Pocket GPS World :: View topic - BT Receiver - to be permanently wired in car
Gasman2
PostPosted: Tue Jan 06, 2009 2:32 pm    Post subject: BT Receiver - to be permanently wired in car Reply with quote
I'm looking for a reasonable BT GPS receiver to go in my car.
Ideally, spec wise:
    Sirf III or MTK
    Mini USB sized power connector.
    Can be connected to a power outlet in the boot (trunk) of my car and left there, to switch itself on and off with the ignition.
Other than that, it just needs to work reasonably!
I think the Holux GPSlim (GR-236) will do what I want, but there don't seem to be many of these around, and those that are, are quite expensive.
Are there any alternatives? I'm in the UK, if that makes a difference.
Many thanks
wiz
PostPosted: Tue Jan 06, 2009 2:55 pm    Post subject: Reply with quote
my BT GPS receiver has been wired in for a year at least and stays on 24 7 it has never missed a beat
RoyalTek GPS Mini X-Treme
Alan --- aka Wiz.
Iphone 4S 16gb, ios 5 windows 7, CamerAlert, CoPilot & TomTom
Gasman2
PostPosted: Tue Jan 06, 2009 3:45 pm    Post subject: Reply with quote
Thanks for the reply - I found a review of the RoyalTek 2200 here after posting the above question. Not as small as the Mini - but as it is likely to spend 95%+ of its life in the car - shouldn't be a problem! And only £23 delivered.
Unless someone comes up with something better - I think I'll probably buy this.
Do you leave the battery in yours, so it is permanently charging and discharging?
wiz
PostPosted: Tue Jan 06, 2009 8:34 pm    Post subject: Reply with quote
I have never taken the batt out..
have moved it to different cars a couple of time for short trips the batt held up no problem, it normally sits in the front under the dash next to the fuse box. works perfectly brilliant reception
Alan --- aka Wiz.
24.034 (25 Mar 26)
