| Author |
PAULBROM Occasional Visitor
Posted: Mon Jun 02, 2008 4:20 pm Post subject: New window mount |
Can anyone recomend a new window mount for the TT 510 the genuine one wouldn't hold the unit up when the sun was shining,then it snapped behind the suction cup.
So any advice on replacement would be greatful |
| Back to top |
GJF Frequent Visitor
Posted: Mon Jun 02, 2008 5:07 pm Post subject: |
It's not just the sun, they are even worse on a cold winter screen.
If you had an accident the Sat Nav would be looking for somewhere to land, not good for you or your passengers.
Try the Brodit Mount
The Brodit mount bracket fixes to the dashboard fascia rather than on the top of the dash.
You can easily take the unit with you when leaving the vehicle. The holders can be adjusted in order to avoid light reflection on the screen.
When i first used it i found it strange at a lower position, but it not only keeps your screen visible, it can't be seen so easily by thieves.
Once you get used to it's position, i now find it easier to touch and view, so easier to use. _________________ TomTom Go 60
Garmin Nüvi 660, Firmware v4.90
Drive-Smart GPS with Loader v1.4.16
HTC Advantage X7500 MS 6.1 Tchart Speed Sentry
Satmap Active 10, Software v1.16
Fuzion 32 HUD Bluetooth GPS receiver |
| Back to top |
Darren Frequent Visitor
Posted: Mon Jun 02, 2008 5:12 pm Post subject: |
I'm not sure Brodit ever offered an x10 mount because of the peculiarities fo that models mount design. _________________ Darren Griffin |
| Back to top |
Posted: Mon Jun 02, 2008 5:16 pm Post subject: |
I think you need to contact TomTom support as this might be still covered by the two year waranty, 0845 161 0009 and see what they can offer, they did exchange quite a few mounts in the days of the x10 products so they are aware of droopy mounts etc.
The only Brodit solutions were home made affairs which combined the TomTom connector with other parts, AFAIK there were no third party solutions to this problem - Mike |
| Back to top |
Posted: Mon Jun 02, 2008 5:19 pm Post subject: |
RAM-Mounts had an alternative although I'm not sure where the original mount fits in and I just found this whilst searching? _________________ Darren Griffin |
| Back to top |
Posted: Mon Jun 02, 2008 5:40 pm Post subject: |
Thanks for your help lads  |
| Back to top |
john877 Lifetime Member
Posted: Mon Jun 02, 2008 7:25 pm Post subject: |
| mikealder wrote: | I think you need to contact TomTom support as this might be still covered by the two year waranty, 0845 161 0009 and see what they can offer, they did exchange quite a few mounts in the days of the x10 products so they are aware of droopy mounts etc.
I queried the warranty period on the Tomtom 520 with tomtom support there answer is below
| Quote: | Thank you for contacting TomTom Customer Support
The device is covered for 2 years. The accessories like the mount and charger are covered for 1 year.
With Best Regards |
whether the warranty period changed between the Tomtom 510 and the Tomtom 520 I do not know |
| Back to top |
Anita Pocket GPS Moderator
Joined: Mar 15, 2006 Posts: 3219 Location: Windlesham, Surrey
Posted: Mon Jun 02, 2008 7:34 pm Post subject: |
| john877 wrote: | | whether the warranty period changed between the Tomtom 510 and the Tomtom 520 I do not know |
The Limited Warranty document in the Licences folder on my 720 states it's for one year only:
| Quote: | "WHAT THIS WARRANTY COVERS
1) TomTom International B.V. (“TomTom”) warrants to you that the Hardware will be free from defects in workmanship and materials under normal use (“Defects”) for a period of one (1) year from the date that the Hardware was first purchased by you (“Warranty Period”). During the Warranty Period the Hardware will be repaired or replaced at TomTom’s choice (“Limited Warranty”) without charge to you for either parts or labour. This Limited Warranty covers the replacement of the Hardware only" |
_________________ Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21 |
| Back to top |
Posted: Mon Jun 02, 2008 8:45 pm Post subject: |
| Anita wrote: | | john877 wrote: | | whether the warranty period changed between the Tomtom 510 and the Tomtom 520 I do not know |
Yes I take your point but that is what Tomtom support said to me by email also John Lewis states that a 2 year warranty
This has been discussed on a previous thread
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=64837&highlight= |
| Back to top |
Posted: Mon Jun 02, 2008 9:10 pm Post subject: |
x10 devices, original One and One XL state 2 years in the license files on the device, the newer units, x20, x30 One Third Edition state one year so it looks like they have reduced the duration of the warranty, if in doubt check the licenses folder on the device and open the relevant document for your region.
If the retailer offer an extended warranty over and above that offered by the manufacturer then any issue would have to be taken up with the retailer - Mike |
| Back to top |
Posted: Tue Jun 03, 2008 9:48 am Post subject: |
| Darren wrote: | | I'm not sure Brodit ever offered an x10 mount because of the peculiarities fo that models mount design. |
Sorry your right, I can remember them telling me that they did mounts for all Sat Navs so i went on that instead of checking.
PAULBROM - I rang them today and they said they couldn't make a mount for the TT 510 model as the electrics clip was large and heavy.
It was suggested that many owners were getting around this by buying a Brodit mount and then glue or screw a round perspex disc to it, then fix the existing suction cap to that.
The advantage is that it will remove the need to stick to the glass (hot & cold problems), in an accident the unit will be safer as it is lower and you can conceal all your cables.
I hope that helps. _________________ TomTom Go 60
| Back to top |
Posted: Tue Jun 03, 2008 9:53 am Post subject: |
The trouble is, the issue with the x10 was the mount itself which couldn't support the device without drooping so that solution wouldn't really help and in this case, the OP's has broken anyway. One of the solutions I linked to above gives an alternative mount to the original supplied.
Another possibility which I used was to cannibalise an existing 910 mount and use parts from a RAM Mount to make a hybrid retaining the electronics module but adding a RAM suction base. And another option is to use the desk mount, I know at least one of our team used this and screwed it to a bracket. _________________ Darren Griffin |
| Back to top |
| Back to top |
