Pocket GPS World :: View topic - Locking up map source with overlay
Taps
PostPosted: Sun Jan 18, 2009 5:45 pm    Post subject: Locking up map source with overlay Reply with quote
Hi, Could any one advise I have a garmin 2610 with the europe map 08 I could install the speed cameras ok until after the end of Dec, it now locks up the map source and quote product 702, may have stated after updating menbership, any Ideas, ps I can reload previous down loads ok
Cheers Taps Confused
WiRED
PostPosted: Sun Jan 18, 2009 5:58 pm    Post subject: Reply with quote
Interesting. I upgraded Mapsource yesterday to the latest version (6.13.4) and when I started it up, I got that message about product 702. However, I closed it down, started it again and it was fine. I've started it several times since and I can't repeat the error, so I put it down to the Mapsource upgrade process.
However, are you saying you have a recreatable failure, which goes away if you use an older version of the maps? If so, I would be interested to know which version of Mapsource you have and which versions of the overlay work and don't work. Also, the path to the folder where you install the Safetycameramap would be helpful as well.
I should point out, I create the overlay map for PocketGPSWorld, so I should be able to help get to the bottom of this.
/WiRED
eyeQue
PostPosted: Sun Jan 18, 2009 6:23 pm    Post subject: Reply with quote
The new Mapsource is v6.15.3
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=73631
Garmin Oregon 300 + Garmin iQue 3600
My Zoned Speed Camera Icons, available here.
WiRED
PostPosted: Sun Jan 18, 2009 8:58 pm    Post subject: Reply with quote
Ok, I've sorted it out now.
I managed to introduce a typo into the build process of the pMobiles product. Interestingly, it only seems to upset recent versions of Mapsource. The reason I hadn't noticed it is that I appear to have 2 versions of Mapsource installed and I've been testing releases with the old version Rolling Eyes
Anyway, its fixed now and anyone affected by this should download version 7.013.2. I've sent it to MaFt but it may take a little while before it makes it onto the downloads page.
/WiRED
PostPosted: Mon Jan 19, 2009 12:01 pm    Post subject: Reply with quote
this has now been updated (11am, 19th jan 09)
Taps
PostPosted: Mon Jan 19, 2009 8:50 pm    Post subject: map source overlay code 702 Reply with quote
Very Happy
Many thanks the new updated download works a treat.
loads up ok now
Cheers Taps
24.041 (01 Apr 26)
