Pocket GPS World :: View topic - navman se not working - help required please
Goto page Previous  1, 2
amcluesent
PostPosted: Thu Aug 19, 2004 10:49 pm    Post subject: Reply with quote
As your 3970 has bluetooth, why not give up on the Navman sleeve and use TT3 with a bluetooth GPS?
PostPosted: Fri Aug 20, 2004 7:11 am    Post subject: Reply with quote
plexy wrote:
tried that darren - not supported message.
i read the instructions :-
2. Install Smart ST Pro Europe from the original CD's if not already installed. (Very Important)
i haven't got the SST software though and it does say very important.
does the SST contain the driver that gets updated by the 3.1.6 ?
That's not the issue, despite what they say in the install.txt the driver is independent of SmartST.
As has been spotted by as 'amcluesent' has spoted I agree that WM2003 is the problem here, Navman list other WM2003 iPAQ models (e.g. 5550) as being compatible but it's possible that it's use with 3rd party apps is not supported.
I agree that a call to Navman is required or as has also been suggested better still, get a BT GPS, you'll find the improvements in reception sensitivity worth the investment.
plexy
PostPosted: Tue Aug 24, 2004 9:49 pm    Post subject: Reply with quote
contacted navman.........apparently the 'upgrade' has bugs in it that make the navman & other accessories not work. :x
any ideas how to downgrade to pc2002 (no upgrade disc or backup) as it looks like HP won't be bothering to fix this problem?
amcluesent
PostPosted: Tue Aug 24, 2004 10:45 pm    Post subject: Reply with quote
Companies like http://www.ipaqrepair.co.uk/view_product.php?product=76 will restore an iPaq ROM after a bodged OS upgrade. They may be able to re-install PC2002. Otherwise, suggest looking at the bluetooth approach and selling the Navman SE sleeve on e-bay - might see £100 for it.
singe
PostPosted: Wed Dec 22, 2004 11:29 am    Post subject: Sleeve on or off when installing serial 3.1.6 driver. Reply with quote
"It's been a long long (very long) time since I've installed drivers onto a Navman sleeve, but what I would suggest is you
1) uninstall TomTom ~ GPS and TomTom GPS in Remove Programs.
2) Soft Reset
3) Download Serial 3.1.6 driver (from this link as we know this version works.
4) Summon the rain god (whoops, wrong post-but can't help trying!)
5) Install Serial 3.1.6 driver
6) Check SE Software is working
7) Re-install TomTom GPS and see if it breaks at this point.
At 5, I can't remember whether the sleeve needs to be on or off the iPAQ. I have a hunch that it needs to be on, but I'd suggest performing a soft reset when you get to point 5 just in case. If it doesn't work with it on, try it with it off."
At 5 I had to have the sleeve off before installing the driver. Then things worked well.
It failed with the sleeve left on.
SamOntario
PostPosted: Fri Mar 11, 2005 3:11 pm    Post subject: Reply with quote
Is your working satisfactory now? Any problem with sensitivity? My Navman SE seems lagging behind 100m render it almost useful when taking turns!
dokteriq
PostPosted: Tue Jul 04, 2006 6:21 pm    Post subject: Navman SE IPAQ GPS V2.0A 02180100 Reply with quote
I work for the United Nations in Pakistan. I received an iPAQ 5550 and the GPS sleeve from one of our donors in the europe. Unfortunately the software/manual etc are lost for both devices. I have no past experience with this kind of GPS devices.
I am not sure whats the model of this GPS device as it does not say it on the device. These are the things written on it.
NAVMAN SE
Model: IPAQ GPS V2.0A (Can not find it on navman.com)
02180100
Firstly, please tell me if its GPS 3450 cause I am not sure.
Secondly I downloaded the SerialDriver_3_1_6.exe file which helped my iPAQ recognize the sleeve. So I am assuming that worked fine.
Thirdly, what kind of software do I use on my PocketPC to make this thing work? I tried looking up SmartST on Navmans website but apparently its not free. Would I be able to use some other software?
Sorry for all the dumb questions. Thanks for the help guys.
pickles74
PostPosted: Wed Jun 10, 2009 11:05 am    Post subject: navman ipaq serial driver 3.1.6 Reply with quote
hi mate i have the driver disc for navman ipaq gps which suppotrs ipaq h3600 ,h3700 , h3800 , h3900 and h5400.
ne good for you ???? . also got gps sensor for ipaq pocket pc.
kingkong8796
PostPosted: Fri Jun 26, 2009 5:50 pm    Post subject: Navman iPAQ 3.1.6 Serial Driver Reply with quote
my questin is:
did everyone now where i can find this download for Navman iPAQ 3.1.6 Serial Driver?
thanks a lot
Ratbert
PostPosted: Sat Aug 08, 2009 4:59 am    Post subject: Re: Navman iPAQ 3.1.6 Serial Driver Reply with quote
Here: http://www.ctndata.com/download/download.cgi?NAVMAN_3.1.6.exe
stevevx800
PostPosted: Fri Apr 30, 2010 12:42 pm    Post subject: Reply with quote
You can get the driver for the sleeve called DL02 here
http://www.support.navman-europe.com/Downloads/DL02.zip
there is a rom upgrade for the 3450 jacket, it can only be used on the jacket that has the external aerial socket called DL04 here
http://www.support.navman-europe.com/Downloads/DL04.zip
I have them on a 3870 with Navman se sleeve 3450 works perfectly also used with 3970 both with 2003 os, tomtom 6, other nmea receiver, baud rate 57600, navman driver
DL03 is gps info if you need to find your settings
http://www.support.navman-europe.com/Downloads/DL03.zip
VX800
Page 2 of 2
23.094 (24 Sep 25)
