| Author |
ccsnet Regular Visitor
Posted: Tue Sep 23, 2008 10:15 am Post subject: Trafficmaster TMC Coverage |
Does any one have a definitive coverage list of Traffic Master TMC ? All they seem to have is a list of companys and not statations on their web site......
I'm asking because I have just swicthed from ITS to TM with my new car disk ( its an OEM one ) and while the data may be better the reception is poor..... I just want to see where I get it from.
TIA
Terran _________________ http://www.letscommunicate.co.uk/carpc/ |
| Back to top |
Posted: Tue Sep 23, 2008 8:19 pm Post subject: |
This image might be a little out of date but it shows where the transmitters were located towards the end of last year:
I also have a POI File detailing the locations which can be used on Garmin devices, but your built in system might not be able to read the data? unless it supports third party POI files - Mike |
| Back to top |
Pocketgps Lifetime Member
Joined: Nov 16, 2004 Posts: 2145 Location: Midlands, UK
Posted: Wed Sep 24, 2008 12:23 am Post subject: |
Where can the TMC POI be found for download.
Thanks |
| Back to top |
Posted: Wed Sep 24, 2008 12:35 am Post subject: |
You should have e-mail containing the file - Mike |
| Back to top |
Posted: Wed Sep 24, 2008 9:36 am Post subject: |
Mike, thats fantastic..... I wounder if I could also have a copy of the POI file.... and may be if you have it one for ITS transmitters so I can compaire the two ?
Was this some thing you made your self or is there a data source you can share at all ?
Terran | mikealder wrote: | This image might be a little out of date but it shows where the transmitters were located towards the end of last year:
BTW This sort of thing would be highly useful to others too.... could I suggest you stick it on the main page of this site too some where ? _________________ http://www.letscommunicate.co.uk/carpc/ |
| Back to top |
Posted: Wed Sep 24, 2008 10:01 am Post subject: |
| I have posted the maps up on the site on a few occasions, I created the list of Transmitters when I first started using the RDS TMC system with my TomTom, so once that was complete I decided to do the same for the TM - finding out the information isn't too easy though and I would expect the lists to both be a little out of date - I will send you what I have got its in Excel format if thats ok? - Mike |
| Back to top |
Posted: Wed Sep 24, 2008 10:11 am Post subject: |
| mikealder wrote: | | I have posted the maps up on the site on a few occasions, I created the list of Transmitters when I first started using the RDS TMC system with my TomTom, so once that was complete I decided to do the same for the TM - finding out the information isn't too easy though and I would expect the lists to both be a little out of date - I will send you what I have got its in Excel format if thats ok? - Mike | Mike - thanks for that.... may be it could be a new POI set for the Free POIs ?
| Back to top |
Posted: Wed Sep 24, 2008 10:30 am Post subject: |
The main use for the data file on the TomTom is explained in This Thread.
I never uploaded the data to the site as people could very easily download the wrong file set (not everyone knows the difference between TM and iTIS) - The files would be of very limited use as the aerials tend to be on large hills in the middle of nowhere, you certainly could navigate to one! And to make sure of the accuracy I would have to re-check the whole lot again - if iTIS / TM would offer the transmitter list to start with (all I got last time was the radio station and frequency, but you can work the rest out from that) - Mike |
| Back to top |
Posted: Wed Sep 24, 2008 12:35 pm Post subject: |
| mikealder wrote: | You should have e-mail containing the file - Mike |
Thanks Mike.
Best regards, |
| Back to top |
gem Regular Visitor
Posted: Wed Jan 28, 2009 9:46 pm Post subject: |
Could I have a copy of this TM and iTIS points of interest file.
I remain rather astonished that 99% of the UK can't be covered for TMC and around Glasgow it cuts out about 4-5 miles to the west of the airport.
Classic FM is the station that NavMan used and Garmin may be the same as the location to start/end coverage is almost identical.
Garmin use TrafficMaster however. I thought NM on Classic FM would have been iTIS.
And there (on Garmin anyway!) was no coverage from 10 miles south of Glasgow until well past the Lake District. This is useless.  |
| Back to top |
Posted: Wed Jan 28, 2009 10:37 pm Post subject: |
Files sent so you should have mail.
Garmin use the Traffic Master system while TomTom and Navman use the iTIS data which is transmitted via Classic FM and quite a number of additional radio stations within the UK.
If you have a Navman or TomTom you should be picking up the Morecombe Bay station (101,8) while driving through the Lakes though - I do, does your car have an Athermic windscreen? as these are known to mess up reception in a big way, if you use Garmin then I am not too sure there is any coverage for that area at the moment - Mike |
| Back to top |
| Back to top |
