Pocket GPS World :: View topic - HELP! Oregon 400T Update - roads gone!
empee
PostPosted: Sat Feb 28, 2009 9:16 pm    Post subject: HELP! Oregon 400T Update - roads gone! Reply with quote
Updated my Oregon for the first time last night from 2.4 something to 2.8 and now all the roads are gone. Confused
Don't use it for driving but the local area does look totally different when you take all the roads out!
Advice appreciated
Garmin Oregon 400T
TomTom 920T
eyeQue
PostPosted: Sat Feb 28, 2009 9:57 pm    Post subject: Reply with quote
You have to reset all the options after a firmware update.
Setup-Map-Map information-Select Map.
See what is 'Enable' or 'Disable'
Garmin Oregon 300 + Garmin iQue 3600
My Zoned Speed Camera Icons, available here.
empee
PostPosted: Sat Feb 28, 2009 10:15 pm    Post subject: Reply with quote
Thanks eyeQue
I'm showing:
Enabled - Topo US 2008
Enabled - Recreational Map of Europe v2.00
Enabled - WW Autoroute DEM Basemap NR
Tried disabling each in turn and then enabling but still no roads, here or in the US
Garmin Oregon 400T
TomTom 920T
eyeQue
PostPosted: Sat Feb 28, 2009 10:22 pm    Post subject: Reply with quote
Try to zoom in on an area to 300ft.
empee
PostPosted: Sat Feb 28, 2009 10:31 pm    Post subject: Reply with quote
In and out - 5mls to 20' - still no roads!
Garmin Oregon 400T
TomTom 920T
eyeQue
PostPosted: Sat Feb 28, 2009 10:38 pm    Post subject: Reply with quote
What is the size of each map file?
Are they in the unit or on the micro card?
empee
PostPosted: Sat Feb 28, 2009 10:44 pm    Post subject: Reply with quote
The US topo is on a micro sd card - the European ones came within the unit - how do you check the file size?
Garmin Oregon 400T
TomTom 920T
eyeQue
PostPosted: Sat Feb 28, 2009 10:57 pm    Post subject: Reply with quote
plug up to PC and the unit becomes a drive.
How did you upgrade to 2.8?
The most recent upgrade is 2.86 which gives problems.
I have 2.85.
Setup- 'About'
What do you see?
empee
PostPosted: Sat Feb 28, 2009 11:01 pm    Post subject: Reply with quote
Plugged into my pc, opened up the Garmin 'WebUpdater' software and followed the 'update software' wizard.
My version is showing 2.80 Should I try updating again?
Garmin Oregon 400T
TomTom 920T
eyeQue
PostPosted: Sat Feb 28, 2009 11:11 pm    Post subject: Reply with quote
http://garminoregon.wikispaces.com/Versions#toc0
empee
PostPosted: Sat Feb 28, 2009 11:56 pm    Post subject: Reply with quote
Thanx for the link -
WOW - didn't realise it was the public sorting out Garmins' software for them!
Tried installing version 2.85 as explained. Not sure what opening in mass storage mode means so just copied the renamed file into Garmin (G drive for me) and it's not doing anything there (still version 2.80)
Tried just re-installing version 2.80 but no change there either - only other options appear to be install the latest beta (2.86) or return the unit for a refund!
Garmin Oregon 400T
TomTom 920T
eyeQue
PostPosted: Sat Feb 28, 2009 11:59 pm    Post subject: Reply with quote
If you want send a Private Message with a phone number it could be quicker!
empee
PostPosted: Mon Mar 02, 2009 10:41 am    Post subject: Reply with quote
Quick update
Spoke to Garmin UK this morning - they'd never come across this problem so explained how to do a factory reset - got my roads back!
Garmin Oregon 400T
TomTom 920T
23.103 (15 Oct 25)
