that they will can calculate a fix, I think it's 60,000 feet or so!
Watch out for battery life if the unit is going to get very cold - I presume you are well aware that the cold kills the battery very quickly.
Gone fishing!
WLMOATE
PostPosted: Fri Mar 07, 2008 8:09 pm    Post subject: Reply with quote
Two challenges that you will need to over come are drift of freq due to the extreme tempratures any of your radio equipment is exposed to.
You may get out of range of the GSM base once you reach an altitude above 5 miles. This could be improved by using a small yagi style antenna. DO not purchase one just make it form thick copper wire to keep weight down
Another solution is to use licensce free radio equip www.lprs.co.uk they supply some modules that you can connect directly to a gps rciever. The ground station could use a reciever with high gain Yagi antenna, and the data could be fed directly into a PC using google earth .
If you need more details just ask
Wayne
MY-SOS, Benefon TWIG, DriveSmart, Wayfinder
lbendlin
PostPosted: Sat Mar 08, 2008 7:15 am    Post subject: Reply with quote
this has been done a few times already. The cheapest solution is a SMS based GPS tracker. Yes, it won't function above a certain altitude but then again you only need it when you retrieve the balloon. GPS itself has no altitude limitation (heck, the ISS is using it...)
Lutz
TomTom/TeleAtlas NAVTEQ
simontdc
PostPosted: Fri Mar 14, 2008 4:03 pm    Post subject: Reply with quote
We have something - http://www.tdc.co.uk/index.php?key=lr8m03 - but bear in mind it is illegal to use GSM in an airborne situation - not because of interference with aircraft, but it is the terms of use of GSM - similar to most PMR licences.
This is mainly because your balloon would be able to 'see' GSM base stations for hundreds of miles once airborne! - and the networks will suffer interference.
G1NTX AFRIN LRPS
simontdc
PostPosted: Fri Mar 14, 2008 4:07 pm    Post subject: Reply with quote
And again, commercial GPS units will refuse to present a fix over the SPS height limit of 60,000 feet. You may well be able to recover psuedo-range information (I have not tested it...), but position will not (or at least should not) be returned. Export licences would not be granted for navigation equipment without such a restriction.
L2 receivers will work though at greater altitudes, they will not have a restriction.
G1NTX AFRIN LRPS
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Vehicle Locators & Person or Pet Tracking All times are GMT + 1 Hour
23.094 (24 Sep 25)
