Pocket GPS World :: View topic - Emtac Trine Datalogger
Goto page Previous  1, 2
Fieldgeek
PostPosted: Thu Jun 24, 2004 4:18 am    Post subject: Reply with quote
I just discovered a ROM update for the IPAQ 4100 series on HPs website. I downloaded it and installed it. Same thing wit the Bluetooth. Connection drops off in a couple seconds. Doh!
Oh well.
CESkins
PostPosted: Thu Jun 24, 2004 5:29 pm    Post subject: Reply with quote
Fieldgeek I am having the same problems with my iPAQ 4150. Surprisingly though my iPAQ 2210 works just fine with the Trine. Like you I applied the most recent HP ROM update for the 4150 with no change in the dropped signal/connection to the GPS receiver after 1 sec.
Fieldgeek
PostPosted: Fri Jun 25, 2004 3:42 am    Post subject: Reply with quote
Yay! Someone else with the problem too! I am not saying that it is a good thing... but I am just happy I am not the only one. Just out of curiosity, if you connect to your 2210 first, can you then also connect to your 4150 without a problem?
CESkins
PostPosted: Fri Jun 25, 2004 11:10 am    Post subject: Reply with quote
Misery loves company...I understand. I found like you, if I connect with my PC 1st then I can connect with the 4150 and the connection is stable. I haven't tried connecting with the 2210 followed by the 4150. However, I suspect that the 4150 will connect stably if I do so. Fortunately, the trine and the 4150 software can be updated...hopefully a fix or workaround is found soon.
snaz
PostPosted: Thu Jul 01, 2004 1:02 am    Post subject: Reply with quote
from what i can tell, the trine is the exact same GPS unit as the original emtac (i.e. the chipset, etc) the only things different/new are the battery, datalogger, and multilink, none of which affects the gps part of the unit (i.e. the sensitivity, time to lock, avg number of satellites, etc).
that means that, except for the new non-gps features, the trine is essentially the same BTGPS that was released back in 2002. Now, as far as i can tell, the only really new thing these days is xtrac version 2, which the trine doesn't have.
Question:
does it make sense to get the trine if you're basically buying a unit that's over 2 years old (i.e. same as the original emtac) or should i wait to get one with xtrac v2?
i'd be using it with a palm T3, and i like the fact that emtac has software for the palm on their website to control the unit (i.e. access WAAS, trickle mode, etc) whereas most other units only have software for pocketPC - so i'd like to get the trine (assuming the same palm software works for it)
unless people think that it's out of date and one with xtrac is definitely the way to go (hopefully also with WAAS and palm software)
AMG_Roadster
PostPosted: Thu Jul 08, 2004 2:13 am    Post subject: Reply with quote
What makes you feel that the GPS portion of the unit is the same. I would hope that they would improve upon the key features in 2 years.
illusion
PostPosted: Thu Jul 08, 2004 4:22 pm    Post subject: Reply with quote
I mailed Emtac about the iPAQ 4150 + Trine issue.
I'm still waiting for reply but I'll share it with you guys.
I also found a dutch online shop witch mentioned that these devices didn't work together.
Let's hope there's an update available soon.
snaz
PostPosted: Thu Jul 08, 2004 8:37 pm    Post subject: Reply with quote
if you look at the specs for each unit (Trine vs original) on the emtac website, they're identical. (i.e. chipset, firmware, sensitivity, times to acquire, etc)
AMG_Roadster
PostPosted: Fri Jul 09, 2004 2:53 am    Post subject: Reply with quote
Damn. After seeing that the price for the original Socket BT GPS has risen in the last couple of weeks by ~$30 I figured I would go ahead and get the Trine. But now that it has been pointed out that it is old technology, it is time to figure out what BT GPS I want to buy now.
Brandon
PostPosted: Mon Jul 12, 2004 11:39 pm    Post subject: ATTN: 4000 series iPAQ & Trine Users! Update! Reply with quote
For the users of the 4000 series iPAQ and EMTAC Trine Bluetooth GPS, there is now a firmware update to solve the connection problems you may have been experiencing.
Users with a Bluetooth enabled laptop can go to www.transplantgps.com/support.html to download the update.
For users without a Bluetooth enabled laptop, please contact support@transplantgps.com for information on how to get your unit updated.
Thank you to all of the members who alerted us to the connection issue!
Transplant GPS is a leading provider of GPS devices, handheld computers, and mobile solutions. Working with industries such as the transportation industry, precision farming, and forestry management, Transplant GPS helps to provide high quality, portable GPS solutions. Transplant is head-quartered in Rochester, Minnesota and can be reached at 507.529.0041
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
Fieldgeek
PostPosted: Wed Jul 14, 2004 12:44 am    Post subject: Reply with quote
YAY! I installed the update and it works! Time to play!!! Thank you Brandon.
Cheers,
Peter
CESkins
PostPosted: Wed Jul 14, 2004 1:17 am    Post subject: Reply with quote
Fieldgeek I too installed the update and now I'm in business...Emtac BTGPS II Trine + Mapopolis + Arkon powered mount. :-)
jorgenchr
PostPosted: Fri Aug 06, 2004 5:14 pm    Post subject: Reply with quote
I am having problems with my Dell Laptop D400 and the Bluetooth device i am trying to access. I see that Dell had posted a new A05 driver update, but i am unable to locate it anywhere on their website.
Does anyone have a copy of that Driver available that i can try?
Page 2 of 2
24.041 (01 Apr 26)
