Pocket GPS World :: View topic - Leadtek 9532 Initialisation problems
mike100
PostPosted: Wed Aug 11, 2004 8:25 pm    Post subject: Leadtek 9532 Initialisation problems Reply with quote
I have written a bespoke software application to monitor a Leadtek 9532 gps receiver.
Before I can use my software I must first initialise the GPS unit with Winfast Navigator (the software suppied with the GPS unit).
Once the GPS has been initialised with Winfast Navigator, I can then shut Winfast Navigator down and launch my own software.
I need to load Winfast Navigator each time I power up the GPS unit.
Whilst most GPS units blindly output the NMEA data, it appears that this Leadtek unit requires an input message to be sent to it before it will output any data.
Can someone please identify what this input message is - its driving me mad.
Regards in advance
Mike
PostPosted: Wed Aug 11, 2004 9:37 pm    Post subject: Reply with quote
When you look at the Dev screen in WinFast or other tools there is a $PST message (or something of this kind). Try capturing just the first few lines of the connection.
mike100
PostPosted: Wed Aug 11, 2004 11:26 pm    Post subject: Reply with quote
When I do a hardware reset, I get the following information - but no $PST command.
$Version 220.006.000ES-LD03
$TOW: 0
$WK: 1151
$POS: 6378137 0 0
$CLK: 85811
$CHNL:12
$Baud rate: 4800 System clock: 12.277MHz
$HW Type: S2AR
Any ideas ?
Is it possible that the unit is starting up in SiRF Binary Protocol mode ?
PostPosted: Thu Aug 12, 2004 1:16 am    Post subject: Reply with quote
I don't think it's starting in SiRF binary. What happens if you send just some carriage returns down the pipe?
ckuethe
PostPosted: Thu Aug 12, 2004 3:46 am    Post subject: Reply with quote
That looks suspiciously like it might just be starting in binary mode. My TN-200 will output those very strings (well, something similar) in binary message number 255 (Development Information). Try using SiRFdemo to set the output format. and see if it comes back in NMEA mode.
PostPosted: Thu Aug 12, 2004 4:17 am    Post subject: Reply with quote
You sure? I tried the reset with my Leadtek 9537 clone, and that one definitely is set to NMEA, and it emits similiar strings when programmed. (the programming itself actually gets sent in SiRF mode).
So how would you switch from SiRF to NMEA? What message is that?
ckuethe
PostPosted: Thu Aug 12, 2004 7:21 am    Post subject: Reply with quote
SiRF message 129 (switch to nmea protocol) or message 165 (set uart configuration).
and to set SiRF mode, send "$PSRF100,0,[baudrate],8,1,0*[cksum]"
All the interesting stuff is done in SiRF mode unless you have a u-blox firmware. u-blox has some interesting proprietary nmea messages. basically nmea-encoded binary.
I've never seen my TN200 output those strings in NMEA mode... but I don't bother using the NMEA interface, as the binary protocol is so much richer. that and i've written a toolkit to use the binary protocol without much hassle. The only reason I need NMEA any more is to get the UTC/GPS time difference... it's a royal pain calculating leap second difference from the 50bps data.
mike100
PostPosted: Tue Aug 24, 2004 11:02 pm    Post subject: Initialisation Problem Solved - Software Bug Reply with quote
Thanks for the advice guys - but I've finally found the problem.
The flow control within my application was defaulting to ON instead of OFF - hence the need to run Winfast Navigator in order to initialise the flow control correctly first
I have now found a way of fixing the problem
GpsGisGuy
PostPosted: Sat Aug 22, 2009 1:38 pm    Post subject: Incoming GPS port data Reply with quote
Thank's mike100,
I had the same problem. Though your info wasn't precise, it did give me a place to check. When I opened the gps port, all I got back was gobble-dee-goop. I, too, thought the device was operating in binary mode or the baud rate was wrong. However, this was not the case.
But, when I opened the port with the GPS Diagnostic program everything worked.
Here's what I found in the case of my problem:
The problem was in the Device Control Block (DCB) values. When I opend the port from my program, one of the params (fOutxCtsFlow) was set to 459264 (H70200), but when the GPS diag opened the port the value was set to 524800 (H80200). I changed my program to init this value to &H80200 and now everything works.
So Thanks Again. This problem was a real bug in the works!
24.041 (01 Apr 26)
