Pocket GPS World :: View topic - Resetting local time when abroad
Nick_Russell
PostPosted: Wed Feb 11, 2009 12:25 pm    Post subject: Resetting local time when abroad Reply with quote
When I travel in Europe the ETA shows arrival time as UK time. Is it possible to set local time according to which time zone you are in and therefore to get correct arrival time? Changing time zone only seems to change clock.
I have scoured the manual and forums for this but can't find how to do this.
Is it possible without resetting the whole device?
Nick Russell
Garmin nüvi 3590LM
SW v4.60, Audio v1.50, GTM v5.30, GPS v3.00, Bluetooth v3.40
City Navigator Europe NT 2008. GarminPOI Loader 2.5.2
greg_m
PostPosted: Wed Feb 11, 2009 1:35 pm    Post subject: Reply with quote
check if you have gmaptz.img file in your garmin. if contains info about time zones so possibly it might help adjusting the clock, but i'm not sure.
is the time showed right and you only have issue with ETA or both are shown as UK time?
EDIT: just found it on the internet:
Sometimes the Nuvi does not detect your timezone when you skip zones (for example if you are flying) or you leave it off for extended periods of time when Traveling.
If you do need to select another time zone, to to the Travel Kit, Select World Clock, Select (or press on the clock), Select the city currently residing in the Time Zone window, Scroll up or down and select the city that is in the time zone you wish to select, press OK, Select Back, Select Back, Select Back, verify that the time (Hour) is correct.
or check here:
http://home.comcast.net/~ghayman3/garmin.gps/page3.htm
scroll down to: MY TIME'S NOT YOUR TIME
i hope it helps.
Nick_Russell
PostPosted: Wed Feb 11, 2009 4:27 pm    Post subject: Reply with quote
greg_m wrote:
...is the time showed right and you only have issue with ETA or both are shown as UK time?
When I change the time in settings, the time is correct but ETA still shows UK time.
Nick Russell
Garmin nüvi 3590LM
Nick_Russell
PostPosted: Thu Feb 12, 2009 9:41 am    Post subject: Reply with quote
Update: I have been in the Netherlands for a few days and changed time zone yesterday. Time and ETA was OK - both showed local time and not UK time. When I did this before I changed time zone as soon as I arrived in Europre and clock was OK but ETA remained on UK time.
Can't explain why it now works - is it possible that system has to register for a period in new time zone to pick up correct ETA?
Nick Russell
Garmin nüvi 3590LM
23.104 (22 Oct 25)
