Pocket GPS World :: View topic - TT720GO Postcode Problem
jonial
PostPosted: Thu Mar 05, 2009 4:00 am    Post subject: TT720GO Postcode Problem Reply with quote
Hello to all
Can anyone explain this problem please.
My home postcode is PR3 1PL The Close, Wyre Vale Park, Garstang however whenever I try to navigate to this postcode then the 720 tries to take me to PR4 2UL The Close, Preston which is app.15 miles away in a village called Freckleton
On my 510 the postcode is identified correctly and I arrive at my home location.
Regards
John
PostPosted: Thu Mar 05, 2009 4:24 am    Post subject: Reply with quote
Should it be a small "loop" of three roads with yours in the middle and Wyre Vale Park on either side?
If so, it is correct on v825 maps and v801 postcodes.
To check your postcodes Use Windows Explorer to browse to the "zip" folder on your Go. There will be a file called "Great_Britain.postal" in there and hopefully another one called "Great_BritainPostal.ver". Open that one with Notepad, and it will tell you the version number.
If it isn't v801, we can give you a link for the right file.
jonial
PostPosted: Thu Mar 05, 2009 4:55 am    Post subject: Reply with quote
The version qoted on my TT is 701
The link and installation instructions woul be greatly appreciated.
You are correct in the description of Wyre Vale Park
John
PostPosted: Thu Mar 05, 2009 7:53 am    Post subject: Re: TT720GO Postcode Problem Reply with quote
You are, presumably, entering a house number when the menu asks for one.
This is where the error creeps in. As there are no numbers listed in the Postcode file for "The Close" you want, the software looks for the nearest within the Preston area. If you use 1-9 you will get another "The Close", and if you use 10-42 you will get yet another "The Close". You can check the house numbers with Browse Map.
These findings apply to the 801 Postcode File. Rolling Eyes
TT Via 135 App 12.075: Europe Map v1165
jonial
PostPosted: Thu Mar 05, 2009 8:55 am    Post subject: Reply with quote
Hi Oldboy
Absolutely spot on -- I was trying to enter a house number.
Is there still an advantage in upgrading to postcode ver 801 ?
If so How do I do it?
Many Thanks
John
PostPosted: Thu Mar 05, 2009 12:17 pm    Post subject: Reply with quote
It might have some Postcodes that are not present in the 701 file. You can get the UK 801 files Here.
Just Unzip the Download. Then the 2 files just replace the existing files in the zip Folder on the Device. You can always Backup the 701 files if you feel the need.
jonial
PostPosted: Thu Mar 05, 2009 1:06 pm    Post subject: Reply with quote
Hi Richard
Thanks for the link and the explanation re 710 / 810
John
24.041 (01 Apr 26)
