| Author |
Anita Pocket GPS Moderator
Posted: Sun Dec 07, 2008 5:53 pm Post subject: Solar panel charger |
Can anyone advise whether this would be suitable for a GO720?
I'm planning a trip to South Africa next year, and am trying to find a cheap alternative charging method in case the ciggy lighter socket in the hire care is faulty. At £4.67 with free worldwide shipping from the US it looks like the ideal solution, but I don't want to risk damaging my TomTom or having it not adequately charged. _________________ Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21 |
| Back to top |
Andy_P Pocket GPS Moderator
Posted: Sun Dec 07, 2008 11:55 pm Post subject: |
So long as it adhered to the USB spec for voltage (which it appears to do) it shouldn't do any damage, but from the figures quoted it might well charge VERY slowly.
Solar battery: 0.4 W
Output voltage: 5.1V
That implies a max current of 0.08 Amps
A standard USB power connection (like on a PC) can provide 0.5 Amps
and a TT cigarette lighter adapter more than that (they are rated at 1 or 2 Amps on the 12Volt DC input.
I'd have thought you'd be better off with a mains charger and international plug adapters (the TT "fast charger"reckons it does a full charge in 2 hours).
Or if you think it has to be kept charged on the road, then a "Heath Robinson" cable with a cigarette lighter socket on one end and crocodile clips to go straight onto the car battery at the other would cover all eventualities.
I keep one in the car for camping trips for charging mobile phones etc. after I changed cars for one that didn't have a permanently powered cigarette lighter socket. |
| Back to top |
253 Lifetime Member
Joined: Mar 05, 2007 Posts: 1058 Location: The green bit between the M40, M4 and M25.
Posted: Mon Dec 08, 2008 12:24 am Post subject: |
Morpeth Mobiles have a 'booster' for about £10, takes 4 x AAA batteries (not included). So you could buy rechargeable batteries and charger from Maplins, and use them. At least you would have a chargeable unit in car.
But a lot of stuff to carry around.
I have seen other solar chargers for mobiles and laptops, but no idea how good they are. I bought one that was supposed to trickle feed a car battery about 4 years ago - it was crap. I think they are still 'touted' in some magazines. _________________ Triumph Tbird 1700. And now a Bonnie T100. |
| Back to top |
Posted: Mon Dec 08, 2008 12:26 am Post subject: |
Thanks for the advice, Andy.
I shall take a mains charger to use overnight, so I start each day fully charged. I had hoped the solar charger would provide enough power to keep the TT running if necessary, but obviously not, so I won't bother.
I shall probably get a usb battery box and take loads of rechargeable AA batteries in case of problems when it just might help a little (and would be useful for the mobile phone anyway), and hope that the ciggy socket in the hire car works. _________________ Anita
UK map 1130.12368
| Back to top |
Posted: Mon Dec 08, 2008 12:33 am Post subject: |
Thanks, 253. It looks as if we were both typing about the same thing at the same time!  _________________ Anita
UK map 1130.12368
| Back to top |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10645 Location: Suffolk, UK
Posted: Mon Dec 08, 2008 7:50 am Post subject: |
A bit more expensive, but something like This might be want you want. _________________ Richard
TT Via 135 App 12.075: Europe Map v1165 |
| Back to top |
AndyBB Lifetime Member
Posted: Mon Dec 08, 2008 8:19 am Post subject: |
| I have got both of the Solar Chargers you are looking at and can support Richard with his comment that the Freeloader may be a better option for you. The freeloader has a rechargeable battery pack inside it which charges up from the solar cells or any mini USB type voltage supply. At a time when the car TT power cord is working or when you can use the mains charger you could also boost up this pack I have just taken mine from the cupboard not used in the last month and plugged it into a TomTom One for you and it looks to be charging it ok. The cheap one I cannot test right now for you ..... it is dark here ! I used the cheap one in brilliant sunlight and it was fussy over what it would and would not charge so I suspect it operates a bit lower than the 5V USB rating. |
| Back to top |
Posted: Mon Dec 08, 2008 8:20 am Post subject: |
Thanks, Richard.
Do you think that would deliver enough power to keep the 720 running if it was fully charged overnight? _________________ Anita
UK map 1130.12368
| Back to top |
Posted: Mon Dec 08, 2008 8:28 am Post subject: |
Thanks, Andy. I've ruled out the cheap one anyway, but if the FreeLoader can be charged via the TT mains charger that looks a possibility. I'll look into it further. _________________ Anita
UK map 1130.12368
| Back to top |
Posted: Mon Dec 08, 2008 8:35 am Post subject: |
It should have a reserve from it's own internal battery, and can supply another 120mA from the Solar Panel at the same time, so it should, in theory, double the battery time.
At a guess.  _________________ Richard
| Back to top |
Darren Frequent Visitor
Posted: Mon Dec 08, 2008 8:53 am Post subject: |
What about the PowerMonkey I reviewed a while back> It has a solar charger AND backup battery with power tips and international adapters, reviewed here. _________________ Darren Griffin |
| Back to top |
253 Lifetime Member
Posted: Mon Dec 08, 2008 9:05 am Post subject: |
| Anita wrote: | Thanks, 253. It looks as if we were both typing about the same thing at the same time!  |
Always the way.
Looks like you have plenty of options!! Spoilt for choice now. _________________ Triumph Tbird 1700. And now a Bonnie T100. |
| Back to top |
Posted: Mon Dec 08, 2008 9:23 am Post subject: |
You're right there, 253!
Thanks for all the help, everyone. Lots to look at and think about.
The PowerMonkey is very tempting, Darren, but sadly I really don't think I can justify spending £65 when, hopefully, the hire car will have a working ciggy lighter socket so I won't need it anyway. _________________ Anita
UK map 1130.12368
| Back to top |
wazzzzupmate Regular Visitor
Posted: Mon Dec 08, 2008 11:37 am Post subject: |
I have the freeloader and would not recommend it to operate the tomtom in the car. It will charge the tomtom, switched off, for about 30 mins. But with the tomtom operational, screen illuminated, you will get a much reduced operational time. _________________ -------------------------
Tomtom Go 400
Tomtom 1.15.1 for Iphone |
| Back to top |
Posted: Mon Dec 08, 2008 11:43 am Post subject: |
I too have a Freeloader and found it pretty poor tbh. The battery pack isn't capable of charging a GPS nor an iPhone or even some of my mobile phones without expiring mid-charge. _________________ Darren Griffin |
| Back to top |
| Back to top |
