Pocket GPS World :: View topic - SentrySoft releases new version of GPS Sentry
CharlieCassidy
PostPosted: Thu Apr 22, 2004 4:26 pm    Post subject: SentrySoft releases new version of GPS Sentry Reply with quote
SentrySoft today released the latest version of GPS Sentry, a GPS monitoring Today screen plug-in for Pocket PC 2002 and later PDAs. GPS Sentry provides users of NMEA capable GPS units a compact way of keeping an eye on their GPS from the Today screen.
To get more information on GPS Sentry or to download a 15-day full function trial, visit http://www.sentry-soft.com
CharlieCassidy
PostPosted: Mon May 17, 2004 2:47 pm    Post subject: Reply with quote
SentrySoft is pleased to announce that GPS Sentry V1.3 is available for immediate download. Version 1.3 has the following changes:
  • Added display of position in UTM and USNG/MGRS coordinates.
  • Added automatic display rotation. This feature is enabled and the time interval set in the Configure Screens dialog.
  • Fixed bug in calculation of HDDD format.
  • GPS is now disabled after Serial Port open failure. This will stop the recurring error dialog after the first time.
  • Logging is now disabled after open failure. This will stop the recurring error dialog after the first time.
The new version of GPS Sentry can be downloaded from http://sentry-soft.com/GPSSentry.exe. As in previous versions, this file is a fully functional evaluation copy which can be evaluated for 15 days.
To upgrade a previous version of GPS Sentry to V1.3, simply run GPSSentry.exe then soft reset your Pocket PC. You should not need to reenter your registration code.
Privateer
PostPosted: Mon May 17, 2004 3:36 pm    Post subject: Reply with quote
Hi Charlie,
Can GPS Sentry display the position format of “British Grid”, i.e. Ordnance Survey of Great Britain?
For details on the Ordnance Survey format please see:
http://www.ordnancesurvey.co.uk
http://www.gps.gov.uk/
Robert.
Garmin Camper 770 LMT-D
CharlieCassidy
PostPosted: Thu Jun 03, 2004 6:36 pm    Post subject: Reply with quote
SentrySoft is pleased to announce that GPS Sentry V1.6 is available for immediate download. Version 1.6 has the following changes:
V1.5
    . Time is not gathered from 3 different NMEA sentences rather than just the $GPGLL sentence. Some users with GPSs that did not output the $GPGLL were not displaying the fix time.
    . Added a visual indicator of GPS Disabled and No Fix available. Clear display when GPS is Disabled.
    . Fixed bug in calculation of position in GML log format (same bug as HDDD fixed in V1.3)
    . Added Copy Location to Clipboard function. Copies location and time in current display format to clipboard.
    . Fixed help file issues.
V1.6
    . Extensive changes to Options Dialog. Now it is implemented as a Tabbed Property Sheet with tabs for GPS/Display, Screens, Log, Registration and About.
    . Added option to disable GPS if no input seen. Time delay is set on GPS/Display tab.
    . Added drop down to set GPS Baud rate. Navman 3450 needs 57600, others should be set to the NMEA standard of 4800. In any case, setting must match GPS.
    . Added option to log position periodically, instead of every NMEA sentence. Option is set on Log tab.
    . General refactoring of code and code cleanup.
To upgrade a previous version of GPS Sentry to V1.6, simply run GPSSentry.exe then soft reset your Pocket PC. You should not need to reenter your registration code.
CharlieCassidy
PostPosted: Thu Jun 03, 2004 6:38 pm    Post subject: Reply with quote
Robert,
Sorry this took so long. I generally don't get here often.
I'll take a look at adding the British Grid. Shouldn't be an issue.
Cheers,
Charlie
Privateer
PostPosted: Thu Jun 03, 2004 11:28 pm    Post subject: Reply with quote
Hi Charlie,
Thanks for looking into adding the British Grid.
I guess that GPS Sentry uses the WGS84 Map Datum. Unfortunately Ordnance Survey (OS) paper maps use a different one called OSGB36. The full description I’ve taken from an OS paper map is: Base map constructed on Transverse Mercator Projection, Airy Spheroid, OSGB (1936) Datum Vertical datum mean sea level (Newlyn).
Would it be possible to add a user switchable function in the settings of GPS Sentry to add (or remove) a “shift” on the co-ordinates to allow for OSGB36 when using OS paper maps and thus keeping maximum accuracy in transferring your indicated physical position to the map and vice versa?
Also when using a GPS unit you will get a 10-digit reading (not including the 2 letter 100,000 metre grid square identification) and a theoretical accuracy of 1 metre. However when using a paper map, the best you can hope for is an 8-digit reading with a theoretical accuracy of 10 metres. If you’re using a smaller scale map then you might only have a 6-digit reading with a theoretical accuracy of 100 metres. The following are all the same location but different accuracy:
ST 12345 67890 (10-digit, down to 1 metre)
ST 1234 6789 (8-digit, down to 10 metres)
ST 123 678 (6-digit, down to 100 metres)
Could you also provide a user option of 6-digit, 8-digit, or 10-digit display of the OSGB format?
Robert.
CharlieCassidy
PostPosted: Fri Jun 04, 2004 3:30 pm    Post subject: Reply with quote
Since I've got to compute the OSGB36 anyway to give an accurate British Grid reading, it will be easy to have the option of displaying the L/L using the OSGB36 datum.
Ditto on the accuracy issue. The only reason I didn't do that when I implemented the UTM/MGRS display was I was running out of space in the options dialog. I needed to implement property pages there first. Now that I've done that (V1.6) adding more options like this is a lot easier.
- Charlie
24.034 (25 Mar 26)
