| Author |
mrgee Occasional Visitor
Posted: Tue May 06, 2008 1:22 pm Post subject: tomtom 710 not starting at all |
hello can any one help please .
i have a tomtom 710 but when i try to start it all i get is the little tomtom drum roll and then the screen is just white with a grey bar gounin from top to bottom along the left hand side.
ive done the reset but still no luck in starting . is there anything a can try to get this working please
thanks |
| Back to top |
Anita Pocket GPS Moderator
Posted: Tue May 06, 2008 1:40 pm Post subject: |
Have you got a Windows back up you can copy back to the device? _________________ Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21 |
| Back to top |
Posted: Tue May 06, 2008 1:48 pm Post subject: |
| no i have no back up or anything like that . |
| Back to top |
Andy_P Pocket GPS Moderator
Posted: Tue May 06, 2008 2:11 pm Post subject: |
Do you have a copy of TT's PC utility "Home" on your computer yet?
If no download it from HERE (left hand green box).
Connect up the Go to the PC and run the Home utility.
If the Go is not recognised by Home, repeat the exercise but using the OTHER version of Home (right hand green box on that webpage).
Then, first try THIS
and if that doesn't work, try this:
| Quote: |
Using Home to trigger a new download of software by removing the system files:
Delete the files from the root directory of the TomTom. Follow the steps below to do this:
1. Reset your TomTom device: http://www.tomtom.com/6965 and connect it to your computer.
2. Open My Computer in Windows, or Finder in Macintosh from your desktop and turn on your TomTom device.
3. On your screen a new removable disk appears, this is your TomTom device, click on the disk to open it.
4. You will see a list of folders and a list of loose files
5. Delete all of the loose files. IMPORTANT: The folders with their content must NOT be deleted.
5. Close the window when all files are deleted by clicking on the {x}.
Next we will reinstall the application via TomTom HOME.
First, go into TomTom Home and click on file / exit.
Now go into my documents on your PC / TomTom Home / Downloads / Program. Delete everything that is in this folder.
Now start TomTom HOME on your computer again
TomTom Home should automatically check for updates and prompt you to install them, if not:-
2. Click Install to TomTom.
3. Select the Application update.
4. Click on 'Device - Disconnect Device', then turn off your device when it is done installing and disconnect it from your computer. |
NOTE: The above was written for Home v1. For Home v2, replace instruction 2 by "Click on 'Update my device'..." |
| Back to top |
Posted: Tue May 06, 2008 2:51 pm Post subject: |
| cheers andy but already have tried both methods and still all im getting is the whole screen white except for grey stripe down the left side od screen |
| Back to top |
Posted: Tue May 06, 2008 2:53 pm Post subject: |
It may be worth telling us what you HAVE done then, to avoid us wasting time making suggestions you have already tried.
Also, what did you do just before it stopped working...... |
| Back to top |
Posted: Tue May 06, 2008 3:18 pm Post subject: |
hi . have done nothing to it mate . its been in a drawer for 6 months never been charged for 6 months . came to switych it on today and like i say ....... all i get on switching it on is a white screen with a little grey stripe down left side and the little tomtom drum roll then it just hangs there and does nothinng else . have tried a reset and the other method you mentiones .
i have noticed that when i have reset the tomtom and i go into the contacts folder that recived calls and dialed calls are still there . wold a reset not erase the data ? |
| Back to top |
Posted: Tue May 06, 2008 3:28 pm Post subject: |
| mrgee wrote: | | its been in a drawer for 6 months never been charged for 6 months . came to switych it on today.... |
Right, that's relevant.
If the battery is deeply discharged, it will not power up.
Put it on charge for at least 5 hours and try again.
| Quote: | | wold a reset not erase the data ? |
No, a "pin in the hole" reset just turns the device off fully (it normally just goes into a "sleep mode" when you think you've "switched it off").
The program is rebooted but no personal data is touched.
It's like re-booting your PC. |
| Back to top |
Posted: Wed May 07, 2008 8:40 am Post subject: |
| ok been on charge now over 12 hours and still all i getting is white screen with grey bar. anyone any ideas please , |
| Back to top |
Posted: Wed May 07, 2008 2:54 pm Post subject: |
| Will it connect to the PC? |
| Back to top |
Posted: Wed May 07, 2008 3:05 pm Post subject: |
yes mate it will conect to pc no problem . i can get updates etc but cannot see any colour just the white screen
thanks |
| Back to top |
Posted: Wed May 07, 2008 3:28 pm Post subject: |
I'm not sure how you can connect to the PC and get updates if the screen NEVER changes - usually you have to tap the screen when it asks "Do you want to connect to Computer".
Anyway, IF it never changes at all even when connected to the PC, then it looks like it may be broken.
If it's less than 2 years old it's under guarantee - ring TomTom
If it's older - get in touch with http://www.satnav-shop.com/ for a reliable repair. |
| Back to top |
Posted: Wed May 07, 2008 5:03 pm Post subject: |
Connect it to the PC and use Windows Explorer to view the devices files, are there any files listed within the root of the drive and also can you see some folders?
It could be the device isn't booting up due to the main application file being corupt or possibly missing, but you would get the PC connection - Mike |
| Back to top |
Posted: Wed May 07, 2008 6:10 pm Post subject: |
Ive just done a full format as told by tom tom support but till nothing . i guess this tom tom is destined for the bin
saying that though tomtom home has let me use the operate my go on the pc but and works but thats it . maybe screen has gone . |
| Back to top |
| Back to top |
