| Author |
howard40uk Occasional Visitor
Posted: Fri May 29, 2009 12:51 am Post subject: are the 1:50000 maps good enough for doing my walking |
| ive just bought the lancashire 1;50000 memory card for which i do mosty countyside walks will the detail on the maps be good enough for what i need it for as i dont want to fork out over £130 for the 1:25000 version if i dont really need to |
| Back to top |
G1LIW Lifetime Member
Joined: Jun 19, 2006 Posts: 212 Location: Sahrf Lunnon ;)
Posted: Fri May 29, 2009 8:10 am Post subject: |
Put it this way...
I learnt to map read with the T.A.; they use the MoD GSGS series 1:50,000 series, which are identical to the publicly available maps (bar certain overprinting for military stuff).
Aside from once trying to read a paper map upside down (I was somewhat hungover, bleary-eyed, and slow of brain from the night before , it should be mentioned), with a decent compass (Silva type) I could (normally) find my way reasonably well.
Couple that with your moving-map GPS technology, and you shouldn't put a foot wrong
Hope that helps  _________________ Roger, G1LIW
Google Pixel 3a XL Android Smartphone | SatNav Sygic for Android | Waze for Android | CamerAlert for Android | Blog http://rogersblant.blogspot.com/ |
| Back to top |
Posted: Fri May 29, 2009 8:32 am Post subject: |
I use 50K most of the time on my a10 it is fine for cycling, walking etc. 25K offers considerably more detail but its difficult to see larger areas on the device, only on a couple of occasions have I found 25K of benefit while in thick fog decending Ingleborough.
Where in Lancashire are you located? - Mike |
| Back to top |
Posted: Fri May 29, 2009 9:12 am Post subject: |
| Im accrington just tend to stick to walks in lancs not often i go elsewhere |
| Back to top |
Posted: Fri May 29, 2009 9:18 am Post subject: |
| My a10 comes tomorrow :-) cant wait |
| Back to top |
philpugh Lifetime Member
Joined: Dec 28, 2005 Posts: 2003 Location: Antrobus, Cheshire
Posted: Fri May 29, 2009 1:29 pm Post subject: |
The main thing you will be missing (apart from the larger scale for poor eyes like mine) is that the 1:25k include field boundaries e.g. walls etc. These can be useful when trying to find that elusive path on the ground that you can see on the 1:50k map. Having said that I only have the UK at 1:50k on mine and it is very nice to use. I do have MemoryMap with 1:25k of my favourite areas though - so I can take a customised paper map out with me. _________________ Phil |
| Back to top |
cwmboy Occasional Visitor
Posted: Fri May 29, 2009 4:35 pm Post subject: |
I assume you use papers maps before the arrival of your A10. The detail on a 1:50000 card on your Satmap will be exactly the same as a paper map. Likewise for 1:25000. Only you don't have to hang on to your A10 like a kite in windy conditions . You can always get a 1:25k later as your budget allows if you really want the finer detail.
Pop a paper map & compass in your sack as a back-up in the rare event your battery expires or an alien spaceship wipes out the satellites The former has happened once to me before I changed to lipol battery and the second hasn't happened yet!
Enjoy your Satmap, a great tool! _________________ I Go To The Hills.............
Garmin 12XL
Garmin Vista
Satmap A10
Anquet Maps 6.2.10 |
| Back to top |
JimmyTheHand Frequent Visitor
Posted: Fri May 29, 2009 9:05 pm Post subject: |
| philpugh wrote: | | is that the 1:25k include field boundaries e.g. walls etc. These can be useful when trying to find that elusive path on the ground that you can see on the 1:50k map. |
Though I have found times when the 25K maps are wrong - e.g. path runs along other side of ditch to map shows it. (not really a great issue in Herts) _________________ J. |
| Back to top |
Posted: Fri May 29, 2009 9:12 pm Post subject: Re: are the 1:50000 maps good enough for doing my walking |
| howard40uk wrote: | | ive just bought the lancashire 1;50000 memory card for which i do mosty countyside walks will the detail on the maps be good enough for what i need it for as i dont want to fork out over £130 for the 1:25000 version if i dont really need to |
Usually 1:50,000 is more than enough. But if you don't venture too far from home, then the site centred maps satmap do might be worth looking at as they can work out cheaper _________________ J. |
| Back to top |
RSB77 Occasional Visitor
Posted: Sun May 31, 2009 7:26 pm Post subject: 25000 far superior for walking |
howard
I think 25000 gives you the confidence to go further as it shows all the footpaths and allows you to walk in areas you don't know. Expensive but worth it. |
| Back to top |
LostMike Frequent Visitor
Joined: Jan 17, 2008 Posts: 369 Location: Monmouthshire
Posted: Sun May 31, 2009 9:33 pm Post subject: |
But the 1:50,000 also shows all the footpaths. _________________ LostMike
Satmap A10. Platform 21
Software version 1.5.9193
Satsync 1.525 |
| Back to top |
planetnine Regular Visitor
Joined: Dec 11, 2006 Posts: 93 Location: Lincolnshire, England.
