| Author |
W90BHP Occasional Visitor
Posted: Fri Jan 30, 2009 8:58 am Post subject: |
The answer is probably "no", but would this work with a 730? Looks to be a better mounting solution than the standard sucker...
Martin _________________ LG G4: Android 6 : Viewranger : CoPilot : Waze
TomTom Go 730T : Traffic subscription long expired
Nokia E61 : Nokia GPS : TomTom Navigator 6 : Retired from duty
iPAQ 3970 : Navman Sleeve : CoPilot 4 : Somewhere in the loft |
| Back to top |
MrT Frequent Visitor
Joined: Nov 14, 2003 Posts: 2146 Location: Surrounded by A1, M1 & M25
Posted: Fri Jan 30, 2009 9:29 am Post subject: |
| W90BHP wrote: | The answer is probably "no", but would this work with a 730? Looks to be a better mounting solution than the standard sucker...
Martin |
The answer is definitely no. This mount is only for the Go Live x40 range. _________________ Drivelux |
| Back to top |
Posted: Fri Jan 30, 2009 10:55 am Post subject: |
| MrT wrote: | | Could this mount be cannibalised with an original to give more movement? |
The RDS receivers aerial exits the mount via a small hole in the ball that the mount swivels on, therefore to prevent the cable from being severed there is a mechanism to limit the rotation to around 270 degrees there is also an amount of restriction in vertical movement which is again provided to prevent the cable from being severed.
You could increase the range of movement by taking it to bits and a little 'adjustment' using a dremel or small file, although this will void your warranty and could possibly result in a snapped aerial wire if you force it too far. You cannot use the swivel housing from the normal mount though as it doesn't contain an exit path for the wire aerial.
I guess it depends how far you want to modify the mount, if you fit a small connector to the back of the mount for the aerial wire to exit via then the swivel restriction wouldn't be required, but this is more involved, for myself I would like the RDS Mount in the Brodit style, but its not an avaìlable option without DIY - Mike |
| Back to top |
tkerby Lifetime Member
Posted: Fri Jan 30, 2009 11:38 am Post subject: |
Its a real shame the rds-tmc version of the mount didn't add an aerial connector onto the clip part of the mount itself next to the other connectors and provide a short aerial. This would have given people the option of connecting into the car aerial and not limited the mount movement
I find even the standard x40 mount doesnt work well on my Saab 9-3 dash with dash disk. Its bearable but the screen is inclined slightly up as the dash is highest near me and falls away towards the screen. The mount just doesnt adjust enough |
| Back to top |
shortbloke Occasional Visitor
Posted: Fri Jan 30, 2009 1:26 pm Post subject: |
I'm not clear from the tomtom site if the Fixed Install version has the ipod AND line out connector. I contacted tomtom last week and asked if any of the mounts supported this, they said No.
Only the new windscreen mounts mention ipod/line out connections, but I thought I'd seen a picture showing these on the fixed mount somewhere.
Can anyone confirm? As I'd rather have a fixed mount for my 940. |
| Back to top |
Darren Frequent Visitor
Posted: Fri Jan 30, 2009 1:32 pm Post subject: |
| shortbloke wrote: | | I'm not clear from the tomtom site if the Fixed Install version has the ipod AND line out connector. |
It does. _________________ Darren Griffin |
| Back to top |
Andy_P Pocket GPS Moderator
Posted: Fri Jan 30, 2009 10:57 pm Post subject: |
| Darren wrote: | | Andy_P wrote: | | Also the range of movement possible on the ball joint is quite a lot less then on the standard mounts. |
Which mount is this Andy? The RDS mount? |
Yes, I was referring to the mount in the link that I'd quoted above my reply.
It is indeed the RDS-TMC one.
| mikealder wrote: | | there is a mechanism to limit the rotation to around 270 degrees there is also an amount of restriction in vertical movement which is again provided to prevent the cable from being severed. |
Interesting... the one I have has the restricted vertical/horizontal movement, but there's nothing to stop you rotating it on it's axis as much as you like.
I keep trying to remember which way I've turned it, so I can turn it back the other way!  |
| Back to top |
Posted: Fri Jan 30, 2009 11:10 pm Post subject: |
| So you can get 360+ degrees of movement from the mount - in which case I would consider what this rotation is doing, and the aerial wire will snap if you keep turning around which it shouldn't be possible to do - Mike |
| Back to top |
Posted: Sat Jan 31, 2009 12:02 am Post subject: |
| Yes, that was exactly my point! I mentioned to TT that it was going to snap as soon as I got it, which is maybe why they've modified it now. |
| Back to top |
emjaiuk Frequent Visitor
Joined: Dec 06, 2003 Posts: 335 Location: North Surrey (TW17) UK
Posted: Mon Feb 02, 2009 3:45 pm Post subject: |
Andy
have you used RDS-TMC with the new mount yet, and if so what's reception like? I've just ordered a new 740 live, and had intended to get a USB TMC receiver and hook it up to an external Fm aerial as my previous one. _________________ Go740L App 9.510 Europe 985.8155
RDS_TMC mount
Home 2.8.3.2499 Win10 Home |
| Back to top |
Posted: Mon Feb 02, 2009 7:50 pm Post subject: |
Whilst I don't mind discussing the new mount in terms of form factor etc the actual performance isn't something that should be compared, those of use with Beta test hardware have no way of knowing if a production version would perform better or worse than the hardware we have.
Eitherway it is easy to connect an external aerial to the mount should you find one necessary - Mike |
| Back to top |
Posted: Wed Feb 04, 2009 12:24 pm Post subject: |
Probably a stupid question with TomTom, but does anyone know when the RDS mount will be available, I dont want to get a USB version if it's due 'soon' _________________ Go740L App 9.510 Europe 985.8155
RDS_TMC mount
| Back to top |
itaylort Occasional Visitor
Posted: Fri Feb 06, 2009 7:08 pm Post subject: |
Does anyone know if the ipod cable charge the ipod?
Ian |
| Back to top |
Posted: Fri Feb 06, 2009 7:25 pm Post subject: |
| itaylort wrote: | | Does anyone know if the ipod cable charge the ipod? |
Ian, thats an easy question sadly the answer is NO - Mike |
| Back to top |
Tim Buxton Pocket GPS Moderator
Joined: 14/09/2002 20:56:18 Posts: 5231 Location: Surrey, United Kingdom
Posted: Tue Feb 10, 2009 10:40 am Post subject: |
| emjaiuk wrote: | | Probably a stupid question with TomTom, but does anyone know when the RDS mount will be available, I dont want to get a USB version if it's due 'soon' |
The RDS-TMC mount for the x40 range was officially announced yesterday.
Click here. _________________ Tim |
| Back to top |
| Back to top |
