Pocket GPS World :: View topic - REVIEW COMMENTS: TomTom GO
Goto page 1, 2, 3 ... 33, 34, 35  Next
PostPosted: Thu Jun 17, 2004 12:50 pm    Post subject: REVIEW COMMENTS: TomTom GO Reply with quote
As always, PocketGPSWorld.com tries to bring you the most detailed GPS Reviews first, and we've done it again!
A world's first! The Full In-Depth TomTom GO Review!
TomTom have put a lot of thought into GO. Firstly they've gone with something they're happy with, trying to pull the three systems to a single product platform which will make life easier going forward. They've also used a Palm/Pocket PC style processor, RAM and screen, these work very well and prices are coming down on these components.
TomTom GO is currently shipping in The Netherlands, and is expected to ship in the UK by the end of June.
Read the full review here
http://www.pocketgpsworld.com/tomtom-go.php
davast
PostPosted: Thu Jun 17, 2004 2:31 pm    Post subject: Entering Street Names Reply with quote
I noticed there was no mention of entering addresses into GO under "Problems".
How does this compare to entering addresses in TT3?
Frenchie
PostPosted: Thu Jun 17, 2004 3:31 pm    Post subject: Reply with quote
Thanks Dave and Mike for this 1st World review.
Now, we are eagerly waiting for a comparative:
TomTom GO (~ £450)
Garmin SP 26XX (~ £730)
Magellan Road Mate 700 (~ £930)
PostPosted: Thu Jun 17, 2004 3:41 pm    Post subject: Reply with quote
And there will be one available in the not so distant future.
Frenchie
PostPosted: Thu Jun 17, 2004 4:27 pm    Post subject: Reply with quote
I am sure you will write this comparative before July and the big departures for holidays...
Frenchie
PostPosted: Thu Jun 17, 2004 4:29 pm    Post subject: Reply with quote
On http://www.pocketgpsworld.com/modules.php?name=Forums > PALM & POCKET PC STREET NAVIGATION SOFTWARE , there is a folder for TomTom Navigator.
It would be nice to create a specific folder for TomTom GO under http://www.pocketgpsworld.com/modules.php?name=Forums > GPS HARDWARE.
Thanks again, Hope this helps.
Frenchie
PostPosted: Thu Jun 17, 2004 5:34 pm    Post subject: Reply with quote
Will it bring the same advantages as PDA-based units for TomTom Traffic and Speed Cameras detector?
PostPosted: Thu Jun 17, 2004 6:53 pm    Post subject: Reply with quote
By the time it launches in the UK the Speed (sorry safety) Camera POI interface will be available, but it will be sometime before the traffic will be implemented.
iancjc
PostPosted: Thu Jun 17, 2004 6:59 pm    Post subject: Reply with quote
re the saftety poi will it run checkpoint - or similar (Being very good) or just provide the icons on screen (being not very good).
TTN6.03 tomtom 7.xx (one)
gambitgander
PostPosted: Thu Jun 17, 2004 7:17 pm    Post subject: Reply with quote
Thanks for the review Dave.
Just a few questions though:
I've been doing a bit of reading on Tom Tom's website, and they say that the unit has to be charged for at least 2 hours, then it takes another 45 minutes to obtain a GPS fix. Did you find this was the case when you first used it?
I spoke to Tom Tom support and asked about the SD card limit. They did not recommend or support anything above 256MB. Were you able to test with a larger card?
PostPosted: Thu Jun 17, 2004 8:06 pm    Post subject: Reply with quote
It won't have a camera detector AFAIK, but it will support POI's like the Pocket PC version does. No it won't support CheckPOInt, GPSAssist etc.
Glad you liked it! No, didn't have to wait 45 mins for a fix. Basically what happens is that manufacturers do state that sometimes you have to wait 45 mins to obtain your first fix when it's out of the factory and flied half way around the earth. 45 mins is incorrect. The longest TTFF if all data is received correctly without error should be around 12.5 mins, but a good 90% of the time on new products you only have to wait a few mins. The 12.5 mins is the time it takes to download both the almanac and ephemeris tables from the satellites. Almanac data is current for several months where as ephemeris is what you normally download everytime your receiver is between hot, warm or a cold start (up to a few days or a week without use). So you shouldn't have too much problem. With Li-Ion style batteries it's always good to condition them so charging for a couple of hours is a good thing to do before use. I usually put them on charge and play around with them at the same time Wink
256mb is a moot point and one that a lot of manufacturers are shy about. There's a lot of inherent problems with SD cards matched to SD readers. The SD cards that ship will be Sandisk (I here everyone boo and hiss). In theory the SD readers can support any size, the same CF readers can, so any size should be okay. The only issue is whether there is a software limitation like Navman has on loading too many maps into memory. There may be, but I can't say as I've only been using UK maps and these work fine. Basically the SD card will ship with GO and I believe it's locked to the SD card that it ships with (although Mike may be able to tell you a little more). Certainly the Palm OS version of Navigator is locked to the SD card so yoiu can't copy it onto another larger SD card as it reads the Secure ID off the Secure Digital (SD) card.
gambitgander
PostPosted: Fri Jun 18, 2004 8:33 am    Post subject: Reply with quote
Thanks for the info Dave. I double-checked with Tom Tom about the SD card. They said that any more than 256MB worth of maps, and there would be a degradation in performance. Do they have a map management feature, like in Navman, where you can install lots of maps, and enable and disable at your leisure?
PostPosted: Fri Jun 18, 2004 9:02 am    Post subject: Reply with quote
Probably the reason that TomTom is mentioning the 256Mb as a limit is because the largest mapset the provide at the moment comes on a 256Mb card. There should be no reason that they dont provide say all the mapsets for Europe (or most of it) an a 1GB card, but you would still have tho switch maps.
I wouldnt envisage a performance issue there, just a one of cost.
PostPosted: Fri Jun 18, 2004 9:17 am    Post subject: Reply with quote
Yes, don't forget that TomTom you do still have to switch maps, the only exception is MRE (Major Roads of Europe), where you can navigate through countries. If you want to use street level maps from England to Spain, you would still have to switch maps at each countries border like you have to on the Pocket PC and Palm OS.
Frenchie
PostPosted: Fri Jun 18, 2004 10:08 am    Post subject: Reply with quote
Compared to solutions like Garmin SP 2610 or Magellan Road Mate 700, it's worth noting European maps are extra with TomTom.
For reference, price for TomTom European maps for Tom Tom Navigator 3 Pocket PC is more than £100:
http://www.globalpositioningsystems.co.uk/viewprod.php?product_id=1738
Page 1 of 35
23.094 (24 Sep 25)
