| Author |
masrock Occasional Visitor
Posted: Thu Mar 20, 2008 12:15 pm Post subject: |
| themeldrews wrote: | Just received my Mio p560 from Anquet.
Will start playing with it(my first PDA).
The Anquet mapping is all GB OS at 50,000 scale.
I have been looking for powered car mount with built in speaker and a mains charger like the type available for the Mio p550.No luck so far.
Terry |
Hi Terry,
Let me know what you think. Do you use the Anquet map for general navigation or for hiking too? What memory card have you got, mine is Transcend class 6 8gb SDHC and seems to work well.
Masrock _________________ Time flies like an arrow
Fruit flies like a banana
| Back to top |
themeldrews Occasional Visitor
Posted: Thu Mar 20, 2008 4:37 pm Post subject: |
Hi Masrock,
I got the Mio as a replacement for my Navman in car GPS.I also will use it for hillwalking using the Anquet mapping.
We will be in Snowdonia at the end of the month to try it out.
Will let you know how it does.
The deal from Anquet was Mio P560,All UK on DVD OS 50,000 mapping and a Kingston 8gb SDHC card
Terry |
| Back to top |
Posted: Thu Mar 20, 2008 11:41 pm Post subject: |
| themeldrews wrote: | Hi Masrock,
Terry |
That sounds sweet. If you don't mind my asking, how much was that package?
| Back to top |
Posted: Fri Mar 21, 2008 9:28 am Post subject: |
Including P&P and VAT it was £366.
The best deal i saw in the show was from a company www.viewranger.com who offered all of UK National Parks OS at 50,000 on a card for £35.
This deal was for mobile phones with GPS.My mate bought this for his Nokia and is really pleased.He will use it as a backup device on the mountains.
I think this deal is still on.
Terry |
| Back to top |
CaptainZed Occasional Visitor
Posted: Fri Apr 04, 2008 1:44 pm Post subject: |
| themeldrews wrote: | Including P&P and VAT it was £366.
Terry |
I think you can get a better deal than that. Anquet offers all national parks at 1:50,000 whic can be obtained for £15 from these guys
http://www.aboveandbeyond.co.uk/shop/Anquet-National-Park-Series-p-1-c-1110.html
Memory map is also offered but that is more expensive (£27).
More general comments on the MIO. I haven't really used it in anger yet - my main use is as a GPS not a PDA. It is certainly quicker than the 168 and has bettter satelite reception.
One good feature I noticed which may have been there on the 350/550, is that there is a soft off at the top, recessed so hard to activate by mistake and a hard off at the bottom. This latter does not cause the unit to lose all its data (in stark contrast to the 168). Thus I can leave it off just about all the time hence saving on battery use. From comments I have seen for the 350/550, units running down when not in use was a major issue, so hopefully this will have solved the problem.
Am going to the Lakes in May to see how it works on a long walk. |
| Back to top |
Posted: Fri Apr 04, 2008 3:10 pm Post subject: |
Thanks for the links.
I also willl be using mine mainly as a GPS unit in car and on the hill.
I ran a comparison with my Navman N20 last weekend.The Navman is set to suit caravanning but the Mio/TomTom i left at default.The routes given were identical from Cardiff to Snowdonia. The volume on the Mio is noticeably lower and i will get a powered car mount when they come on the market.
On the hill it was excellent with fast response.We tried Anquet and Memory Map both good.The conditions were pretty bad with heavy rain/mist etc and had no problem.I used a friends Otterbox which kept it dry and have ordered one of these.
Battery life was very good and no extra charging was needed other than when in use in the car.
Good Luck in th Lakes.
Terry |
| Back to top |
akribie Occasional Visitor
Posted: Sun May 18, 2008 7:09 pm Post subject: |
If you want good flexibility when out and about and easy charging, you can do a lot worse than buy one of the U20 battery units from http://www.gpsforless.co.uk/search.php?st=category|Mitac%20Mio%20Accessories.
The U20 comes with a mains charging lead and you can charge the PDA at the same time as charging the battery. So you get the best of both worlds - tidy mains charging system and lots of running time away from power. I ran an A201 continuously on U20 power using the GPS in a coach for 7 hours and still had lots of life left without starting on internal battery.
I also did a test with the bigger I-UP S400 unit and got 16-19 hours of continuous screen-on GPS before reverting to internal battery on the A201. I would guess that it will last even longer on a P560, which seems to use less battery life per hour on GPS than the A201. |
| Back to top |
| Back to top |
