Pocket GPS World :: View topic - GO 720 sound issues after update
Geoggy
PostPosted: Thu Jun 25, 2009 9:50 am    Post subject: GO 720 sound issues after update Reply with quote
Hi all,
Haven't updated my Go 720 for about 9 months.
Tomtom home hates me and always makes something go wrong with my tomtom, so I avoid it like the plague.
Anyway, recently it was struggling recently to get gps fixes, so I bit the bullet and downloaded the latest tomtom home, hooked up and updated.
I tried to do a backup and resotre first, but home told me my device didnt support this?! I know at this point I should hav eunplugged it and run off, but silly me went ahead an installed all the updates.
Now everything running great apart from the sound. Was finne before the update, now I have intermittent sound.
Some days - fine - other days absolutely nothing.
Can anyone suggest some things for me to try to rectify it It can't be a hardware issue surely?
G
dhn
PostPosted: Thu Jun 25, 2009 11:49 am    Post subject: Reply with quote
When you say 'sound', is this the voices you are referring to? And, if so, the recorded voices or computer voices?
Or, by 'sounds', do you mean the built in sounds that are utilized as warning sounds??
PaulB2005
PostPosted: Thu Jun 25, 2009 11:55 am    Post subject: Reply with quote
Also before you do anything else read the TomTom FAQ especially Number 1, which details how to make a backup with Windows Explorer. Never use TT Home to backup and restore the device
Secondly which updates did you install?
Geoggy
PostPosted: Fri Jul 03, 2009 7:35 pm    Post subject: Reply with quote
guys - thanks for replies - work been hell so this is first chance i have had to sit down and have another go at sorting this out.
tomtom home 2.6 tells me that i have installed 8.351 version of tomtom
i am still getting intermittent sound. by sound i mean all sounds. one minute the voice will work then stop - and all of the voices, computer and human.
yesterday i was getting speed camera alerts for a few miles then they stopped.
then i was getting speed limit alerts and again they stopped.
its driving me insane. m6 was closed last night and i was re routed through cheshire and its a nuisance having to watch the screen and the road.
help!
AndyVaughan
PostPosted: Fri Jul 03, 2009 8:50 pm    Post subject: Reply with quote
Download the ClearFlash tool from TT and run it.
Then do a hard reset and run clear flash again.
Make sure HOME is not running - exit the icon in the system tray before starting.
Geoggy
PostPosted: Fri Jul 03, 2009 9:26 pm    Post subject: Reply with quote
done that andy thanks - made no difference - went into voice prefs, test voice - silence
PostPosted: Fri Jul 03, 2009 9:47 pm    Post subject: Reply with quote
If you view the device using Windows Explorer and right click the drive letter associated with the device then click "Properties" how much free space is available? - A lack of available storage space can cause strange behaviour and this is easy to resolve by removing certain files from the unit or transfering the map to an SD card - Mike
Geoggy
PostPosted: Fri Jul 03, 2009 10:23 pm    Post subject: Reply with quote
mike - the map is on my 2gb sd card - so the available space on the hard drive of the tomtom is over 1 GB
AndyVaughan
PostPosted: Sat Jul 04, 2009 1:13 pm    Post subject: Reply with quote
The plot thickens .......
The map is on the SD card - where do you have the voices and the Navcore app?
Try copying the map to the main memory and then trying again.
The latest applications have exhibited some odd behaviour when using the SD card and the internal memory at the same time.
For troubleshooting purposes run EVERYTHING from the internal memory, with no SD Card in the device.
If you ran clear flash where did you install it to - the main memory or the SD card?
Also, after taking out the SD Card ensure all your voices are up to date using HOME.
Geoggy
PostPosted: Sat Jul 04, 2009 1:59 pm    Post subject: Reply with quote
thanks andy,
ok i've moved the map to the tomtom, taken out the sd card and run ttflash again - it doesn't give me an option of where i want to install it, but given that I ran it with no sd card in I can only assume that it installed in the tomtom memory.
all went ok until i got to your last step - and now there is no room for any voices on the tomtom.
windows explorer is saying that the capacity is 1.91gb and there is 1.87gb used.
i only have the map, the application, speed cameras and postcodes on there.
my map is western europe and its 1.66gb
i really do appreciate the help
thanks
Ian
Geoggy
PostPosted: Sat Jul 04, 2009 2:15 pm    Post subject: Reply with quote
i think we are getting there, i've managed to get a non computer voice on and its working.
if i can get some guidance on how to fit a computer voice on then i think its sorted!
Very Happy
edit: just looking at my file structure on the tomtom and i have a folder called Tomtom (J) - when i open this it seems to have similar folders as my route directory - is this anything to do with why i have no space?
edit 2: getting impatient so started deleting files in this folder that seem to be duplicates of those in the root directory - done that - copied a computer voice over, and *i think* its sorted - will take it out for a spin to try it.
thanks again for all your help - what the hell do i need an sd card for now??!! Laughing
dhn
PostPosted: Sat Jul 04, 2009 3:42 pm    Post subject: Reply with quote
Why a card? To avoid all the aggrevation you're having with space on internal flash memory.
I would strongly suggest you get a 4-gig sdhc card and put your map on it. Lots of room to then add more computer voices to the Loquendo folder using Home.
Plus flexibility to add mp3'/photos on the card (or internal) as you'll have more storage space to play with.
My opinion, anyway........
Geoggy
PostPosted: Sat Jul 04, 2009 4:38 pm    Post subject: Reply with quote
thanks david
thanks all - just been out in the lovely summer rain and tomtom was talking to me.
thank you for all your help - if anyone knows what that tomtom (j) directory is and if i can get rid of it let me know
thanks
dhn
PostPosted: Sat Jul 04, 2009 4:55 pm    Post subject: Reply with quote
If you download this utility
DriveZ
, it will let you show contents of a folder and be able to copy & paste contents to a location (like a post here).
So, if you provide relevant info using that tool, someone here should be able to advise.
Geoggy
PostPosted: Sat Jul 04, 2009 6:19 pm    Post subject: Reply with quote
DriveZ
ok here goes:
root directory is here;
art
ASR
bin
contacts
customvoice
ephem
gns
helpme
itn
licences
logging
LoquendoTTS
microbrowser
phone_database
program
script
SIMCARD
sounds
statdata
TomTom (J)
TomTom-Cfg
voices
Western_Europe
zip
antitheftw
bootloaderversion
clmdata
CurrentMap
data
data_im1
data_lim
data_ra
data_sp
data_ts
fm2010parameters
fmsignal
install
internal
libaec_55
libaec_60
lowbatteryw
mctx
reflush
settings
signpost_li
system
tomtom
ttgo
tthome
ttpnpd
ttsystem
UserPatch
then that tomtomj thing is here;
art
ASR
audiobooks
bin
Canary_Islands
contacts
demo
ephem
fleetecd
gns
helpme
home images
itn
licences
logging
mp3
photos
raster
schemes
sounds
statdata
text
TomTom HOME Install.app
TomTom-Cfg
voices
Western_Europe
zip
antitheftw
autorun
clmdata
connect2internet
connect2internet
connect2internetdb
CurrentLocation
CurrentMap
data
fm2010parameters
fmsignal
install
InstallTomTomHOME
libaec
lowbatteryw
mctx
newsettings
settings
splashw
system
tomtom
tthome
TTPnPD
ttsystem
UserPatch
be good to free up some space beacuse i quite fancy subscribing to the gpsworld cameras after doing some reading on the site.
23.105 (29 Oct 25)
