Pocket GPS World :: View topic - CBROM's converter, error type mismatch
11oydee
PostPosted: Sat Mar 29, 2008 11:51 am    Post subject: CBROM's converter, error type mismatch Reply with quote
Is anyone else getting an "ERROR : Type Mismatch" error when converting the latest database?
I am using CBROM's GPX converter.
It's only happening to the mobile.csv file, converts everything else ok.
I have tried downloading again but still get the same error & looking at the .csv l all looks ok.
11oydee.
PaulB2005
PostPosted: Mon Mar 31, 2008 8:42 am    Post subject: Reply with quote
Which file did you download?
The database has been released for over 2 weeks and i've not seen anyother reports of problems, with or without the GPX Program.
PostPosted: Mon Mar 31, 2008 2:56 pm    Post subject: Reply with quote
he fixed this a while back - get the latest version from here: http://cbrom.myby.co.uk/3.html?submenu=2
11oydee
PostPosted: Mon Mar 31, 2008 10:44 pm    Post subject: Reply with quote
Thanks MaFt, its been a while since I have updated my garmin as you can tell.
Apologies PaulB for the second post but as I hadn't received a reply I started wondering if I should have posted in a different forum. Embarassed
11oydee
markjohnson
PostPosted: Wed May 21, 2008 9:35 pm    Post subject: Reply with quote
I have the same problem. cbrom's utility (v1.1.3 - latest) gives "run time error 13" and "type mismatch" when trying to convert the csv database dated 2/5/08.
Any suggestions?
Kind regards,
Mark
PostPosted: Wed May 21, 2008 10:04 pm    Post subject: Reply with quote
markjohnson wrote:
Any suggestions?
Kind regards,
Mark
if you redownload it should be fine now
boatmanpw
PostPosted: Thu May 22, 2008 2:41 pm    Post subject: Cbrom's GPX Converter - error type mismatch Reply with quote
I have the same problem but with the csv files from the latest v.6.054 dated 21 May.
Cbrom's GPX Converter (v1.1.3) gives "run time error 13 : type mismatch" when trying to convert the redlight, Gatso, mobile and pmobile files. I can convert the specs and temp csv files OK as I can all the files dated 2 May.
Today I have re-downloaded and re-installed GPX Converter and re-downloaded and unzipped the csv files but with the same result.
Can anyone help please ?
PostPosted: Thu May 22, 2008 3:31 pm    Post subject: Reply with quote
hi, if you redownload (again) then this should now be ok
markjohnson
PostPosted: Thu May 22, 2008 8:34 pm    Post subject: Reply with quote
Thanks for the suggestion.
I wasn't sure if you meant to redownload the GPX Converter or the camera database... so I did both and can verify it now works.
Kind regards,
Mark
boatmanpw
PostPosted: Thu May 22, 2008 9:32 pm    Post subject: Reply with quote
MaFt,
Did that - it was. Many thanks for your help.
For info of anyone else having similar problem, you only need to re-download the database.
Thanks again.
23.104 (22 Oct 25)
