Pocket GPS World :: View topic - replacement screen covers-different from original
andyb2
PostPosted: Thu Jun 12, 2008 2:14 pm    Post subject: replacement screen covers-different from original Reply with quote
I've purchased a set of replaceable screen covers as the original was really scratched after three week (and so is the internal screen which is REALLY annoying)
The replacement ones are clearly inferior. They lack the foam spacer strips so they rub on, and futher scratch, the internal screen.
And they are not clear. The surface on the front and rear is mottled and uneven. This both looks horrible and reduces visibility.
Anyone else noticed this?
I have emailed Satmap, but so far no reply. Sad
LostMike
PostPosted: Thu Jun 12, 2008 3:01 pm    Post subject: Reply with quote
Sorry this is not going to be any help but I am intrigued by your post. Might the mottling be a non reflective finish intended to give better visibility in bright light?
Also I noted some time ago someone suggesting putting screen protector film on the inner screen. Has anyone tried this it sounds like a good idea to me.
LostMike
Satmap A10. Platform 21
Software version 1.5.9193
Satsync 1.525
cosmiccowboy
PostPosted: Thu Jun 12, 2008 3:35 pm    Post subject: Reply with quote
Hi AndyB2. Having just read your message about the scratches on your Satmap screen, I wondered if the following would help restore the screen to it's new condition before using a screen protector.
Scratch remover.
http://www.disagu.co.uk/product_info.php/info/p2_DISPLEX--Display-Scratch-Remover---DISPLEX--Display-Scratch-Removal.html/XTCsid/2e22ab43079372629ac5f0390975de64
Cosmic
andyb2
PostPosted: Thu Jun 12, 2008 3:56 pm    Post subject: Reply with quote
i have thought of polishing the screen. it does seem incredibly soft.
what happened was i was out walking in the rain.
the rain carried in some grit and rubbed holes into the screen.
the screen is far softer than this on mobile phones or garmin gps units.
i don't want to put a screen saver on as that is a further layer obscuring the screen.
i don't think the mottling is an anti reflective coating - if it is it's a very shoddy coating as it is lumpy and bumpy.
still no reply off satmap - i supplied them a photo of the problem
jonesbach
PostPosted: Thu Jun 12, 2008 5:07 pm    Post subject: Reply with quote
From reading posts and my own experience e-mail to Satmap tend to fall into a Black Hole. Suggest a phone call. As it happens I'm expecting a set to be delivered from Amazon - hopefully tomorrow. I'll report on their state when they arrive.
PostPosted: Thu Jun 12, 2008 6:29 pm    Post subject: Reply with quote
I think a similar thing was reported a while back and the user hadn't removed the clear (ish) plastic protection film applied by the manufactures, can you make sure there is no protective film on either side of the new cover? - Mike
andyb2
PostPosted: Thu Jun 12, 2008 9:50 pm    Post subject: Reply with quote
i have removed the film from both front and back - and checked the other two covers. they also are mottled.
i can provide photos if required.
still no reply off satmap Crying or Very sad
jonesbach
PostPosted: Fri Jun 13, 2008 12:34 pm    Post subject: Reply with quote
I have just received a set of screen covers this morning. Inside the Amazon packaging -
    The box was sealed in a plastic bag.
    Inside the box each screen was separated by a cardboard partition.
    Each screen had its own plastic envelope.
    Each screen had protection film on both sides.
There was no sign of any blemish on the screens once the protection was removed.
I would suggest you phone Satmap as obviously you've received a duff batch.
andyb2
PostPosted: Fri Jun 13, 2008 12:48 pm    Post subject: Reply with quote
thanks for that - i'll get onto satmap
incidently do the replacement screens have the foam spacer strips on the rear?
thanks
andyb2
PostPosted: Fri Jun 13, 2008 4:58 pm    Post subject: Reply with quote
I've contacted the retailer who has no more stocks and advised that i contact satmap for replacement.
satmap (unlike the retailer) is still not responding to emails!!!!
jonesbach
PostPosted: Fri Jun 13, 2008 9:37 pm    Post subject: Reply with quote
No foam strips on rear. Suggest you try Amazon, while the price is the same as quoted by Satmap they can be sent free delivery if you are prepared for a short delay. As at 21:35 they were still being shown as in stock.
drpeej
PostPosted: Sun Jun 15, 2008 11:23 pm    Post subject: Reply with quote
I am thinking of protecting my screen using a PDA screen protector. However I am not sure which one to get as all the on-line sites seem to specify them by PDA model rather than size.
Does anyone else have any experience of using these and can anyone suggest which size to go for?
Peter
PloddinPedro
PostPosted: Mon Jun 16, 2008 7:13 am    Post subject: Reply with quote
drpeej wrote:
... a PDA screen protector ... which one to get ....... which size to go for?
The ones I use have no brand name but are described as: "For use on PDA HP 565, 568 and iPAQ 1900 & 2200 series". They measure 55mm x 73mm and just cover all the usable Satmap screen area.
notmyname
PostPosted: Mon Jun 16, 2008 3:31 pm    Post subject: screen protector Reply with quote
Ploddinpedro - can you tell me who you ordered the screen protector from - I have tried 2 places on the web without sucess
thanks Alan
PloddinPedro
PostPosted: Mon Jun 16, 2008 3:53 pm    Post subject: Re: screen protector Reply with quote
notmyname wrote:
Ploddinpedro - can you tell me who you ordered the screen protector from - I have tried 2 places on the web without sucess. thanks Alan
I've had mine so long I can't remember where I got them! But if I needed more I would probably go to:
http://www.ipaqrepair.co.uk/store.php?cat_id=97&catname='iPAQ%202200%20Series'
or:
http://www.pdahut.com/store/home.php?cat=507
Mine are cheap and use once only. The modern ones seem to be washable and re-usable, which looks better to me, but I haven't used these (yet).
24.041 (01 Apr 26)