Posted: Sun May 31, 2009 10:56 pm Post subject: |
1:50k may be all you need, but 1:25k is nicer.
if you get the premium version of a site-centred 1:25k of your likely covered area, you get both 1:50k and 1:25k.
i prefer 1:25k when walking, but I am a bit of a map fiend -I can sit and read one for an hour...
I'll second the 1:25k not always being accurate; there are path diversions local to me that have been picked up on the 1:50k map, but forgotten on the latest version of the 1:25k sheet.
nathan _________________ planet nine
Lincoln, UK. |
| Back to top |
Posted: Mon Jun 01, 2009 1:08 pm Post subject: |
| JimmyTheHand wrote: | | philpugh wrote: | | is that the 1:25k include field boundaries e.g. walls etc. These can be useful when trying to find that elusive path on the ground that you can see on the 1:50k map. |
Though I have found times when the 25K maps are wrong - e.g. path runs along other side of ditch to map shows it. (not really a great issue in Herts) |
Interesting point - provoked a long discussion during one of our walks. One of my friends is convinced that anything marked in blue on an OS map is not to be relied on for navigation purposes. The obvious blue is water (lakes, rivers, streams...). He believes that this is because water courses can change. I have not seen this stated anywhere before.
In the case you quote I suspect the footpath in question has been 'moved' by common usage. (NB the OS do not assume any responsibility for paths and rights of way - this lies with the local authority.) _________________ Phil |
| Back to top |
Posted: Mon Jun 01, 2009 6:10 pm Post subject: |
| philpugh wrote: | | Interesting point - provoked a long discussion during one of our walks. One of my friends is convinced that anything marked in blue on an OS map is not to be relied on for navigation purposes |
I know the M11 (motorways being blue on OS maps) is always moving around Though I doubt is as wide in real life as the representation usually is on the maps (esp 1:50K & above).
| philpugh wrote: | | The obvious blue is water (lakes, rivers, streams...). He believes that this is because water courses can change. I have not seen this stated anywhere before. |
They can and do (and can dry up).
He should add anything marked as woods – they can be cut down. I recall being in Derbyshire with a group, I was showing where we were on a map – they disagreed as that was in the middle of a wood – where as I was going by the bends in the path I could see. Someone when off the track and sure enough loads of tree stumps.
Of course anything marked as green can be built on and any thing marked as a road can be dug up.
I think an element of common sense is required – in that you never rely on just one element to tell you where you are when in unknown territory.
| philpugh wrote: | | In the case you quote I suspect the footpath in question has been 'moved' by common usage. (NB the OS do not assume any responsibility for paths and rights of way - this lies with the local authority.) |
I think in this case it is probably accuracy of the data – it ran along the wrong side of a ditch, there was a footbridge in the right place if you assumed map was slightly wrong (guess less than ½ mm on 1:25K map). But footpaths moving is definitely something to be aware of when walking _________________ J. |
| Back to top |
sjdwheeler Occasional Visitor
Joined: Mar 18, 2008 Posts: 9 Location: Chipping Norton, Oxon
Posted: Wed Sep 02, 2009 10:45 pm Post subject: |
I find my GB 1:50,000 is fine for walking most of the country but I definitely recommend the 1:25,000 for mountainous areas.
Mountain paths on maps are sometimes just light black dotted lines and are not always shown on the 1:50,000 scale. Similarly the contour lines are easier to read and more accurate on the 1:25,000. |
| Back to top |
| Back to top |
