| Author |
D4VE Lifetime Member
Joined: Aug 31, 2005 Posts: 207 Location: Hertfordshire
Posted: Sat Mar 29, 2008 9:07 pm Post subject: |
| Andy_P2002 wrote: | | To be fair, the Go520 and 720 ARE the same hardware apart from the size of internal memory, but Home still should be able to tell the difference! |
I did throw Home a curve tho, I have a 4GB external card
Dave |
| Back to top |
weely Occasional Visitor
Posted: Sat Mar 29, 2008 9:08 pm Post subject: |
Cheers mike, will have a look at that but I do try to keep away from windows software, never have another pc.  |
| Back to top |
Posted: Sun Mar 30, 2008 8:54 am Post subject: |
OK Dan, you can wake up now
Dave |
| Back to top |
AndyVaughan Lifetime Member
Joined: Apr 13, 2006 Posts: 1500 Location: Rossendale
Posted: Sun Mar 30, 2008 10:31 am Post subject: |
Dan,
The green circle on the TMC now seems to mean 'I have had a signal in the last 10 minutes or so' NOT 'I have a signal now' as it used to do.
If you browse the traffic incidents when a route is planned do you get any delay indicated for any of them? I don't, but if I unplug the TMC and use my GPRS traffic the same incidents give delay information and add time to the route, which isn't happening on RDS-TMC.
It appears that in response to the wildly inaccurate delay info with RDS-TMC on previous Navcore 7 versions TT have 'fixed' it by just turning off the delay part, it now only notifies you of incidents.
Also, if you have 3 plus incidents on your route how many show on the traffic sidebar - on mine it is none of them and has been with all versions of Navcore 7. If you have ever used RDS-TMC on Navcore 6 you would see all of these incidents on the sidebar with delay times - this how the system is advertised as working by all the TT documentation I have seen. It has never worked like this with Navcore 7. Some people have reported that when they have 2 incidents the first one shows, but not the second. I only ever see anything on the sidebar when there is a single incident.
Is your RDS-TMC performing differently to the above? You need to look how many incidents you have on the route and how much time has been added to your ETA. Rerouting accurately around traffic incidents isn't possible if there is no indication of delays!!
Andy |
| Back to top |
stuart Frequent Visitor
Joined: 20/04/2003 11:51:10 Posts: 405 Location: Dorset, England, Great Britain
Posted: Sun Mar 30, 2008 10:54 am Post subject: |
| AndyVaughan wrote: |
Andy |
So basically Andy, if you do the official update to v7.480, it renders your unit 'unfit for purpose'. So all customers can claim a full refund from TomTom. |
| Back to top |
Posted: Sun Mar 30, 2008 6:19 pm Post subject: |
| Dan_Gleebitz wrote: |
OK I note your points about the TMC. I get a signal almost immediately, and I KEEP the signal, where as with the original aerial I could sometimes get a signal but then I would always lose/gain it as car moved.
The traffic info continually updates and shows on the map pages that you scroll through, delay is shown as one minute only, but the mileage shows and updates as time/incident changes/progresses.
The traffic bar does only show one incident at a time and no delay.
So it is not perfect then. But it is certainly better than the previous TMC.
Dan
If you had tried the new aerial with 7.221 you would have a better indication of if you had a signal or not.
With 7.480 the green circle doesn't seem to change if you lose the signal until at least 10 minutes after the signal is lost - I can prove this by unplugging my antenna from the 'egg' as I have modified mine. All this time it still says 'up to date'.
So, you may well be losing the signal for five minutes or so and then regaining it, but the TT does not give you this indication any more.
The lack of delay info is a major problem - you cannot reroute without delay info, all you can do is avoid an incident. The reroute may add 20 mins to your ETA to avoid a 3 minute delay - not much use!
Andy
| Back to top |
ChrisJ_slh Occasional Visitor
Posted: Sun Mar 30, 2008 6:20 pm Post subject: |
| Dan_Gleebitz wrote: | What I can't get my head round is that since I installed 7.480 on my 720, every aspect of it is still working perfectly, and I am especially pleased with the TMC.
