Pocket GPS World :: View topic - DELL hidden HD partition
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Lost Satellite Fix - Off Topic Area
Pocketgps
PostPosted: Wed Dec 03, 2008 1:32 am    Post subject: DELL hidden HD partition Reply with quote
I have a DELL XPS 420 running Vista. For some reason or other I cannot get it start the Dell System Diagnostics hidden partition Crying or Very sad has always worked in the past.
Could someone have a look on:
Control Panel - System and Maintenance - Administrative Tools - Computer Management - Disk Management
and see if it compares with mine:
Screen shot here (image will open in a new window)
Mine shows the hidden partition, but say it is empty/free
Also does it say anything against File System
Note: all Dell systems will have the hidden partition, may not be the same size as shown on mine, depends on the hd size etc.
Pocketgps
PostPosted: Wed Dec 03, 2008 7:09 pm    Post subject: Reply with quote
Come on Dell users, help me out Crying or Very sad
alix776
PostPosted: Wed Dec 03, 2008 7:18 pm    Post subject: Reply with quote
make sure you can see all hidden files i very much doubt its empty
device Lumia 950 xl
Mullet
PostPosted: Wed Dec 03, 2008 7:27 pm    Post subject: Reply with quote
I dont have a Dell but posted screen shots show contents of several MB. Stating the obvious, it seems empty.
Anything happening when booting with f12?
Is the partition listed under system restore and is a restore point available?
Pocketgps
PostPosted: Thu Dec 04, 2008 3:05 pm    Post subject: Reply with quote
Its not possible to see the hidden partition or see the files from the normal C: drive. That is normal.
You never get the system restore for that partition. Because it is hidden from you and the normal C: drive.
Using the F12 at boot gives you the option to start via the diagnostics, but it only goes so far and when it should load the Dell System Diagnostics from that hidden partition it just stops. Have to turn off the system and reboot.
There must be someone with a Dell system who can have look to see how it compares with mine.
Mullet
PostPosted: Thu Dec 04, 2008 3:54 pm    Post subject: Reply with quote
Plenty of user screenshots to compare on Google images, as I said, all showing MB in that partition.
mattstachurski
PostPosted: Thu Dec 04, 2008 8:22 pm    Post subject: Reply with quote
My screenshot would almost look identical to yours but shows 2 drives with 100% free space, I've just run complete factory restore worked ok. does pressing the fn key while powering on do the same as f12? that runs diagnostics for me on Inspiron 1525 but may only be on laptops.
PostPosted: Thu Dec 04, 2008 8:29 pm    Post subject: Reply with quote
Am I missing something here? Your screenshot shows the Recovery Partition as 15GB and 70% full which would be about right? The 55MB partition you see as empty is normal, that's just unallocated space on the disk.
PaulB2005
PostPosted: Thu Dec 04, 2008 10:04 pm    Post subject: Reply with quote
Except it should NOT be empty. It's a FAT Partition with Hard Drive Diagnostics on it - usually accessed during boot up if the drive is playing up. Also has Memory Tests and other diagnostics stuff.....
However I'm not sure if the data will shown as used space under Windows. (Don't actually know why i think this - been a long day so far)
Lots of info and headachy stuff here
It's called the Dell Utility Partition
Mullet
PostPosted: Fri Dec 05, 2008 6:18 am    Post subject: Reply with quote
There is a detailed explanation here of the Dell tools. Whist the used disc space is clearly shown in the screenshot, the contents are not accessible through the Windows OS.
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Lost Satellite Fix - Off Topic Area All times are GMT + 1 Hour
23.103 (15 Oct 25)
