| Author |
pello Occasional Visitor
Joined: 25/01/2003 18:43:46 Posts: 30 Location: London, UK
Posted: Fri Jan 09, 2004 6:05 am Post subject: Good news for GPSmart BT users |
Although only in beta at this time the "Fortunasync" program allows you to connect to the GPS from your PC using the proprietory USB to Serial cable which incidentally uses a Prolific driver. With this app. you can upload firmware updates, waypoints, routes etc. as well as being able to set all the menu options to configure your GPS. An unpublished fact came from my tinkering though, I managed to switch the unit into SiRF mode by accident & had a problem getting it back to NMEA. I wasn't aware this unit had a SiRF mode, it's not in the specs. or advertising. I wonder if the manufacurers know  |
| Back to top |
Dave Frequent Visitor
Posted: Fri Jan 09, 2004 8:47 am Post subject: |
| 90% of GPS's use the SiRF chipset, so should be switchable to SiRF. |
| Back to top |
Philip Regular Visitor
Joined: 12/09/2002 14:25:05 Posts: 141 Location: Hampshire, United Kingdom
Posted: Fri Jan 09, 2004 10:46 pm Post subject: |
The specs for the GPSmart on the Fortuna website certainly mentions SiRF.
Where did you get the Fortunasync program from? _________________ Philip |
| Back to top |
Posted: Sat Jan 10, 2004 2:32 am Post subject: |
Yes you are right, I missed that ref. completely however I was going by the manual that came with my unit & there was no mention there. Also with the advantage of a display & menu opton on the receiver itself it would have been nice to see an option to switch there, perhaps this is an item I could send them for the user wish list?
The "Fortunasyc" can be downloaded from this link.
Peter |
| Back to top |
Posted: Fri Jan 23, 2004 1:24 pm Post subject: |
Thanks for the link!
http://www.fortuna.com.tw/Support.htm currently has firmware upgrades (dated "2004/1") for the GPSmart and GPSmart BlueTooth. However (like Fortunasync) they have Beta in their names, so I'm a bit reluctant to load them.
I can't find any mention of what's included/changed in the new firmware - sadly, the Fortuna website is not exactly the most informative in the world :-(
Anybody have any more info? Dave - do you have a contact at Fortuna who could clarify? _________________ Philip |
| Back to top |
Posted: Fri Jan 23, 2004 1:49 pm Post subject: |
| Unfortunately not, we've tried to open communication with Fortuna but not received any responses to our emails. |
| Back to top |
bowser Occasional Visitor
Posted: Mon Mar 22, 2004 2:34 am Post subject: FortunaSync |
| Does anyone knows how to work with the FortunaSync properly? How can I download all waypoints and tracks? And upload them? All I can do is to change the GPS settings and renaming some Marks, Routes and Waypoints. I also can add a new waypoint but whenever I try to create a new mark I get an “run-time error (6) Overflow” and then FortunaSync crashes… By the way, what’s the difference between Marks and Waypoints? |
| Back to top |
gpsheppard Occasional Visitor
Posted: Tue Jun 01, 2004 6:03 pm Post subject: |
| Quote: | | An unpublished fact came from my tinkering though, I managed to switch the unit into SiRF mode by accident & had a problem getting it back to NMEA |
Okay, so can anyone tell me how to reset mine back to NMEA? I'm having problems synchronising with various software, and I think this might be the problem. I have been able to establish that my GPS is currently in SiRF mode.
Thanks.[/quote] |
| Back to top |
Posted: Thu Jun 03, 2004 11:40 pm Post subject: |
I have just upgraded my GPSmart from 2.25 to 2.26 and am having problems connecting to my XDA2. I wonder if I am in SiRF mode?
1) How can you tell if you are in SiRF mode?
2) How do you change between SiRF and NMEA? _________________ Philip |
| Back to top |
Posted: Sat Jun 05, 2004 11:07 am Post subject: |
Sorry to follow up my own posting, but just in case anybody is searching the archives to find out how to change the GPSmart from SiRF to NMEA (e.g., after using FortunaSync) ...
