| Author |
fluffytails Occasional Visitor
Posted: Mon Mar 10, 2008 8:25 pm Post subject: Garmin map update 2008 |
I have recently registered my c510 with Garmin. It is a GB&I version. Garmin have just sent me a DVD map update 2008 Europe. I don't require European cover so is it worth downloading it onto my unit? Or does it also include UK updates as well? If my c510 had all the European maps on it would it slow it down?
Sorry about all the questions, I have loads more but I dare not ask for more! |
| Back to top |
inspiredron Frequent Visitor
Joined: Dec 17, 2006 Posts: 302 Location: Ellesmere UK
Posted: Mon Mar 10, 2008 9:30 pm Post subject: Re: Garmin map update 2008 |
| fluffytails wrote: | I have recently registered my c510 with Garmin. It is a GB&I version. Garmin have just sent me a DVD map update 2008 Europe. I don't require European cover so is it worth downloading it onto my unit? Or does it also include UK updates as well? If my c510 had all the European maps on it would it slow it down?
Your 510 will not take the whole of Europe. However, you can put Europe, excluding GB & I on an SD card. To get all of that on you would need a 2Gb card but 1Gb will give enough space for all that you are likely to need on a single trip. It will probably be worth updating the UK maps to 2008 and the update disk will do that automatically. If you are concerned about speed (and on my C510 I never noticed any difference) you can deselect the Europe maps in Map, Map Info. Another benefit of using an SD card is that it can hold your POI's - eg Speed cameras - better there than on the Garmin and certainly quicker to load using a card reader. |
| Back to top |
Posted: Mon Mar 10, 2008 9:42 pm Post subject: |
| Many thanks for that. In fact it seems that I have v9 already installed (GB&I) and I think that the update DVD is v9. I am not 100% sure and it does not state the version on the DVD cover. |
| Back to top |
Posted: Mon Mar 10, 2008 9:45 pm Post subject: |
| Quote: | | I am not 100% sure and it does not state the version on the DVD cover. |
What does it say exactly? |
| Back to top |
Posted: Mon Mar 10, 2008 10:02 pm Post subject: |
| Map update 2008 City Navigator Europe NT. |
| Back to top |
Posted: Mon Mar 10, 2008 11:17 pm Post subject: |
| Quote: | | Map update 2008 City Navigator Europe NT. |
That's the newest (v10) maps. |
| Back to top |
Posted: Tue Mar 11, 2008 9:30 am Post subject: |
| Thank you Paul. That is great news. |
| Back to top |
lancashirelad Occasional Visitor
Joined: Dec 08, 2007 Posts: 15 Location: Pendle Views
Posted: Fri Mar 14, 2008 10:46 am Post subject: updates onto SD card |
| I am likely being very dense, but how do I get the new map info updates onto the sd card, rather than clog the 310's internal memory? |
| Back to top |
Posted: Fri Mar 14, 2008 9:44 pm Post subject: Re: updates onto SD card |
| lancashirelad wrote: | | I am likely being very dense, but how do I get the new map info updates onto the sd card, rather than clog the 310's internal memory? |
Connect a card reader to your PC and plug in the SD card. Run MapSource or MapInstall and highlight the areas that you want on the SD card. When you have highlighted the required area (which can be done in bits - you will see them building up in the left margin) give the mapset a meaningful name and use the transfer facility. The program will then join together all th emap tiles that you have selected into an image file (which takes quite a long time) and then copy that file to your SD card. Insert the card in the Garmin and enable the map in "Main Menu - Map - Map info.
Hope that helps. |
| Back to top |
morgad Occasional Visitor
Posted: Fri Mar 14, 2008 10:06 pm Post subject: |
Got my update installed today
No DVD drive on the XP box, so had go via a Samba share from my Linux box.
I had to mount the /long/path/to/the/samba/share as a drive letter (z:/) to get the installer to work correctly
If I had know how out-of date the data was I probably would not have bothered to buy it
Two major road projects near me that have be *open* for a year were not on the map
1) New main link road north from Ambassador Drive in Exeter to Pinhoe Rd Google Map
2) I could not find the new A30 dual-carridgeway section at Victoria either Google Map
but at least they fixed the road past A La Ronde (Summer Lane - it was Orange even thought it is only 6 ft wide)
[/url] |
| Back to top |
Posted: Fri Mar 14, 2008 10:44 pm Post subject: Still being dense |
| Thanks for the info inspiredron, but, when I plug the sd card into the pc, it only shows the few music tracks that are on it, no maps, they are loaded onto the nuvi. Perhaps I should not bother with the update Cd and just leave it as it is............. |
| Back to top |
crazyfingers Regular Visitor
Joined: Aug 08, 2004 Posts: 107 Location: Massachusetts, USA
Posted: Sat Mar 15, 2008 2:47 am Post subject: Re: Still being dense |
| lancashirelad wrote: | | Thanks for the info inspiredron, but, when I plug the sd card into the pc, it only shows the few music tracks that are on it, no maps, they are loaded onto the nuvi. Perhaps I should not bother with the update Cd and just leave it as it is............. |
Have you tried installing the other maps to the card while the card is in the Nuvi?
I have the Nuvi 750 North America version (North America maps installed on the Nuvi internal memory) but I have learned that I'll be making more business trips to Europe this year and next and so I purchased City Nav Europe. I was able to install it all onto the SD card while the SD card was in the Nuvi unit. It was easy as can be. Just be sure to select the correct drive to install to. _________________ Garmin Nuvi 750 w/City Nav 10 N. America & 08 Europe
Garmin iQue 3600/City Nav 08, City Select v6/v5
Garmin eTrex Vista Cx, Topo USA, Topo Canada
eTrex Legend (Original)
A Magellan that got wet and died on a canoe trip in 02 |
| Back to top |
Posted: Sat Mar 15, 2008 4:24 pm Post subject: it didn't work |
| Having inserted the CD 2008 update, connected the nuvi, with the SD card in, it ran to the blue install screen, flashed up another,( so quick I was unable to read it ), then came up with the blue exit screen..........and that was it.........obviously the updates didn't install in .5 of a second......bizzare......still says city navigator europe nt v9 on the map info screen. |
| Back to top |
Posted: Sat Mar 15, 2008 4:56 pm Post subject: Re: it didn't work |
| lancashirelad wrote: | | Having inserted the CD 2008 update, connected the nuvi, with the SD card in, it ran to the blue install screen, flashed up another,( so quick I was unable to read it ), then came up with the blue exit screen..........and that was it.........obviously the updates didn't install in .5 of a second......bizzare......still says city navigator europe nt v9 on the map info screen. |
Call or send an email to Garmin. Registering your product on the Garmin website helps. Garmin tech support people are actually very helpful. They usually take about a day to reply to emails. But they will continue to reply until the problem is solved. Or call them.
I have no doubt that they will fix your problem if you work with them. _________________ Garmin Nuvi 750 w/City Nav 10 N. America & 08 Europe
| Back to top |
Posted: Sat Mar 15, 2008 5:19 pm Post subject: thanks |
Thanks crazyfingers, I have written to the bods at Garmin plus the unit was registered some months back. As you say, they are pretty good at getting back to questions in a short space of time. Will wait and see  |
| Back to top |
| Back to top |