Dan. |
I just bought my 720 last Sunday and didn't even read this thread. Installed Home from TomTom website, updated the firmware and maps. Guess what, absolutely fine.
Ok, so the bluetooth crashed while I was on battery power and the POI warning sounds keep resetting but otherwise no issues I can notice. Very happy.
After reading this thread though I'm bl00dy paranoid that it is all going to go pear shaped any second now..... |
| Back to top |
Posted: Sun Mar 30, 2008 8:17 pm Post subject: |
If all you want from the device is to navigate to a postcode while playing music and answering the odd phone call then the device will work fine. It is some of the more obscure menu options that seem to be broken.
As you have found out running the device on its battery alone is not a good idea, and if anything makes the Bluetooth phone problem more likely to occur - Mike |
| Back to top |
DennisN Tired Old Man
Posted: Sun Mar 30, 2008 9:03 pm Post subject: |
| AndyVaughan wrote: | | So, you may well be losing the signal for five minutes or so and then regaining it, but the TT does not give you this indication any more. |
Just a small point, Andy. I'm now getting a lot of shouts "Traffic situation on your route has changed", then nothing and no change to the traffic bar (one indication if only one, possibly two incidents, no indication if three or more). AND when I look at the detail, it hasn't changed from the previous time I looked.
With 7.221 I used to get "delay now xxx minutes, do you wish to reroute?".
I am beginning to conclude that these repeats of "situation changed" are simply the aerial dropping and regaining contact - I don't think I'm being handed across that many transmitter regions.
I've got 7.221 on a 720, so I might swap the TMC round and see what I get again. _________________ Dennis
Two of them are obesiting!! |
| Back to top |
Posted: Sun Mar 30, 2008 9:25 pm Post subject: |
| DennisN wrote: |
I think there is a tickbox somewhere in voice preferences about reading aloud traffic info - I turned that off ages ago due to the delay is now 178 mins announcements!
You may be right - this could be an indication of losing signal and gaining it again.
Andy |
| Back to top |
mikewall Regular Visitor
Posted: Mon Mar 31, 2008 5:12 am Post subject: |
You hit the nail on the head there Dennis, it also says it after rerouting you eg the A361 is shut from Banbury to Daventry for roadworks! started work at 0300 and set up my route on my old 520 but sat in my cab sorting my paperwork out, because the yard is well off road the unit kept trying to place me on a road choosing between 3! i got several traffic on your route has changed messages every time TT locked onto a road! At 3am the only people on the roads round here are us mad truckers hardly enough to change a road condition where the road id closed to all traffic |
| Back to top |
Posted: Mon Mar 31, 2008 7:00 pm Post subject: |
And how frustrating is it when everyone in front of you is going at 50 MPH through a series of SPECS and you can only travel at 45 MPH (TomTom speed)
Sorry guys somehow managed to post to wrong thread.  |
| Back to top |
Sema_4 Pocket GPS Verifier
Joined: Jun 06, 2006 Posts: 40 Location: Madrid, Spain
Posted: Tue Apr 01, 2008 12:11 pm Post subject: |
| D4VE wrote: | | Believe it or not 7.480 has upgraded my 520 to a 720. |
I suspect this is just another bug in TTH as I also get the '720' message when I operate my 920 in TTH since the last update, was fine before.... |
| Back to top |
Posted: Tue Apr 01, 2008 12:45 pm Post subject: |
Seems 7.481 is out any one tried it yet? is it the prodical son the perfect version or just more bugs!
Lets face it can't be worse than 7.480! but dont quote me on that  |
| Back to top |
nebula Occasional Visitor
Posted: Tue Apr 01, 2008 1:07 pm Post subject: The "One moment please..." problem is still there |
| The "One moment please..." problem is still there in 7481 (9086) which makes this version unusable for me, so I have reverted to 7.221. |
| Back to top |
| Back to top |
