| Author |
pennyandchris Occasional Visitor
Posted: Fri Jun 27, 2008 1:45 pm Post subject: Anyone using Anquet on WM6? |
Anyone using Anquet successfully on WM6?
I've tried on a Smartphone (HP514) and a PPC (Orbit 2).
It'll install, and show maps, but when you try to 'connect to GPS' it just freezes.
Reported this to Anquet customer support and they were no help at all. Suggested other progs were taking over the GPS, which is absolute because I've tried it with nothing else installed.
Any advice appreciated. |
| Back to top |
CaptainZed Occasional Visitor
Posted: Mon Jun 30, 2008 1:36 pm Post subject: I am running it without a problem |
| I am using a mio P360, rather than a mobile. Runs fine for me (certasinly better than on my old Mio 168) |
| Back to top |
philpugh Lifetime Member
Posted: Mon Jun 30, 2008 10:28 pm Post subject: Re: Anyone using Anquet on WM6? |
| pennyandchris wrote: | Anyone using Anquet successfully on WM6?
You aren't using the GPS 'sharing' applet on WM6 are you? If so - disable it and use the native GPS port.
Also check with the mobile phone manuf that they aren't 'interfering' with the connectivity of the internal GPS.
Does any other satnav s/w see the GPS? _________________ Phil |
| Back to top |
Posted: Wed Jul 02, 2008 8:11 am Post subject: Re: Anyone using Anquet on WM6? |
| philpugh wrote: |
Does any other satnav s/w see the GPS? |
I've not installed a GPS 'sharing' applet. If it's native to WM6, where might I find it to disable?
Memory Map and A-Z (and CoPilot) work fine with standard settings - NMEA0183, 4800 baud rate, COM4 I think |
| Back to top |
Posted: Wed Jul 23, 2008 7:54 am Post subject: Anquet 6.2.5.0 still useless to me |
Just installed 6.2.5.0 on my PC, and EVEN with this version, it doesn't work properly with Windows Mobile 6 on my XDA Orbit 2.
The maps load, and open up ok, but when I try to configure GPS it still just hangs. I'm using GPS settings as follows: COM4 NMEA 0183, 4800 baud rate. It works fine with A-Z, Memory Map and Co Pilot.
I've ensured that nothing else is running and using the GPS, but it still hangs. Makes the Anquet software useless to me. |
| Back to top |
Posted: Thu Jul 24, 2008 11:22 am Post subject: Now working |
Contacted Anquet support again and this time they suggested loading GPSGate - apparently some HTC phones with inbuilt GPS use a different encoding for the GPS signal - did this and it works!
All programs (A-Z, Anquet, MM, Co Pilot) can now use the in-built GPS without problems - and it seems to get a fix quicker |
| Back to top |
nick789uk Regular Visitor
Posted: Wed Nov 12, 2008 2:10 am Post subject: Using Anquet on WM6.1 |
| Hi am using it on windows mobile 6.1 on the W800 with built in GPS and it is working ok, also works with external gps, memory map also works fine and QUO working but trying to get to grips with QUO. |
| Back to top |
| Back to top |