All you need to do is to remove the batteries for a few minutes and it will reset itself to NMEA. _________________ Philip |
| Back to top |
micken Occasional Visitor
Posted: Sat Jun 05, 2004 1:09 pm Post subject: |
Philip I am a :D xdaII user thinking of buying the Fortuna clip-on and came across this thread. What navigation software are you using and what are your thoughts on it?
I am going to France this summer and I have seen Fortuna/PrymeNav bundled for a very good price.
I might go for this and then upgrade to Co-pilot v.5 when that arrives.
Happy navigating. |
| Back to top |
Posted: Sat Jun 05, 2004 1:49 pm Post subject: |
| Quote: | | All you need to do is to remove the batteries for a few minutes and it will reset itself to NMEA |
that easy huh? Thx. |
| Back to top |
scatter Occasional Visitor
Posted: Wed Jun 09, 2004 8:20 am Post subject: GPSmart NMEA and Sirf |
Anyone having done a firmware upgrade (e.g. 2.24UK to 2.26) should've been aware that Sirf and NMEA modes are available and can be switched. The "Sirf Demo.exe" program provides these facilities.
FortunaSync leaves the GPSmart in Sirf mode, so Sirf Demo it normally used to switch it back.
FortunaSync is still in Beta, and quite erratic (especially on input format checking ... runtime error). It does leave a memory dump file on the PC however, so with some clever program + a data-structure from this dump, the up/download facilities can be made.
The actual up/download is done through the sirfflashcl.exe program.
Currently it seems the people at Fortuna are not being very responsive, I'm not seeing any progress on their end. |
| Back to top |
DeeJay Occasional Visitor
Joined: Feb 05, 2004 Posts: 13 Location: Near to: 52.6360 / -1.1325
Posted: Wed Jun 09, 2004 12:14 pm Post subject: |
"FortunaSync is still in Beta, and quite erratic (especially on input format checking ... runtime error). It does leave a memory dump file on the PC however, so with some clever program + a data-structure from this dump, the up/download facilities can be made. "
I agree with the observations about FortunaSync crashing with input errors.
I don't think what I have done is particularly clever, and I might have misunderstood some parts of the data-structure (which is not documented by Fortuna) but I HAVE just finished the first phase of a program which is able to extract Waypoint and Trackpoint information from the READFILE.FEC memory image created by the run of SiRFflashCL that is spawned by FortunaSync. The program is a text-console application for Win32, developed under WinXP-Home, but also tested on Win2K-Pro.
The Waypoint and Trackpoint coordinates are written to a simple text file in CSV format, in a form that can be easily read by 'GPS_Utility' - see: www.gspu.co.uk.
I do not feel ready to release this code for use by others yet, but would like to have other copies of READFILE.FEC to examine. (At the moment I have a sample of 2 - my own, and the example shipped with FortunaSync.)
So, if you have installed and run FortunaSync and have a copy of READFILE.FEC containing the memory image of your own GPSmart, and would like a transcript of the Waypoints and Tracks, would you consider zipping it up and emailing it to me, as an attachment, at the email address (suitably modified) in my signature below?
In return I will send you back a copy of the CSV text file with the information that I find in the memory image. I do not intend to use the information you provide for any purpose other than refinement of my code, but if your location or movements are the least bit sensitive I suggest you do not accept this offer.
At a later stage I hope to develop the code further so that routes planned using well-known PC-based GPS applications can be encoded into a new copy of READFILE.FEC for subsequent upload back into the GSPmart - but that depends on, among other things, fully understanding the memory data structures, so may be some time yet! |
| Back to top |
Posted: Wed Jun 09, 2004 12:18 pm Post subject: |
Sorry to follow-up on myself, but the setting 'always attach my signature' seems to have been ignored! Hopefully it WILL be on this one? _________________ DeeJay
Leicester, UK
e: PktGPS ["AT"] DavidRoberts.Org.UK |
| Back to top |
| Back to top |
