Pocket GPS World :: View topic - iGO8 Ultra Skin 6.0.22
Goto page Previous  1, 2, 3 ... 5, 6, 7 ... 33, 34, 35  Next
linknet
PostPosted: Fri Jan 30, 2009 9:43 pm    Post subject: Re: WVGA resolution support Reply with quote
Dusha wrote:
Dear linknet,
Are there any chances to get a support for WVGA (480x800, 800x400) resolutions in Ultra skin in foreseeable future?
I can donate some $
Thanks!
I'd need enough $ to purchase a 800x480 device to develop and test it on. Laughing Laughing
Seriously though, I have considered changing to an 800x480 device so which device are you using and is it any good ?
linknet
fr0d0
PostPosted: Fri Jan 30, 2009 9:49 pm    Post subject: Reply with quote
In your website docs it says:
Added tilt settings to the "3D Smart Zoom" settings screen (no additional "sys.txt" entry is needed for this to work correctly). The settings for Portrait and Landscape mode are now saved separately with optimised initial default settings for each mode.
I can't find the "3D Smart Zoom" settings screen Crying or Very sad
linknet
PostPosted: Fri Jan 30, 2009 10:23 pm    Post subject: Reply with quote
This seems to be a common problem, this is still in the original iGO8 location, I haven't moved it. Laughing
If you look on page 3 of this topic there is a question by "jkare" which I answered previously.
linknet
fr0d0
PostPosted: Fri Jan 30, 2009 11:09 pm    Post subject: Reply with quote
ah sorry linknet - I've followed every post on this thread too! I guess you can't pick your users!
Dusha
PostPosted: Sat Jan 31, 2009 2:09 pm    Post subject: Re: WVGA resolution support Reply with quote
HTC Touch HD.
http://www.htc.com/www/product/touchhd/overview.html
8.3.2 works pefrect on it with native WVGA support.
P.S. The only native WVGA compatible skin for 8.3.x I have found is
Gurjon http://www.gurjon.com/
linknet
PostPosted: Sat Jan 31, 2009 2:20 pm    Post subject: Re: WVGA resolution support Reply with quote
Dusha wrote:
HTC Touch HD.
Thanks for the link, it looks good but I'm looking for a larger screen than my iPAQ 214 which is 4.0 inches, so will have to keep looking. Smile
Regards
linknet
LolitaDamore
PostPosted: Sat Jan 31, 2009 2:28 pm    Post subject: Reply with quote
Then you need something like that (5") http://www.zone-numerique.com/news_2520_L_etonnant_HTC_Advantage_nouvelle_version_X7510.htm
linknet
PostPosted: Sat Jan 31, 2009 2:31 pm    Post subject: Reply with quote
Added Version 6.0.4 Smile
Added a night filter for the navigation screen to reduce brightness for devices that don't support automatic dimming at night. This is configurable via the Settings ► Map Screen ► Colour Profiles settings menu. Also via the navigation screen "Quick Menu" where a new button supports "Tap" to toggle the night filter On/Off and "Tap and Hold" to access the settings menu directly.
Note: This defaults to On so if your device supports automatic dimming at night you may need to turn it Off or reduce the Night Filter Value setting.
Fixed - Second Route Event Pop-Up background now uses correct bitmap in night mode.
Fixed - All menu sliders now display in correct positions for both QVGA and VGA modes.
linknet
linknet
PostPosted: Sat Jan 31, 2009 2:38 pm    Post subject: Reply with quote
Yes, but that's not 800x480. Sad
linknet
Dusha
PostPosted: Sat Jan 31, 2009 2:38 pm    Post subject: Re: WVGA resolution support Reply with quote
This would be hard to find...
I like HD for pretty large screen, huge ram, and everything built-in (no need to have separate GPS, separate phone for GPSgate data transmission)
I don't think that there will be any smartphone/handheld released in a future with the screen larger then 4 inch you have on 214.
Then you have to look at UMPCs but most of them are running on Vista/XP.
linknet
PostPosted: Sat Jan 31, 2009 2:46 pm    Post subject: Re: WVGA resolution support Reply with quote
I've considered an iPAQ 314 but I would have to patch it to run iGO8 instead of the HP version of iGO supplied with it. Also I've heard many reports that it is slow.
linknet
Auke
PostPosted: Sat Jan 31, 2009 5:50 pm    Post subject: Reply with quote
Works great. that night filter. Very Happy
It does not work in simpel mode.. But that is not so important
Linknet Thanks. Its a great skin again... The best one.
LolitaDamore
PostPosted: Sat Jan 31, 2009 6:30 pm    Post subject: Reply with quote
Auke wrote:
...Linknet Thanks. Its a great skin again... The best one.
will be again the best, when radars voices warnings will be back Cheers!
linknet
PostPosted: Sat Jan 31, 2009 6:44 pm    Post subject: Reply with quote
It does not work in simple mode.. But that is not so important
That's by design, in simple mode you don't have access to the advanced menus to be able to adjust the settings, so I disabled it.
linknet
linknet
PostPosted: Sat Jan 31, 2009 6:48 pm    Post subject: Reply with quote
LolitaDamore wrote:
will be again the best, when radars warnings will be back Cheers!
Radar warnings work just fine, it's only voice warnings which have not been included. Wink
linknet
Page 6 of 35
24.041 (01 Apr 26)
