| Author |
sven1 Regular Visitor
Joined: Jun 26, 2005 Posts: 131 Location: Norwich, U.K
Posted: Tue Jun 17, 2008 10:53 am Post subject: Getting a 920 of the windscreen mount |
this seems quite hard. is there a trick to it or do I just slide it off using as much force as necessary! Not keen to break it!
Jon |
| Back to top |
Darren Frequent Visitor
Posted: Tue Jun 17, 2008 11:09 am Post subject: |
Should just slide off with little force required? _________________ Darren Griffin |
| Back to top |
dhn Frequent Visitor
Posted: Tue Jun 17, 2008 11:50 am Post subject: |
| The 920 mount is the same as a 720. I find holding the neck of the mount with one hand and with the thumb of the other hand on one side of the unit and the fingers on the other and then giving the unit a little rock side to side while applying upward pressure should do it. |
| Back to top |
Posted: Tue Jun 17, 2008 12:43 pm Post subject: |
cheers both. as long as thats the way it is and i'm not missing any magical release button!
Jon |
| Back to top |
Posted: Tue Jun 17, 2008 12:46 pm Post subject: |
| sven1 wrote: | | cheers both. as long as thats the way it is and i'm not missing any magical release button! |
You aren't pressing the release button
Good cos there isn't one  _________________ Darren Griffin |
| Back to top |
GPS_fan Pocket GPS Moderator
Joined: Jan 04, 2007 Posts: 2789 Location: Hampshire, UK
Posted: Tue Jun 17, 2008 12:52 pm Post subject: |
| Darren wrote: | Good cos there isn't one  |
Mine has one
Thumb underneath pushing TT up and fingers pushing down against mount works for me  _________________ Andy
PocketGPSWorld.com supports Help for Heroes - Read here |
| Back to top |
Andy_P Pocket GPS Moderator
Posted: Tue Jun 17, 2008 2:37 pm Post subject: |
| It gets easier with time.... |
| Back to top |
Posted: Tue Jun 17, 2008 3:04 pm Post subject: |
| Andy_P wrote: | | It gets easier with time.... |
Uh, what does?  |
| Back to top |
Posted: Tue Jun 17, 2008 4:02 pm Post subject: |
| I was going to say "it rides up with wear"! |
| Back to top |
shadamehr Banned
Posted: Tue Jun 17, 2008 11:00 pm Post subject: |
As has been said, it both gets easier, and softer to acheive (removing it from the mount, before the innuendos start again ) over time.
But, if it helps, let me share my method - and it's a one handed method at that.
What I do, is wrap my thumb under the BOTTOM on the device, and my four fingers over the top of the TomTom.
Then, I press with my middle two fingers, down onto the top of the neck of the mount further round, over the back of the device where i placed them. At the same time, I press UP with my thumb.
And I find that doing this, pushing the device up with the thumb, and in effect PULLING the device up by pushing down on the mount neck/up and away with the device, using my fingers over the top, makes it a doddle to get it off.
Practice this, and you'll get it - the key is the bit with the fingers though - getting them over the top, and using the middle two to press onto the mount neck, to use this to propel the device UPWARDS away from the mount.
Once you do, you can reverse the principle, and come to be adept at getting it ON with one hand too. |
| Back to top |
playswell Regular Visitor
Posted: Sun Jun 22, 2008 12:13 pm Post subject: two handed |
| shadamehr wrote: | As has been said, it both gets easier, and softer to acheive (removing it from the mount, before the innuendos start again ) over time.
I use the two handed method myself............ easier and a quicker release |
| Back to top |
Calomax Lifetime Member
Posted: Sun Jun 22, 2008 4:44 pm Post subject: |
My 720 just slides on & off with one hand. No need to hold the mount at all. The only thing that's a little awkward is lining it up in the first place. _________________ TT Go Essential |
| Back to top |
| Back to top |
