| Author |
Posted: Sat Oct 11, 2008 8:19 am Post subject: |
The usual problem with this is when the ogg file name and POI file name don't match, you must have a matching set for the device to pick up ogg audio files.
For example each camera category will have at least three files like this:
pocketgps_uk_mobile_30.ogg
pocketgps_uk_mobile_30.ov2
If you have the Speed Zoned camera files make sure you download and install the Speed Zoned ogg file set - Mke |
| Back to top |
jono4000 Regular Visitor
Posted: Sat Oct 11, 2008 11:06 pm Post subject: |
| mikealder wrote: | The usual problem with this is when the ogg file name and POI file name don't match, you must have a matching set for the device to pick up ogg audio files.
Okay as always mike appreciatte your advice, unfortunatly no further forward in getting around this particular problem,
as I say have tried deleting the OGG files that were on the TOMTOM and putting on a fresh set, using zoned camera and zoned type OGG files but still they are not recognised.
any other ideas ?? |
| Back to top |
dhn Frequent Visitor
Joined: Oct 08, 2007 Posts: 2544 Location: Toronto CANADA
Posted: Sun Oct 12, 2008 12:55 am Post subject: |
Tried a pin reset? _________________ David |
| Back to top |
Posted: Sun Oct 12, 2008 9:35 am Post subject: |
| dhn wrote: | | Tried a pin reset? |
Okay thanks also for your suggestion, did think about this but not too sure what else I would loss in the process, any advice ?? |
| Back to top |
Posted: Sun Oct 12, 2008 9:43 am Post subject: |
| You won't loose anything following a pin reset, look at the base of the device and you will find the reset hole. Doing this doesn't wipe settings/ data all it does is force the device to stop and then re-load the software next time you switch it on - Mike |
| Back to top |
Posted: Sun Oct 12, 2008 1:00 pm Post subject: |
| Guess what ?? all working thanks to the reset idea. thanks again. |
| Back to top |
Boxbrownie Lifetime Member
Joined: 22/03/2003 16:18:25 Posts: 128 Location: United Kingdom
Posted: Wed Oct 15, 2008 9:40 am Post subject: |
I tried installing the voice warning today...TT OneXL....nothing at all....using the consolidated OV files, picked the consolidated Voice files and placed them in the map folder (ie Europe 1gb) and they are all there, but when I try to enable the alerts through POIs management no custom voice warning are shown only the original TT crappy beep/bell/siren/cow! sounds......I thought I followed the instructions corrorectly as they are pretty simple, I guess I must be even more simple as I cannot get them going!
Best regards David |
| Back to top |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10645 Location: Suffolk, UK
Posted: Wed Oct 15, 2008 11:23 am Post subject: |
As above, 'Have you tried a pin reset'? _________________ Richard
TT Via 135 App 12.075: Europe Map v1165 |
| Back to top |
Posted: Wed Oct 15, 2008 4:38 pm Post subject: |
Yes.....as I read this thread before I added the voice I tried reset twice but still no voice in the menu....odd thing is though on the way home the voice came up as a warning as it should I guess......but still no option to choose it in the menu
Never mind its working, but BOY!! the voice quiet....might go back to a siren anyway!  |
| Back to top |
Andy_P Pocket GPS Moderator
Posted: Sat Oct 18, 2008 1:36 am Post subject: |
| Boxbrownie wrote: | .....but still no option to choose it in the menu |
That's exactly how it works.
Don't know what instructions you found, but the ones on the voice download page say:
| Quote: | # Warn when near POI (this MUST be done even if your camera POI’s have been previously configured).
# Select the first camera in the list, if asked whether you want to delete or remove the warning answer NO.
# You should now be asked to select the warning distance, followed by the Warn Only if POI on route – please set-up these options as per your normal preference, remember everyone will use different settings dependent upon how they use the device. |
(Note NO mention of choosing a sound from the menu - it should skip that step).
And:
| Quote: | Version 7/8 Note:
......you will be asked to choose a sound but will not be offered any options, this is normal. You will be asked 'Is this the sound you want?'. You should answer Yes on this screen. |
If you want to have the normal menu to choose options of sounds to choose from, use the alternative method HERE
It's worth trying some of the other voice packs. Although they have been boosted as much as possible, some do "cut through" better than others. |
| Back to top |
Posted: Sat Oct 18, 2008 10:26 am Post subject: |
Great thanks for that reply, makes complete sense now.....I did not of course read the instructions so carefully......oops!
I will try some other voices, although I am finding in practice the voice stands out a bit better than a siren/bell (even if it is a lower volume) I guess we are used to "listening" to voices rather than electronic beeps and screeches!
| Back to top |
Posted: Sun Oct 19, 2008 11:15 pm Post subject: |
Try one of the ones with a siren at the front of the voice announcement... best of both worlds!  |
| Back to top |
| Back to top |
